    Ros安装出现Traceback的报错
    安装,traceback ros1
      简单
      ROS相关:
      常用软件:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [14]:一键安装:科学上网代理工具
      [15]:一键安装:QQ for Linux
      配置工具:
      [13]:一键配置:python国内源
      请输入[]内的数字以选择:1
      --2024-03-25 15:02:19-- http://mirror.fishros.com/install/tools/tool_install_ros.py
      正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... 已连接。
      已发出 HTTP 请求,正在等待回应... 200 OK
      长度: 19468 (19K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 19.01K --.-KB/s 用时 0.04s
      2024-03-25 15:02:19 (473 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19468/19468])
      --2024-03-25 15:02:19-- http://mirror.fishros.com/install/tools/tool_config_rosenv.py
      /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s 用时 0s
      2024-03-25 15:02:19 (136 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
      --2024-03-25 15:02:19-- http://mirror.fishros.com/install/tools/tool_config_system_source.py
      长度: 7708 (7.5K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 7.53K --.-KB/s 用时 0s
      2024-03-25 15:02:19 (24.5 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7708/7708])
      File "/tmp/fishinstall/install.py", line 123, in <module>
      File "/tmp/fishinstall/install.py", line 115, in main
      File "/tmp/fishinstall/tools/base.py", line 1297, in run_tool_file
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 390, in run
      self.install_ros()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 377, in install_ros
      if not self.support_install(): return False
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 279, in support_install
      if (osversion.get_codename() not in ros_dist_dic.keys()) and (osversion.get_codename() not in ros2_dist_dic.keys()):
      File "/tmp/fishinstall/tools/base.py", line 682, in get_codename
      self.detect_os()
      File "/tmp/fishinstall/tools/base.py", line 642, in detect_os
      tools.base.OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
      1 条回复 最后回复 回复 引用 1
