    一键安装ros2 foxy失败
    一键安装 ros2 foxy
    3.4k
    • 8575482678
      夜雨晨曦
      yuchenye@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
      --2022-05-30 15:32:37--  http://fishros.com/install
      --2022-05-30 15:32:37--  http://fishros.com/install/
      Length: 349 [application/octet-stream]
      Saving to: ‘fishros’
      fishros             100%[===================>]     349  --.-KB/s    in 0s
      2022-05-30 15:32:37 (71.2 MB/s) - ‘fishros’ saved [349/349]
      [sudo] password for yuchenye:
      Reading package lists... Done
      Building dependency tree
      python3-distro is already the newest version (1.4.0-1).
      python3-distro set to manually installed.
      python3-yaml is already the newest version (5.3.1-1ubuntu0.1).
      python3-yaml set to manually installed.
      You might want to run 'apt --fix-broken install' to correct these.
       python3-rosdep-modules : Depends: python3-rospkg-modules (>= 1.3.0) but it is not going to be installed
                                Depends: python3-catkin-pkg-modules (>= 0.4.0) but it is not going to be installed
                                Depends: python3-rosdistro-modules (>= 0.7.5) but it is not going to be installed
       ros-noetic-rospack : Depends: python3-catkin-pkg-modules but it is not going to be installed
       ros-noetic-rqt-gui : Depends: python3-rospkg-modules but it is not going to be installed
       ros-noetic-rqt-robot-monitor : Depends: python3-rospkg-modules but it is not going to be installed
      E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
      --2022-05-30 15:32:42--  http://fishros.com/install/install1s/tools/base.py
      Length: 39555 (39K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]  38.63K  --.-KB/s    in 0.03s
      2022-05-30 15:32:42 (1.12 MB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [39555/39555]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2022-05-30 15:34:01--  http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 12296 (12K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_install_ros.py    100%[==============================================================================================>]  12.01K  --.-KB/s    in 0.001s
      2022-05-30 15:34:01 (17.6 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [12296/12296]
      --2022-05-30 15:34:01--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2307 (2.3K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_config_rosenv.py  100%[==============================================================================================>]   2.25K  --.-KB/s    in 0s
      2022-05-30 15:34:02 (9.61 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
      --2022-05-30 15:34:02--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 9321 (9.1K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_config_system_sou 100%[==============================================================================================>]   9.10K  --.-KB/s    in 0.002s
      2022-05-30 15:34:02 (5.57 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [9321/9321]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键更换系统源,本工具由作者小鱼提供
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[amd64:focal],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [-]Result:success                            --upgradable' to see them. amd64 c-n-f Metadata [512 B] B]
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Get:1 https://mirrors.ustc.edu.cn/ubuntu focal InRelease [265 kB]', 'Get:2 https://mirrors.ustc.edu.cn/ubuntu focal-updates InRelease [114 kB]', 'Get:3 https://mirrors.ustc.edu.cn/ubuntu focal-backports InRelease [108 kB]', 'Get:4 https://mirrors.ustc.edu.cn/ubuntu focal-security InRelease [114 kB]', 'Get:5 https://mirrors.ustc.edu.cn/ubuntu focal/main i386 Packages [718 kB]', 'Get:6 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 Packages [970 kB]', 'Get:7 https://mirrors.ustc.edu.cn/ubuntu focal/main Translation-en [506 kB]', 'Get:8 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 DEP-11 Metadata [494 kB]', 'Get:9 https://mirrors.ustc.edu.cn/ubuntu focal/main DEP-11 48x48 Icons [98.4 kB]', 'Get:10 https://mirrors.ustc.edu.cn/ubuntu focal/main DEP-11 64x64 Icons [163 kB]', 'Get:11 https://mirrors.ustc.edu.cn/ubuntu focal/main DEP-11 64x64@2 Icons [15.8 kB]', 'Get:12 https://mirrors.ustc.edu.cn/ubuntu focal/main amd64 c-n-f Metadata [29.5 kB]', 'Get:13 https://mirrors.ustc.edu.cn/ubuntu focal/restricted amd64 Packages [22.0 kB]', 'Get:14 https://mirrors.ustc.edu.cn/ubuntu focal/restricted i386 Packages [8,112 B]', 'Get:15 https://mirrors.ustc.edu.cn/ubuntu focal/restricted Translation-en [6,212 B]', 'Get:16 https://mirrors.ustc.edu.cn/ubuntu focal/restricted amd64 c-n-f Metadata [392 B]', 'Get:17 https://mirrors.ustc.edu.cn/ubuntu focal/universe i386 Packages [4,642 kB]', 'Get:18 https://mirrors.ustc.edu.cn/ubuntu focal/universe amd64 Packages [8,628 kB]', 'Get:19 https://mirrors.ustc.edu.cn/ubuntu focal/universe Translation-en [5,124 kB]', 'Get:20 https://mirrors.ustc.edu.cn/ubuntu focal/universe amd64 DEP-11 Metadata [3,603 kB]', 'Get:21 https://mirrors.ustc.edu.cn/ubuntu focal/universe DEP-11 48x48 Icons [3,016 kB]', 'Get:22 https://mirrors.ustc.edu.cn/ubuntu focal/universe DEP-11 64x64 Icons [7,794 kB]', 'Get:23 https://mirrors.ustc.edu.cn/ubuntu focal/universe DEP-11 64x64@2 Icons [44.3 kB]', 'Get:24 https://mirrors.ustc.edu.cn/ubuntu focal/universe amd64 c-n-f Metadata [265 kB]', 'Get:25 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse i386 Packages [74.7 kB]', 'Get:26 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse amd64 Packages [144 kB]', 'Get:27 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse Translation-en [104 kB]', 'Get:28 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse amd64 DEP-11 Metadata [48.4 kB]', 'Get:29 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse DEP-11 48x48 Icons [23.1 kB]', 'Get:30 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse DEP-11 64x64 Icons [192 kB]', 'Get:31 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse DEP-11 64x64@2 Icons [214 B]', 'Get:32 https://mirrors.ustc.edu.cn/ubuntu focal/multiverse amd64 c-n-f Metadata [9,136 B]', 'Get:33 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 Packages [1,830 kB]', 'Get:34 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main i386 Packages [659 kB]', 'Get:35 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main Translation-en [336 kB]', 'Get:36 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 DEP-11 Metadata [278 kB]', 'Get:37 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main DEP-11 48x48 Icons [60.8 kB]', 'Get:38 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main DEP-11 64x64 Icons [98.3 kB]', 'Get:39 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main DEP-11 64x64@2 Icons [29 B]', 'Get:40 https://mirrors.ustc.edu.cn/ubuntu focal-updates/main amd64 c-n-f Metadata [15.4 kB]', 'Get:41 https://mirrors.ustc.edu.cn/ubuntu focal-updates/restricted i386 Packages [24.3 kB]', 'Get:42 https://mirrors.ustc.edu.cn/ubuntu focal-updates/restricted amd64 Packages [1,008 kB]', 'Get:43 https://mirrors.ustc.edu.cn/ubuntu focal-updates/restricted Translation-en [143 kB]', 'Get:44 https://mirrors.ustc.edu.cn/ubuntu focal-updates/restricted amd64 c-n-f Metadata [520 B]', 'Get:45 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe i386 Packages [679 kB]', 'Get:46 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe amd64 Packages [924 kB]', 'Get:47 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe Translation-en [207 kB]', 'Get:48 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe amd64 DEP-11 Metadata [390 kB]', 'Get:49 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe DEP-11 48x48 Icons [257 kB]', 'Get:50 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe DEP-11 64x64 Icons [458 kB]', 'Get:51 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe DEP-11 64x64@2 Icons [29 B]', 'Get:52 https://mirrors.ustc.edu.cn/ubuntu focal-updates/universe amd64 c-n-f Metadata [20.7 kB]', 'Get:53 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse i386 Packages [8,440 B]', 'Get:54 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse amd64 Packages [24.4 kB]', 'Get:55 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse Translation-en [7,336 B]', 'Get:56 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse amd64 DEP-11 Metadata [944 B]', 'Get:57 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse DEP-11 48x48 Icons [1,867 B]', 'Get:58 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse DEP-11 64x64 Icons [2,497 B]', 'Get:59 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse DEP-11 64x64@2 Icons [29 B]', 'Get:60 https://mirrors.ustc.edu.cn/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [596 B]', 'Get:61 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main amd64 Packages [44.5 kB]', 'Get:62 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main i386 Packages [35.2 kB]', 'Get:63 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main Translation-en [10.9 kB]', 'Get:64 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main amd64 DEP-11 Metadata [7,964 B]', 'Get:65 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main DEP-11 48x48 Icons [6,974 B]', 'Get:66 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main DEP-11 64x64 Icons [10.5 kB]', 'Get:67 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main DEP-11 64x64@2 Icons [29 B]', 'Get:68 https://mirrors.ustc.edu.cn/ubuntu focal-backports/main amd64 c-n-f Metadata [980 B]', 'Get:69 https://mirrors.ustc.edu.cn/ubuntu focal-backports/restricted amd64 c-n-f Metadata [116 B]', 'Get:70 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe amd64 Packages [23.6 kB]', 'Get:71 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe i386 Packages [13.2 kB]', 'Get:72 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe Translation-en [15.9 kB]', 'Get:73 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe amd64 DEP-11 Metadata [30.8 kB]', 'Get:74 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe DEP-11 48x48 Icons [13.2 kB]', 'Get:75 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe DEP-11 64x64 Icons [22.6 kB]', 'Get:76 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe DEP-11 64x64@2 Icons [29 B]', 'Get:77 https://mirrors.ustc.edu.cn/ubuntu focal-backports/universe amd64 c-n-f Metadata [860 B]', 'Get:78 https://mirrors.ustc.edu.cn/ubuntu focal-backports/multiverse amd64 c-n-f Metadata [116 B]', 'Get:79 https://mirrors.ustc.edu.cn/ubuntu focal-security/main i386 Packages [440 kB]', 'Get:80 https://mirrors.ustc.edu.cn/ubuntu focal-security/main amd64 Packages [1,480 kB]', 'Get:81 https://mirrors.ustc.edu.cn/ubuntu focal-security/main Translation-en [255 kB]', 'Get:82 https://mirrors.ustc.edu.cn/ubuntu focal-security/main amd64 DEP-11 Metadata [40.7 kB]', 'Get:83 https://mirrors.ustc.edu.cn/ubuntu focal-security/main DEP-11 48x48 Icons [18.3 kB]', 'Get:84 https://mirrors.ustc.edu.cn/ubuntu focal-security/main DEP-11 64x64 Icons [35.5 kB]', 'Get:85 https://mirrors.ustc.edu.cn/ubuntu focal-security/main DEP-11 64x64@2 Icons [29 B]', 'Get:86 https://mirrors.ustc.edu.cn/ubuntu focal-security/main amd64 c-n-f Metadata [10.4 kB]', 'Get:87 https://mirrors.ustc.edu.cn/ubuntu focal-security/restricted i386 Packages [23.0 kB]', 'Get:88 https://mirrors.ustc.edu.cn/ubuntu focal-security/restricted amd64 Packages [938 kB]', 'Get:89 https://mirrors.ustc.edu.cn/ubuntu focal-security/restricted Translation-en [134 kB]', 'Get:90 https://mirrors.ustc.edu.cn/ubuntu focal-security/restricted amd64 c-n-f Metadata [520 B]', 'Get:91 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe amd64 Packages [703 kB]', 'Get:92 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe i386 Packages [551 kB]', 'Get:93 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe Translation-en [126 kB]', 'Get:94 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe amd64 DEP-11 Metadata [66.4 kB]', 'Get:95 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe DEP-11 48x48 Icons [33.1 kB]', 'Get:96 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe DEP-11 64x64 Icons [71.5 kB]', 'Get:97 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe DEP-11 64x64@2 Icons [29 B]', 'Get:98 https://mirrors.ustc.edu.cn/ubuntu focal-security/universe amd64 c-n-f Metadata [14.4 kB]', 'Get:99 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse i386 Packages [7,196 B]', 'Get:100 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse amd64 Packages [22.2 kB]', 'Get:101 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse Translation-en [5,376 B]', 'Get:102 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse amd64 DEP-11 Metadata [2,464 B]', 'Get:103 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse DEP-11 48x48 Icons [29 B]', 'Get:104 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse DEP-11 64x64 Icons [2,638 B]', 'Get:105 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse DEP-11 64x64@2 Icons [29 B]', 'Get:106 https://mirrors.ustc.edu.cn/ubuntu focal-security/multiverse amd64 c-n-f Metadata [512 B]', 'Fetched 50.0 MB in 7s (6,861 kB/s)', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "3 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [-]Result:success                           age retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into memory.
      [-]Result:code:100                           ython3-rospkg-modules but it is not installabletallablee
      [-]Result:success                           eplacement (dummy transitional package)
      [-]Result:code:2
      [-]Result:code:2
      导入密钥失败,开始更换导入方式并二次尝试...
      [-]Result:success                           O/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17C654
      [-]Result:success
      根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/', 'http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/', 'http://packages.ros.org/ros2/ubuntu/']
      [-]Result:success                            --upgradable' to see them. [1,042 kB] [681 kB]B]
      [-]Result:success                           tends 'ros_core' and includes other basic functionalities like tf2 and urdf..namic reconfigure, nodelets, and pluginlib.
      [1]:noetic(ROS1)
      [2]:foxy(ROS2)
      [3]:galactic(ROS2)
      [4]:rolling(ROS2)
      [0]:quit
      请输入[]内的数字以选择:2
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:foxy(ROS2)桌面版
      [2]:foxy(ROS2)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      [-]Result:success                           end for Debianfor C++ (development files)sion
      [-]Result:code:100                           ython3-rospkg-modules but it is not going to be installednstalledd
      Run CMD Task:[sudo aptitude install   ros-foxy-desktop -y]
      sudo: aptitude: command not found
      [-]Result:code:1
      Run CMD Task:[sudo apt-cache search python3-colcon-common-extensions ]
      [-]Result:success                           ackage aggregating colcon-core and common extensions.
      [-]Result:code:100                           ython3-rospkg-modules but it is not going to be installednstalleddalleded
      [-]Result:success                            for argparse (for Python 3)
      [-]Result:success                           anager abstraction tool for ROSPython 3)
      Run CMD Task:[ls /opt/ros/foxy/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
      • 8575482678
        夜雨晨曦 @小鱼
        @小鱼 感谢,已解决。解决方式记录在此:
        使用sudo apt --fix-broken install 发现部分文件包已存在目录下
        sudo -i
        获取root权限,以使用dpkg
        dpkg -i --force-overwrite /var/cache/apt/archives/python3-catkin-pkg-modules_0.5.2-1_all.deb
        dpkg -i --force-overwrite /var/cache/apt/archives/python3-rospkg-modules_1.4.0-1_all.deb
        dpkg -i --force-overwrite /var/cache/apt/archives/python3-rosdistro-modules_0.8.3-1_all.deb
        之后运行 apt --fix-broken install
          小鱼 技术大佬 @857548267
          @857548267 在 一键安装ros2 foxy失败 中说:
          试试上面这句话
          8575482678 1 条回复 最后回复 回复 引用 0
          • 8575482678
            夜雨晨曦 @小鱼
            @小鱼 您好,还是继续报错
            yuchenye@ubuntu:~$ apt --fix-broken install
            E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
            E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
            yuchenye@ubuntu:~$ sudo apt --fix-broken install
            Correcting dependencies... Done
            The following packages were automatically installed and are no longer required:
              libfprint-2-tod1 libfwupdplugin1 librospack0d linux-headers-5.8.0-50-generic
              linux-hwe-5.8-headers-5.8.0-50 linux-image-5.8.0-50-generic
              linux-modules-5.8.0-50-generic linux-modules-extra-5.8.0-50-generic
              rospack-tools
            Use 'sudo apt autoremove' to remove them.
            The following additional packages will be installed:
              python3-catkin-pkg-modules python3-rosdistro-modules python3-rospkg-modules
            The following NEW packages will be installed:
            0 upgraded, 3 newly installed, 0 to remove and 6 not upgraded.
            1040 not fully installed or removed.
            Need to get 0 B/99.1 kB of archives.
            After this operation, 656 kB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            (Reading database ... 305867 files and directories currently installed.)
            Preparing to unpack .../python3-catkin-pkg-modules_0.5.2-1_all.deb ...
            Unpacking python3-catkin-pkg-modules (0.5.2-1) ...
            dpkg: error processing archive /var/cache/apt/archives/python3-catkin-pkg-module
            s_0.5.2-1_all.deb (--unpack):
             trying to overwrite '/usr/lib/python3/dist-packages/catkin_pkg/__init__.py', wh
            ich is also in package python3-catkin-pkg 0.4.16-1
            Preparing to unpack .../python3-rospkg-modules_1.4.0-1_all.deb ...
            Unpacking python3-rospkg-modules (1.4.0-1) ...
            dpkg: error processing archive /var/cache/apt/archives/python3-rospkg-modules_1.
            4.0-1_all.deb (--unpack):
             trying to overwrite '/usr/lib/python3/dist-packages/rospkg/__init__.py', which
            is also in package python3-rospkg 1.2.3-1
            Preparing to unpack .../python3-rosdistro-modules_0.8.3-1_all.deb ...
            Unpacking python3-rosdistro-modules (0.8.3-1) ...
            dpkg: error processing archive /var/cache/apt/archives/python3-rosdistro-modules
            _0.8.3-1_all.deb (--unpack):
             trying to overwrite '/usr/lib/python3/dist-packages/rosdistro/__init__.py', whi
            ch is also in package python3-rosdistro 0.8.0-1
            Errors were encountered while processing:
            E: Sub-process /usr/bin/dpkg returned an error code (1)
              小鱼 技术大佬 @857548267
              @857548267 记得加sudo,提示没权限
              • 8575482678
                夜雨晨曦 @小鱼
                @小鱼 您好,在原代码第4行使用了sudo获得了权限。
                现在个人初步猜测以下几点:
                1是问题出在曾经安装ros被打断
                2是python3相关无法安装
                感谢
                  小鱼 技术大佬 @857548267
                  @857548267 sudo apt --fix-broken install
                  接着再用一键安装试试
                  • 8575482678
                    夜雨晨曦 @小鱼
                    sudo -i
                    获取root权限,以使用dpkg
                      小鱼 技术大佬 @857548267
                      @857548267 好滴,下次注意代码格式哈~
                      1. 不要截图,要复制粘贴,一定要代码块包裹
                      • 小鱼小 小鱼 将这个主题转为问答主题,在
                      • 小鱼小 小鱼 将这个主题标记为已解决,在
