    坐标转换有问题
    仿真
    机械臂坐标转化 机械臂仿真
      Doraemon
      是在Ubuntu18中进行的,我用的是gazebo中带的相机,并不是深度相机,因此这个深度我是自己定义的,在仿真中,定义的物体的位置为(-0.6,0.1,0.3165,0,0,0)输出的为 ('anode pose is: ', [-0.50000007943038327, -0.17674752279857978, 1.059866627149683])
      并且机械臂的末端会朝上,我想要的是末端朝下,朝着物体
      相机的位置为<origin xyz="-0.9 -0.0 1.0" rpy="0 ${M_PI/2} 0"/>
      请问哪里出了问题呢?
      以下是代码
       #coding=utf-8
      import cv2
      import rospy
      import tf
      from cv_bridge import CvBridge
      import numpy as np
      import sys
      import moveit_commander
      from geometry_msgs.msg import PoseStamped
      from std_srvs.srv import Empty
      from yolov8_ros_msgs.msg import BoundingBox, BoundingBoxes
      import random
      class graspDemo:
          def __init__(self):
              # 机械臂规划参考系
              self.reference_frame = 'world'
              # 初始化moveit控制器
              moveit_commander.roscpp_initializer.roscpp_initialize(sys.argv)
              self.robot = moveit_commander.robot.RobotCommander()
              # 初始化manipulator group
              self.arm = moveit_commander.move_group.MoveGroupCommander("manipulator_e5")
              self.end_effector_link = self.arm.get_end_effector_link()
              # 设置容忍误差
              self.arm.set_goal_position_tolerance(0.001)
              self.arm.set_goal_orientation_tolerance(0.05)
              self.arm.allow_replanning(True)
              self.arm.set_pose_reference_frame(self.reference_frame)
          def move(self, pose, orientation):
              target_pose = PoseStamped()
              # 设置消息头部的frame_id,即这个姿态数据参考的坐标帧
              target_pose.header.frame_id = self.reference_frame
              target_pose.header.stamp = rospy.Time.now()
              target_pose.pose.position.x = pose[0]
              target_pose.pose.position.y = pose[1]
              target_pose.pose.position.z = pose[2]
              target_pose.pose.orientation.x = orientation[0]
              target_pose.pose.orientation.y = orientation[1]
              target_pose.pose.orientation.z = orientation[2]
              target_pose.pose.orientation.w = orientation[3]
              # 设置当前坐标为起始坐标
              self.arm.set_start_state_to_current_state()
              # 设置位置目标
              self.arm.set_pose_target(target_pose, self.end_effector_link)
              self.arm.go(wait=True)
          # 回到home姿态
          def go_named(self, place = 'home'):
              # 移动至命名的pose,允许用户指定一个预定义的姿态或位置目标
              self.arm.set_named_target(place)
          @property
          # 返回当前坐标
          def poseNow(self):
              return self.arm.get_current_pose(self.end_effector_link)
          # 当前位置的基础上进行相对移动
          def move_by_posNow(self, dx, dy, dz):
              # 在当前坐标的基础上设置目标
              pos = self.poseNow.pose
              pos.position.x -= dx
              pos.position.y -= dy
              pos.position.z -= dz
              self.arm.set_pose_target(pos, self.end_effector_link)
          # 指定的关节角度来控制机械臂的移动
          def move_by_joints(self,joints):
              # 设置关节坐标
              self.arm.set_joint_value_target(joints)
              state = self.arm.go(wait=True)
              return state
          # 用于控制机械臂通过笛卡尔路径规划(即直线移动)到达指定的三维空间位置 (x, y, z)
          def move_cartesian(self, x, y, z):
              # 笛卡尔规划
              waypoints = []
              pos.position.x = x
              pos.position.y = y
              pos.position.z = z
              waypoints.append(pos)
              fraction = 0.0
              maxtries = 100
              attempts = 0
              while fraction < 1.0 and attempts < maxtries:
                  (plan, fraction) = self.arm.compute_cartesian_path (
                                          waypoints,   # waypoint poses,路点列表
                                          0.1,        # eef_step,终端步进值
                                          0.0,         # jump_threshold,跳跃阈值
                                          True)        # avoid_collisions,避障规划
                  attempts += 1
              if fraction == 1.0:
                  self.arm.execute(plan)
                  return True
              else:
                  pass
              return False
          def move_cartesian_byNow(self, x, y, z):
              # 笛卡尔规划(从当前坐标设置目标)
              waypoints = []
          #        waypoints.append(pos)
              pos.position.x -= x
              pos.position.y -= y
              pos.position.z -= z
              # pos.orientation.x = preState['down'][0]
              # pos.orientation.y = preState['down'][1]
              # pos.orientation.z = preState['down'][2]
              # pos.orientation.w = preState['down'][3]
              fraction = 0.0
              maxtries = 100
              attempts = 0
                  attempts += 1
              if fraction == 1.0:
                  return True
              else:
                  pass
              return False
          def shutDowm(self):
              # moveit关闭
              moveit_commander.roscpp_initializer.roscpp_shutdown()
              rospy.loginfo('grasp complete!!!')
      def get_rotation_matrix(q):
          # in TF, it is xyzw
          # xyzw方向转旋转矩阵
          x = q[0]
          y = q[1]
          z = q[2]
          w = q[3]
          rot = [[1-2*y*y-2*z*z, 2*x*y+2*w*z, 2*x*z-2*w*y],
                  [2*x*y-2*w*z, 1-2*x*x-2*z*z, 2*y*z+2*w*x],
                  [2*x*z+2*w*y, 2*y*z-2*w*x, 1-2*x*x-2*y*y]]
          return rot
      def get_CameraFrame_Pos(u, v, depthvalue):
          # 将像素平面的点(pixel_x, pixel_y)转换到相机坐标(u、v图像坐标,depthValue对应坐标的深度值)
          # fx fy cx cy为相机内参
          fx = 420.93942150909646
          fy = 420.93942150909646
          cx = 320
          cy = 240
          z = float(depthvalue)
          cam_x = float((u - cx) * z) / fx
          cam_y = float((v - cy) * z) / fy
          cam_z = z
          return [cam_x, cam_y, cam_z, 1]
      def get_RT_matrix(base_frame, reference_frame):
          # 获取base_frame到reference_frame旋转平移矩阵,通过tf变换获取
          listener = tf.TransformListener()
          i = 3 # 尝试3次,三次未获取到则获取失败
          while i!=0:
              try:
                  listener.waitForTransform(base_frame, reference_frame,rospy.Time.now(), rospy.Duration(3.0))
                  camera2World = listener.lookupTransform(base_frame, reference_frame, rospy.Time(0))
                  break
              except:
                  pass
              i = i - 1
          T = camera2World[0]
          R = get_rotation_matrix(camera2World[1])
          # 将其转换为一个4x4的齐次变换矩阵
          R[0].append(0)
          R[1].append(0)
          R[2].append(0)
          R.append([0.0,0.0,0.0,1.0])
          R = np.mat(R)
          return [R,T]
      def coordinate_transform(cameraFrame_pos, R, T):
          # 相机系转世界坐标系,先旋转再平移,转置操作,np.mat 函数创建一个矩阵
          worldFrame_pos = R.I * np.mat(cameraFrame_pos).T
          worldFrame_pos[0,0] = worldFrame_pos[0,0] + T[0]
          worldFrame_pos[1,0] = worldFrame_pos[1,0] + T[1]
          worldFrame_pos[2,0] = worldFrame_pos[2,0] + T[2]
          worldFrame_pos = [worldFrame_pos[0,0], worldFrame_pos[1,0], worldFrame_pos[2,0]]
          return worldFrame_pos
      findObject = False
      image = np.array(0)
      imagehOK = False
      def BoundingBoxCallBack(data):
          # yolo检测的回调函数
          global findObject, u, v, graspObject
          if not findObject:
              # 待抓取目标为空,则请求输入抓取目标
              if graspObject == '':
                  graspObject = raw_input('object detected, please input the object you want to grasp:(anode, cathode)\n')
              objectGrasp = []
              for dat in data.bounding_boxes:
                  # 遍历所有目标,种类与待抓取目标相同则保存目标中心位置
                  if graspObject == dat.Class:
                      objectGrasp.append([dat.Class, (dat.xmin + dat.xmax)/2, (dat.ymin + dat.ymax)/2])
              if objectGrasp != []:
                  # 如果待抓取目标存在,则在目标列表随机选择一个返回
                  rospy.loginfo('{} found, begin grasp!!!'.format(graspObject))
                  _, u, v = random.choice(objectGrasp)
                  findObject = True
              else:
                  rospy.loginfo('The object you want to grasp is absent!!!')
      def imageCallback(data):
          # 深度图像回调函数
          global image,imageOK
          imageOK = False
          image = CvBridge().imgmsg_to_cv2(data, data.encoding)
          imageOK = True
      # 末端向下对应的xyzw坐标
      endDown = [0.0, 0.0, 0.0, 0.0]
      def grasp_test(grasp_demo):
      if __name__ == "__main__":
          # 图像和检测框对应topic名称
          image_topic  = '/camera/image_raw'
          BoundingBox_topic = '/yolov8/BoundingBoxes'
          # 初始化ros节点
          rospy.init_node('grasp')
          # 实例化抓取控制类
          grasp_demo = graspDemo()
          # 机械臂移动到该位置
          grasp_demo.go_named('home')
          # 初始化图像系坐标及待抓取物体
          u = 320
          v = 240
          graspObject = ''
          # 订阅图像和检测框对应topic,BoundingBoxes是消息类型,定义了消息的数据结构
          rospy.Subscriber(BoundingBox_topic, BoundingBoxes, BoundingBoxCallBack, queue_size=1)
          rospy.Subscriber(image_topic, Image, imageCallback, queue_size=1)
          while not rospy.is_shutdown():
              # 如果检测到待抓取物体且获取到了图
              if findObject :
                  # 获取相机系到世界系的旋转平移矩阵
                  [R, T] = get_RT_matrix('world','camera_link')
                  print("[R, T]",[R, T])
                  u, v = int(u), int(v) # 防止检测的坐标越界
                  print("u,v",u,v)
                  # 像素坐标转相机坐标
                  cameraFrame_pos = get_CameraFrame_Pos(u, v, 0.4)
                  print(cameraFrame_pos)
                  # 相机坐标转世界坐标
                  worldFrame_pos = coordinate_transform(cameraFrame_pos, R, T)
                  print(graspObject + ' pose is: ', worldFrame_pos)
                  # 移动到抓取物体的上方
                  grasp_demo.move([worldFrame_pos[0], worldFrame_pos[1], worldFrame_pos[2]],endDown)
                  rospy.sleep(0.5) # wait for grasp
                  # 向上移动仿真防止直接移动吸到其他物体
                  grasp_demo.move_cartesian_byNow(0, 0 , -0.1) # avoid grasp other object by mistake
                  # 移动到放置位置
                  #grasp_demo.move([worldFrame_pos[0]+0.4, worldFrame_pos[1]-0.2, worldFrame_pos[2]-1.0],endDown)
                  rospy.sleep(0.5)
                  # 回到检测的位置
                  # 重置参数
                  findObject = False
                  graspObject = ''
