    fishbot自定义消息章节 删除/libmicroros 重新构建后报错
    自定义消息 fishbot
    • 20493681212
      星オレンジ
      CMake Warning:
      Manually-specified variables were not used by the project:
      THIRDPARTY
      --- stderr: fishbot_interfaces
      CMake Error at CMakeLists.txt:27 (find_package):
      By not providing "Findrosidl_default_generators.cmake" in CMAKE_MODULE_PATH
      this project has asked CMake to find a package configuration file provided
      by "rosidl_default_generators", but CMake did not find one.
      "rosidl_default_generators" with any of the following names:
      rosidl_default_generatorsConfig.cmake
      rosidl_default_generators-config.cmake
      Add the installation prefix of "rosidl_default_generators" to
      CMAKE_PREFIX_PATH or set "rosidl_default_generators_DIR" to a directory
      containing one of the above files. If "rosidl_default_generators" provides
      a separate development package or SDK, be sure it has been installed.
      Failed <<< fishbot_interfaces [1.39s, exited with code 1]
      5 1 条回复 最后回复 回复 引用 0
      • 5
        Henry @2049368121
        @2049368121 解决了吗,我也遇见这个问题。更改了cemakelist也还是没解决
