    7.5.3rosidl_generate_interfaces报错
    cmake报错 接口报错
    • 4
      开心
      构建空间报错代码:
      tingbo@DESKTOP-NHH5E05:~/chapt7/chapt7_ws$ colcon build
      Starting >>> autopatrol_interfaces
      Starting >>> autopatrol_robot
      Starting >>> fishbot_application
      Starting >>> fishbot_navigation2
      Finished <<< fishbot_description [0.53s]
      Finished <<< fishbot_navigation2 [0.53s]
      Finished <<< fishbot_application [1.02s]
      Finished <<< autopatrol_robot [1.04s]
      --- stderr: autopatrol_interfaces
      CMake Error at CMakeLists.txt:10 (find_package):
        By not providing "Findrosidl_generate_interfaces.cmake" in
        CMAKE_MODULE_PATH this project has asked CMake to find a package
        configuration file provided by "rosidl_generate_interfaces", but CMake did
        not find one.
        "rosidl_generate_interfaces" with any of the following names:
          rosidl_generate_interfacesConfig.cmake
          rosidl_generate_interfaces-config.cmake
        Add the installation prefix of "rosidl_generate_interfaces" to
        CMAKE_PREFIX_PATH or set "rosidl_generate_interfaces_DIR" to a directory
        containing one of the above files.  If "rosidl_generate_interfaces"
        installed.
      Failed   <<< autopatrol_interfaces [1.40s, exited with code 1]
      Summary: 4 packages finished [1.65s]
        1 package failed: autopatrol_interfaces
        1 package had stderr output: autopatrol_interfaces
      SpeachText.srv代码:
      string text
      bool result
      CmakeLists.txt代码:
      project(autopatrol_interfaces)
      endif()
      # find dependencies
      find_package(rosidl_generate_interfaces REQUIRED)
      if(BUILD_TESTING)
      endif()
        "srv/SpeachText.srv"
      ament_package()
      package.xml代码:
      <?xml version="1.0"?>
      <package format="3">
        <name>autopatrol_interfaces</name>
        <version>0.0.0</version>
        <maintainer email="tingbo01@qq.com">tingbo</maintainer>
        <license>Apache-2.0</license>
        <depend>rosidl_generate_interfaces</depend>
        <export>
        </export>
      </package>
      • C
        ControlStudy
        你的问题解决了吗?
