    一键安装失败,换源失败,拜托大佬了
    一键安装 换源问题 18.04 imxull
    • 7
      年夕
      RUN Choose Task:[请输入括号内的数字]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:bionic],正在为你更换对应源..
      创建文件:/etc/apt/sources.list
      替换完成,尝试第一次更新....
      [-]Result:success --upgradable’ 来查看它们。ltiverse Translation-en [3,928 B]
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['获取:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic InRelease [242 kB]', '获取:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates InRelease [88.7 kB]', '获取:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports InRelease [83.3 kB]', '获取:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security InRelease [88.7 kB]', '获取:5 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main armhf Packages [968 kB]', '获取:6 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main Translation-zh_CN [67.7 kB]', '获取:7 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/main Translation-en [516 kB]', '获取:8 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted armhf Packages [8,360 B]', '获取:9 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted Translation-zh_CN [1,188 B]', '获取:10 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/restricted Translation-en [3,584 B]', '获取:11 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe armhf Packages [8,269 kB]', '获取:12 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe Translation-en [4,941 kB]', '获取:13 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/universe Translation-zh_CN [174 kB]', '获取:14 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse armhf Packages [129 kB]', '获取:15 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse Translation-en [108 kB]', '获取:16 https://mirrors.ustc.edu.cn/ubuntu-ports bionic/multiverse Translation-zh_CN [4,768 B]', '获取:17 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main armhf Packages [1,438 kB]', '获取:18 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/main Translation-en [553 kB]', '获取:19 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted armhf Packages [13.4 kB]', '获取:20 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/restricted Translation-en [187 kB]', '获取:21 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe armhf Packages [1,626 kB]', '获取:22 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/universe Translation-en [421 kB]', '获取:23 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse armhf Packages [6,200 B]', '获取:24 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates/multiverse Translation-en [6,088 B]', '获取:25 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main armhf Packages [53.2 kB]', '获取:26 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/main Translation-en [14.6 kB]', '获取:27 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe armhf Packages [17.7 kB]', '获取:28 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports/universe Translation-en [8,668 B]', '获取:29 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main armhf Packages [1,162 kB]', '获取:30 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/main Translation-en [467 kB]', '获取:31 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted armhf Packages [9,576 B]', '获取:32 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/restricted Translation-en [182 kB]', '获取:33 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe armhf Packages [1,091 kB]', '获取:34 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/universe Translation-en [308 kB]', '获取:35 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse armhf Packages [2,672 B]', '获取:36 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security/multiverse Translation-en [3,928 B]', '已下载 23.3 MB,耗时 1分 15秒 (309 kB/s)', '正在读取软件包列表...', '正在分析软件包的依赖关系树...', '正在读取状态信息...', '有 75 个软件包可以升级。请执行 ‘apt list --upgradable’ 来查看它们。', '']
      镜像修复完成.....
      [-]Result:success --upgradable’ 来查看它们。eleasee
      [-]Result:success age - all developer toolsnt filesMPDsfilesbrariesesr)d line
      [-]Result:success 要卸载 0 个软件包,有 75 个软件包未被升级。
      [-]Result:success eplacement (dummy transitional package)
      [-]Result:success
      [-]Result:success
      [-]Result:success --upgradable’ 来查看它们。arm64 Packages [793 kB]
      [-]Result:success e development metapackageKerberos
      [-]Result:success
      [-]Result:success --upgradable’ 来查看它们。ackages [793 kB]
      [-]Result:success
      [-]Result:success --upgradable’ 来查看它们。es [660 kB]
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros/ubuntu/', 'https://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      [-]Result:code:2
      [-]Result:code:2
