    8.2.2代码报错:没有参数匹配的重载函数“nav2_util"
    参数匹配 重载函数
    • 4
      开心
      代码报错问题:
      没有与参数列表匹配的 重载函数 "nav2_util::declare_parameter_if_not_declared" 实例
      空间构建错误:
      #ifndef NAV2_CUSTOM_PLANNER__NAV2_CUSTOM_PLANNER_HPP_
      #define NAV2_CUSTOM_PLANNER__NAV2_CUSTOM_PLANNER_HPP_
      #include <memory>
      #include <string>
      #include "geometry_msgs/msg/point.hpp"
      #include "geometry_msgs/msg/pose_stamped.hpp"
      #include "rclcpp/rclcpp.hpp"
      #include "nav2_core/global_planner.hpp"
      #include "nav2_costmap_2d/costmap_2d_ros.hpp"
      #include "nav2_util/lifecycle_node.hpp"
      #include "nav2_util/robot_utils.hpp"
      #include "nav_msgs/msg/path.hpp"
      namespace nav2_custom_planner {
          //自定义导航规划器类
          class CustomPlanner : public nav2_core::GlobalPlanner{
              public:
                  CustomPlanner() = default;
                  ~CustomPlanner() = default;
                  //插件配置方法
                  void configure(
                      const rclcpp_lifecycle::LifecycleNode::WeakPtr &parent, std::string name,
                      std::shared_ptr<tf2_ros::Buffer> tf,
                      std::shared_ptr<nav2_costmap_2d::Costmap2DROS> costmap_ros) override;
                  //插件清理的方法
                  void cleanup() override;
                  //插件激活的方法
                  void activate() override;
                  //插件停用的方法
                  void deactivate() override;
                  //为给定的起始和目标位姿创建路径的方法
                  nav_msgs::msg::Path
                  createPlan(const geometry_msgs::msg::PoseStamped &start,
                             const geometry_msgs::msg::PoseStamped &goal) override;
              private:
                  //坐标变换缓存指针,可用于查询坐标关系
                  std::shared_ptr<tf2_ros::Buffer> tf_;
                  //节点指针
                  nav2_util::LifecycleNode::SharedPtr node_;
                  //全局代价地图
                  nav2_costmap_2d::Costmap2D *costmap_;
                  //全局代价地图的坐标系
                  std::string global_frame_, name_;
                  //插值分辨率
                  double interpolation_resolution_;
      } // namespace nav2_custom_planner
      #endif // NAV2_CUSTOM_PLANNER__NAV2_CUSTOM_PLANNER_HPP_
      nav2_custom_planner.cpp代码:
      #include "nav2_util/node_utils.hpp"
      #include <cmath>
      #include <memory>
      #include <string>
      #include "nav2_core/exceptions.hpp"
      #include "nav2_custom_planner/nav2_custom_planner.hpp"
      namespace nav2_custom_planner{
          void CustomPlanner::configure(
              std::shared_ptr<nav2_costmap_2d::Costmap2DROS> costmap_ros) {
                  tf_ = tf;
                  node_ = parent.lock();
                  name_ = name;
                  costmap_ = costmap_ros->getCostmap();
                  global_frame_ = costmap_ros->getGlobalFrameID();
                  //参数初始化
                  nav2_util::declare_parameter_if_not_declared(
                      node_, name_, + ".interpolation_resolution",
                      rclcpp::ParameterValue(0.1));
                  node_->get_parameter(name_ + ".interpolation_resolution",
                                      interpolation_resolution_);
          void CustomPlanner::cleanup() {
              RCLCPP_INFO(node_->get_logger(), "正在清理类型为CustomPlanner的插件 %s", name_.c_str());
          void CustomPlanner::activate() {
              RCLCPP_INFO(node_->get_logger(), "正在激活类型为CustomPlanner的插件 %s", name_.c_str());
          void CustomPlanner::deactivate() {
              RCLCPP_INFO(node_->get_logger(), "正在停用类型为CustomPlanner的插件 %s", name_.c_str());
          nav_msgs::msg::Path
          CustomPlanner::createPlan(const geometry_msgs::msg::PoseStamped &start,
                             const geometry_msgs::msg::PoseStamped &goal) {
                              nav_msgs::msg::Path global_path;
                              //进行规划
                              return global_path;
      #include "pluginlib/class_list_macros.hpp"
      PLUGINLIB_EXPORT_CLASS(nav2_custom_planner::CustomPlanner,
                              nav2_core::GlobalPlanner);
      nav2_custom_planner.hpp代码:
      #include <memory>
      #include <string>
          //自定义导航规划器类
              public:
                  //插件配置方法
                  void configure(
                  //插件清理的方法
                  //插件激活的方法
                  //插件停用的方法
                  nav_msgs::msg::Path
              private:
                  //节点指针
                  //全局代价地图
                  //全局代价地图的坐标系
                  //插值分辨率
      4 1 条回复 最后回复 回复 引用 0
      • 4
        开心 @43996173
        @43996173 空间构建错误:
        tingbo@DESKTOP-NHH5E05:~/chapt8/chapt8_ws$ colcon build
        Starting >>> autopatrol_interfaces
        Starting >>> autopatrol_robot
        Starting >>> fishbot_application
        Starting >>> fishbot_navigation2
        Starting >>> nav2_custom_planner
        Finished <<< fishbot_description [2.74s]
        Finished <<< fishbot_navigation2 [2.75s]
        Finished <<< autopatrol_interfaces [5.11s]
        Finished <<< fishbot_application [8.58s]
        Finished <<< autopatrol_robot [8.63s]
        --- stderr: nav2_custom_planner
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp: In member function ‘virtual void nav2_custom_planner::CustomPlanner::configure(const WeakPtr&, std::string, std::shared_ptr<tf2_ros::Buffer>, std::shared_ptr<nav2_costmap_2d::Costmap2DROS>)’:
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:19:57: error: no matching function for call to ‘declare_parameter_if_not_declared(rclcpp_lifecycle::LifecycleNode::SharedPtr&, std::string&, const char*, rclcpp::ParameterValue)’
           19 |             nav2_util::declare_parameter_if_not_declared(
           20 |                 node_, name_, + ".interpolation_resolution",
           21 |                 rclcpp::ParameterValue(0.1));
        In file included from /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:1:
        /opt/ros/humble/include/nav2_util/node_utils.hpp:92:6: note: candidate: ‘template<class NodeT> void nav2_util::declare_parameter_if_not_declared(NodeT, const string&, const rclcpp::ParameterValue&, const ParameterDescriptor&)’
           92 | void declare_parameter_if_not_declared(
        /opt/ros/humble/include/nav2_util/node_utils.hpp:92:6: note:   template argument deduction/substitution failed:
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:20:31: note:   cannot convert ‘+(const char*)".interpolation_resolution"’ (type ‘const char*’) to type ‘const rclcpp::ParameterValue&’
        /opt/ros/humble/include/nav2_util/node_utils.hpp:113:6: note: candidate: ‘template<class NodeT> void nav2_util::declare_parameter_if_not_declared(NodeT, const string&, const rclcpp::ParameterType&, const ParameterDescriptor&)’
          113 | void declare_parameter_if_not_declared(
        /opt/ros/humble/include/nav2_util/node_utils.hpp:113:6: note:   template argument deduction/substitution failed:
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:20:31: note:   cannot convert ‘+(const char*)".interpolation_resolution"’ (type ‘const char*’) to type ‘const rclcpp::ParameterType&’
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp: In member function ‘virtual nav_msgs::msg::Path nav2_custom_planner::CustomPlanner::createPlan(const PoseStamped&, const PoseStamped&)’:
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:40:70: warning: unused parameter ‘start’ [-Wunused-parameter]
           40 |     CustomPlanner::createPlan(const geometry_msgs::msg::PoseStamped &start,
        /home/tingbo/chapt8/chapt8_ws/src/nav2_custom_planner/src/nav2_custom_planner.cpp:41:63: warning: unused parameter ‘goal’ [-Wunused-parameter]
           41 |                        const geometry_msgs::msg::PoseStamped &goal) {
        gmake[2]: *** [CMakeFiles/nav2_custom_planner_Plugin.dir/build.make:76:CMakeFiles/nav2_custom_planner_Plugin.dir/src/nav2_custom_planner.cpp.o] 错误 1
        gmake[1]: *** [CMakeFiles/Makefile2:137:CMakeFiles/nav2_custom_planner_Plugin.dir/all] 错误 2
        Failed   <<< nav2_custom_planner [25.2s, exited with code 2]
        Summary: 5 packages finished [31.0s]
          1 package failed: nav2_custom_planner
          1 package had stderr output: nav2_custom_planner
