    cartographer保存图与rviz显示不一致,且在nav2中加载保存的图是一片白
    仿真
    cartographer 仿真
    1.5k
    • 24758873092
      Mona Darling
      标题:cartographer保存图与rviz显示不一致,且在nav2中加载保存的图是一片白
      硬件 nuc x86平台
      系统版本 ubuntu20.04
      ros版本 foxy
      cartographer建图后使用下面命令后保存的图保存图与rviz显示不一致,且在nav2中加载保存的图是一片白
      ros2 run nav2_map_server map_saver_cli -t map -f fishbot_map
      nav2导入的图是空白的(确定map文件夹下的图已经替换为最新的,编译后share目录下也有对应的图)
      nav2 parmar 配置如下
      amcl:
        ros__parameters:
          use_sim_time: True
          alpha1: 0.2
          alpha2: 0.2
          alpha3: 0.2
          alpha4: 0.2
          alpha5: 0.2
          beam_skip_distance: 0.5
          beam_skip_threshold: 0.3
          do_beamskip: false
          global_frame_id: "map"
          lambda_short: 0.1
          laser_max_range: 100.0
          laser_min_range: -1.0
          max_beams: 60
          max_particles: 2000
          min_particles: 500
          odom_frame_id: "odom"
          pf_err: 0.05
          pf_z: 0.99
          recovery_alpha_fast: 0.0
          recovery_alpha_slow: 0.0
          resample_interval: 1
          robot_model_type: "differential"
          save_pose_rate: 0.5
          sigma_hit: 0.2
          tf_broadcast: true
          transform_tolerance: 1.0
          update_min_a: 0.2
          update_min_d: 0.25
          z_hit: 0.5
          z_max: 0.05
          z_rand: 0.5
          z_short: 0.05
          scan_topic: scan
      amcl_map_client:
        ros__parameters:
          use_sim_time: True
      amcl_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      bt_navigator:
        ros__parameters:
          use_sim_time: True
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          enable_groot_monitoring: True
          groot_zmq_publisher_port: 1666
          groot_zmq_server_port: 1667
          default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
          plugin_lib_names:
          - nav2_back_up_action_bt_node
          - nav2_spin_action_bt_node
          - nav2_wait_action_bt_node
          - nav2_recovery_node_bt_node
      bt_navigator_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      controller_server:
        ros__parameters:
          use_sim_time: True
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          progress_checker_plugin: "progress_checker"
          goal_checker_plugin: "goal_checker"
          controller_plugins: ["FollowPath"]
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          goal_checker:
            plugin: "nav2_controller::SimpleGoalChecker"
            xy_goal_tolerance: 0.25
            yaw_goal_tolerance: 0.25
            stateful: True
          # DWB parameters
          FollowPath:
            plugin: "dwb_core::DWBLocalPlanner"
            debug_trajectory_details: True
            min_vel_x: 0.0
            min_vel_y: 0.0
            max_vel_x: 0.26
            max_vel_y: 0.0
            max_vel_theta: 1.0
            min_speed_xy: 0.0
            max_speed_xy: 0.26
            min_speed_theta: 0.0
            # Add high threshold velocity for turtlebot 3 issue.
            # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
            acc_lim_x: 2.5
            acc_lim_y: 0.0
            acc_lim_theta: 3.2
            decel_lim_x: -2.5
            decel_lim_y: 0.0
            decel_lim_theta: -3.2
            vx_samples: 20
            vy_samples: 5
            vtheta_samples: 20
            sim_time: 1.7
            linear_granularity: 0.05
            angular_granularity: 0.025
            transform_tolerance: 0.2
            trans_stopped_velocity: 0.25
            short_circuit_trajectory_evaluation: True
            stateful: True
            critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
            BaseObstacle.scale: 0.02
            PathAlign.scale: 32.0
            PathAlign.forward_point_distance: 0.1
            GoalAlign.scale: 24.0
            GoalAlign.forward_point_distance: 0.1
            PathDist.scale: 32.0
            GoalDist.scale: 24.0
            RotateToGoal.scale: 32.0
            RotateToGoal.slowing_factor: 5.0
            RotateToGoal.lookahead_time: -1.0
      controller_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      local_costmap:
        local_costmap:
          ros__parameters:
            update_frequency: 5.0
            publish_frequency: 2.0
            global_frame: odom
            use_sim_time: True
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            robot_radius: 0.12
            plugins: ["voxel_layer", "inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.35
            voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
                topic: /scan
                clearing: True
                marking: True
                data_type: "LaserScan"
            static_layer:
        local_costmap_client:
          ros__parameters:
            use_sim_time: True
        local_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      global_costmap:
        global_costmap:
          ros__parameters:
            update_frequency: 1.0
            publish_frequency: 1.0
            global_frame: map
            use_sim_time: True
            robot_radius: 0.12
            resolution: 0.05
            track_unknown_space: true
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
            static_layer:
            inflation_layer:
              inflation_radius: 0.55
        global_costmap_client:
          ros__parameters:
            use_sim_time: True
        global_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      map_server:
        ros__parameters:
          use_sim_time: True
          yaml_filename: "turtlebot3_world.yaml"
      map_saver:
        ros__parameters:
          use_sim_time: True
          save_map_timeout: 5000
          free_thresh_default: 0.25
          occupied_thresh_default: 0.65
          map_subscribe_transient_local: False
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          use_sim_time: True
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner/NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      planner_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      recoveries_server:
        ros__parameters:
          costmap_topic: local_costmap/costmap_raw
          footprint_topic: local_costmap/published_footprint
          cycle_frequency: 10.0
          recovery_plugins: ["spin", "back_up", "wait"]
          spin:
            plugin: "nav2_recoveries/Spin"
          back_up:
            plugin: "nav2_recoveries/BackUp"
          wait:
            plugin: "nav2_recoveries/Wait"
          global_frame: odom
          transform_timeout: 0.1
          use_sim_time: true
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      robot_state_publisher:
        ros__parameters:
          use_sim_time: True
      nav2launch文件配置如下
      作者: 小鱼
      公众号: 鱼香ROS
      QQ交流群: 2642868461
      描述: Nav2 launch启动文件
      import os
      from launch.actions import IncludeLaunchDescription
          #=============================1.定位到包的地址=============================================================
          fishbot_navigation2_dir = get_package_share_directory('fishbot_navigation2')
          #=============================2.声明参数,获取配置文件路径===================================================
          # use_sim_time 这里要设置成true,因为gazebo是仿真环境,其时间是通过/clock话题获取,而不是系统时间
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          map_yaml_path = LaunchConfiguration('map',default=os.path.join(fishbot_navigation2_dir,'maps','fishbot_map.yaml'))
          nav2_param_path = LaunchConfiguration('params_file',default=os.path.join(fishbot_navigation2_dir,'param','fishbot_nav2.yaml'))
          rviz_config_dir = os.path.join(nav2_bringup_dir,'rviz','nav2_default_view.rviz')
          #=============================3.声明启动launch文件,传入:地图路径、是否使用仿真时间以及nav2参数文件==============
          nav2_bringup_launch = IncludeLaunchDescription(
                  PythonLaunchDescriptionSource([nav2_bringup_dir,'/launch','/bringup_launch.py']),
                  launch_arguments={
                      'map': map_yaml_path,
                      'use_sim_time': use_sim_time,
                      'params_file': nav2_param_path}.items(),
          rviz_node =  Node(
                  package='rviz2',
                  executable='rviz2',
                  name='rviz2',
                  output='screen')
          return LaunchDescription([nav2_bringup_launch,rviz_node])
      运行保存地图命令后的log
      doki@doki:~/fishbot_ws/src/fishbot_cartographer/map$ ros2 run nav2_map_server map_saver_cli -t map -f fishbot_map
      /opt/ros/foxy/bin/ros2:6: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
        from pkg_resources import load_entry_point
      2024-04-15 13:35:07.235 [RTPS_TRANSPORT_SHM Error] Failed init_port fastrtps_port7419: open_and_lock_file failed -> Function open_port_internal
      [INFO] [1713159307.271350024] [map_saver]:
      	map_saver lifecycle node launched.
      	Waiting on external lifecycle transitions to activate
      	See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [INFO] [1713159307.271799476] [map_saver]: Creating
      [INFO] [1713159307.272066482] [map_saver]: Saving map from 'map' topic to 'fishbot_map' file
      [WARN] [1713159307.272093244] [map_saver]: Free threshold unspecified. Setting it to default value: 0.250000
      [WARN] [1713159307.272109316] [map_saver]: Occupied threshold unspecified. Setting it to default value: 0.650000
      [WARN] [map_io]: Image format unspecified. Setting it to: pgm
      [INFO] [map_io]: Received a 627 X 424 map @ 0.4 m/pix
      [INFO] [map_io]: Writing map occupancy data to fishbot_map.pgm
      [INFO] [map_io]: Writing map metadata to fishbot_map.yaml
      [INFO] [map_io]: Map saved
      [INFO] [1713159307.981907269] [map_saver]: Map saved successfully
      [INFO] [1713159307.982130604] [map_saver]: Destroying
      rviz 的部分日志(太多了,```
      [rviz2-10] [INFO] [1713159647.797478864] [rviz2]: Message Filter dropping message: frame 'odom' at time 472.554 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159647.799202254] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159647.862795699] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 472.638 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.022436640] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.022596268] [rviz2]: Message Filter dropping message: frame 'odom' at time 472.753 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.054023783] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 472.837 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.214593625] [rviz2]: Message Filter dropping message: frame 'odom' at time 472.952 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.278110172] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 473.038 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159648.299271064] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159648.406450886] [rviz2]: Message Filter dropping message: frame 'odom' at time 473.152 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.439731285] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159648.440915173] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159648.469438843] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 473.237 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.597485350] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.597642555] [rviz2]: Message Filter dropping message: frame 'odom' at time 473.352 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.661936972] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 473.438 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159648.799237647] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159648.822041899] [rviz2]: Message Filter dropping message: frame 'odom' at time 473.552 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159648.854357300] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 473.637 for reason 'Unknown'
      [amcl-2] [WARN] [1713159648.863671605] [amcl]: ACML cannot publish a pose or update the transform. Please set the initial pose...
      [rviz2-10] [INFO] [1713159649.013832346] [rviz2]: Message Filter dropping message: frame 'odom' at time 473.754 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.078166627] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 473.838 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.206504088] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.206787334] [rviz2]: Message Filter dropping message: frame 'odom' at time 473.951 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.269529554] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 474.038 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159649.299290754] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159649.399012779] [rviz2]: Message Filter dropping message: frame 'odom' at time 474.151 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.441700218] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159649.442619588] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159649.462482790] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 474.238 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.622652422] [rviz2]: Message Filter dropping message: frame 'odom' at time 474.351 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.686002800] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 474.438 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159649.799189835] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159649.814223037] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.814709394] [rviz2]: Message Filter dropping message: frame 'odom' at time 474.550 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159649.878791784] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 474.638 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.005417642] [rviz2]: Message Filter dropping message: frame 'odom' at time 474.750 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.070341239] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 474.838 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.198511275] [rviz2]: Message Filter dropping message: frame 'odom' at time 474.949 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.261945399] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 475.037 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159650.299247049] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159650.421914516] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.422045626] [rviz2]: Message Filter dropping message: frame 'odom' at time 475.150 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.443113732] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159650.444083290] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159650.485644092] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 475.237 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.613620479] [rviz2]: Message Filter dropping message: frame 'odom' at time 475.352 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.678198323] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 475.437 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159650.799244227] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159650.805600382] [rviz2]: Message Filter dropping message: frame 'odom' at time 475.553 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.870276858] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 475.637 for reason 'Unknown'
      [amcl-2] [WARN] [1713159650.882334554] [amcl]: ACML cannot publish a pose or update the transform. Please set the initial pose...
      [rviz2-10] [INFO] [1713159650.998285087] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159650.998422818] [rviz2]: Message Filter dropping message: frame 'odom' at time 475.749 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.093894366] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 475.837 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.221625376] [rviz2]: Message Filter dropping message: frame 'odom' at time 475.949 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.286049976] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 476.037 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159651.299249407] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159651.413803093] [rviz2]: Message Filter dropping message: frame 'odom' at time 476.149 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.444867464] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159651.445873984] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159651.478551117] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 476.238 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.606442996] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.606746417] [rviz2]: Message Filter dropping message: frame 'odom' at time 476.348 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.701941527] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 476.437 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159651.797544944] [rviz2]: Message Filter dropping message: frame 'odom' at time 476.547 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159651.799309499] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159651.894219467] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 476.638 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.021925720] [rviz2]: Message Filter dropping message: frame 'odom' at time 476.748 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.085431324] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 476.838 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.214032369] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.214224830] [rviz2]: Message Filter dropping message: frame 'odom' at time 476.947 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.278332345] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 477.037 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159652.299237975] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159652.406072540] [rviz2]: Message Filter dropping message: frame 'odom' at time 477.146 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.446284509] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159652.447689916] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159652.501870393] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 477.238 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.598241486] [rviz2]: Message Filter dropping message: frame 'odom' at time 477.345 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.693494315] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 477.438 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159652.799344432] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159652.822452165] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.822896275] [rviz2]: Message Filter dropping message: frame 'odom' at time 477.546 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159652.886226420] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 477.637 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.014130858] [rviz2]: Message Filter dropping message: frame 'odom' at time 477.746 for reason 'Unknown'
      [amcl-2] [WARN] [1713159653.108456455] [amcl]: ACML cannot publish a pose or update the transform. Please set the initial pose...
      [rviz2-10] [INFO] [1713159653.110023775] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 477.837 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.206759680] [rviz2]: Message Filter dropping message: frame 'odom' at time 477.945 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159653.299191104] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159653.301679760] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 478.037 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.397709834] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.397828950] [rviz2]: Message Filter dropping message: frame 'odom' at time 478.145 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.448269136] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1713159653.449045781] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [rviz2-10] [INFO] [1713159653.495060844] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 478.238 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.621509719] [rviz2]: Message Filter dropping message: frame 'odom' at time 478.344 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.686319605] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 478.438 for reason 'Unknown'
      [planner_server-5] [INFO] [1713159653.799207263] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1713159653.813864847] [rviz2]: Message Filter dropping message: frame 'odom' at time 478.543 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159653.909697860] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 478.637 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159654.006121477] [rviz2]: Message Filter dropping message: frame 'odom' at time 0.000 for reason 'Unknown'
      [rviz2-10] [INFO] [1713159654.006264343] [rviz2]: Message Filter dropping message: frame 'odom' at time 478.743 for reason 'Unknown'
      [bt_navigator-7] [INFO] [1713159654.099212964] [rclcpp]: signal_handler(signal_value=2)
      [waypoint_follower-8] [INFO] [1713159654.099250860] [rclcpp]: signal_handler(signal_value=2)
      [rviz2-10] [INFO] [1713159654.099260991] [rclcpp]: signal_handler(signal_value=2)
      [rviz2-10] [INFO] [1713159654.099603561] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10]
      [rviz2-10] >>> [rcutils|error_handling.c:108] rcutils_set_error_state()
      [rviz2-10] This error state is being overwritten:
      [rviz2-10]
      [rviz2-10] 'rcl node's context is invalid, at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/node.c:441'
      [rviz2-10]
      [rviz2-10] with this new error message:
      [rviz2-10]
      [rviz2-10] 'the given context is not valid, either rcl_init() was not called or rcl_shutdown() was called., at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/wait.c:130'
      [rviz2-10]
      [rviz2-10] rcutils_reset_error() should be called after error handling to avoid this.
      [rviz2-10] <<<
      [rviz2-10] terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
      [rviz2-10] what(): failed to initialize wait set: the given context is not valid, either rcl_init() was not called or rcl_shutdown() was called., at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/wait.c:130
      [map_server-1] [INFO] [1713159654.099292247] [rclcpp]: signal_handler(signal_value=2)
      [map_server-1] [INFO] [1713159654.102026209] [map_server]: Destroying
      [lifecycle_manager-9] [INFO] [1713159654.099293681] [rclcpp]: signal_handler(signal_value=2)
      [lifecycle_manager-9] [ERROR] [1713159654.101441635] [lifecycle_manager_navigation]: Failed to change state for node: planner_server
      [lifecycle_manager-9] [ERROR] [1713159654.101501914] [lifecycle_manager_navigation]: Failed to bring up all requested nodes. Aborting bringup.
      [lifecycle_manager-9] terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
      [lifecycle_manager-9] what(): Failed to create interrupt guard condition in Executor constructor: the given context is not valid, either rcl_init() was not called or rcl_shutdown() was called., at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/guard_condition.c:67
      [lifecycle_manager-3] [INFO] [1713159654.099292959] [rclcpp]: signal_handler(signal_value=2)
      [recoveries_server-6] [INFO] [1713159654.099298399] [rclcpp]: signal_handler(signal_value=2)
      [INFO] [planner_server-5]: process has finished cleanly [pid 81383]
      [planner_server-5] [INFO] [1713159654.099319352] [rclcpp]: signal_handler(signal_value=2)
      [planner_server-5] [INFO] [1713159654.099924784] [global_costmap.global_costmap]: start
      [planner_server-5] [ERROR] [1713159654.102255260] []: Caught exception in callback for transition 13
      [INFO] [recoveries_server-6]: process has finished cleanly [pid 81385]
      [amcl-2] [INFO] [1713159654.099359884] [rclcpp]: signal_handler(signal_value=2)
      [controller_server-4] [INFO] [1713159654.099360150] [rclcpp]: signal_handler(signal_value=2)
      [planner_server-5] [ERROR] [1713159654.102301003] []: Original error: could not create subscription: rcl node's context is invalid, at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/node.c:441
      [planner_server-5] [ERROR] [1713159654.102363423] []: Failed to finish transition 3. Current state is now: errorprocessing (Could not publish transition: publisher's context is invalid, at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/publisher.c:423, at /tmp/binarydeb/ros-foxy-rcl-lifecycle-1.1.14/src/rcl_lifecycle.c:367)
      [planner_server-5] [INFO] [1713159654.102388121] [planner_server]: Activating plugin GridBased of type NavfnPlanner
      [planner_server-5] [ERROR] [1713159654.102407435] []: Failed to finish transition 3. Current state is now: active (Could not publish transition: publisher's context is invalid, at /tmp/binarydeb/ros-foxy-rcl-1.1.14/src/rcl/publisher.c:423, at /tmp/binarydeb/ros-foxy-rcl-lifecycle-1.1.14/src/rcl_lifecycle.c:367)
      [INFO] [controller_server-4]: process has finished cleanly [pid 81381]
      [lifecycle_manager-3] [INFO] [1713159654.104235704] [lifecycle_manager_localization]: Destroying
      [amcl-2] [INFO] [1713159654.105737279] [amcl]: Destroying
      [bt_navigator-7] [INFO] [1713159654.105798507] [bt_navigator]: Destroying
      [waypoint_follower-8] [INFO] [1713159654.106005618] [waypoint_follower]: Destroying
      [INFO] [map_server-1]: process has finished cleanly [pid 81375]
      [INFO] [lifecycle_manager-3]: process has finished cleanly [pid 81379]
      [INFO] [waypoint_follower-8]: process has finished cleanly [pid 81389]
      [INFO] [amcl-2]: process has finished cleanly [pid 81377]
      [INFO] [bt_navigator-7]: process has finished cleanly [pid 81387]
      [ERROR] [rviz2-10]: process has died [pid 81393, exit code -6, cmd '/opt/ros/foxy/lib/rviz2/rviz2 -d /home/doki/fishbot_ws/install/nav2_bringup/share/nav2_bringup/rviz/nav2_default_view.rviz --ros-args -r __node:=rviz2 --params-file /tmp/launch_params_gizwe1yi'].
      [ERROR] [lifecycle_manager-9]: process has died [pid 81391, exit code -6, cmd '/home/doki/fishbot_ws/install/nav2_lifecycle_manager/lib/nav2_lifecycle_manager/lifecycle_manager --ros-args -r __node:=lifecycle_manager_navigation --params-file /tmp/launch_params_xaxlgzon --params-file /tmp/launch_params_6ul_5qpx --params-file /tmp/launch_params_dbtoojxe'].
      24758873092 1 条回复 最后回复 回复 引用 0
      • 24758873092
        Mona Darling @2475887309
        @2475887309 在 cartographer保存图与rviz显示不一致,且在nav2中加载保存的图是一片白 中说:
        rviz部分日志格式有问题,重发一下
        [rviz2-10]
        [rviz2-10]
        [rviz2-10]
        [rviz2-10]
        [rviz2-10]
        [rviz2-10] <<<
        • 24758873092
          @2475887309 大概知道什么情况了,是launch文件中配置地图分辨率的值比较大,导致生成的图没有黑色线,将地图分辨率改为0.01恢复正常了
