    CMake编译错误
    cmake ros2 foxy
    • 2716585362
      ℡﹏smˋ背靠背の承诺
      前置操作
      安装carotgrapher
      sudo apt install ros-foxy-cartographer
      sudo apt install ros-foxy-cartographer-ros
      然后在fishbot_ws工作空间创建fishbot_cartographer功能包
      ros2 pkg create fishbot_cartographer
      执行编译命令
      colcon build --packages-select fishbot_cartographer
      CMakeLists.txt文件内容如下
      project(fishbot_cartographer)
      install(
        DIRECTORY config launch rviz
        DESTINATION share/${PROJECT_NAME}
      # Default to C99
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
      if(BUILD_TESTING)
        # uncomment the line when a copyright and license is not present in all source files
        #set(ament_cmake_copyright_FOUND TRUE)
        # uncomment the line when this package is not in a git repo
        #set(ament_cmake_cpplint_FOUND TRUE)
      endif()
      ament_package()
      编译错误内容如下
      Starting >>> fishbot_cartographer
      --- stderr: fishbot_cartographer
        File "/opt/ros/foxy/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 21, in <module>
          from catkin_pkg.package import parse_package_string
      ModuleNotFoundError: No module named 'catkin_pkg'
      CMake Error at /opt/ros/foxy/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:94 (message):
        execute_process(/home/ros2/miniconda3/bin/python3
        /home/ros2/fishbot_ws/src/fishbot_cartographer/package.xml
        /home/ros2/fishbot_ws/build/fishbot_cartographer/ament_cmake_core/package.cmake)
        returned error code 1
        /opt/ros/foxy/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml)
        /opt/ros/foxy/share/ament_lint_auto/cmake/ament_lint_auto_find_test_dependencies.cmake:31 (ament_package_xml)
        CMakeLists.txt:37 (ament_lint_auto_find_test_dependencies)
      Failed   <<< fishbot_cartographer [0.63s, exited with code 1]
      Summary: 0 packages finished [0.85s]
        1 package failed: fishbot_cartographer
        1 package had stderr output: fishbot_cartographer
      新建功能包无任何操作,编译也是这个错误。
      • 2716585362
        ℡﹏smˋ背靠背の承诺
        @271658536 在 CMake编译错误 中说:
        已经解决,解决方法原文如下:
        https://blog.csdn.net/qq_27865227/article/details/122609055
        • 2716585362 271658536 将这个主题标记为已解决,在
