    Python调用'/gazebo/set_link_state'发生AttributeError
    仿真
    gazebo setlinkstate gazebo9
    1.8k
      Landson Housebigger
      **## 标题:**Python代码调用get_link_state和set_link_state
      **### 背景:**在ros-melodic-gazebo9仿真环境里有一个运动中的机器人,为了使它在base_link运动过程中其末端link仍然保持在当前世界位置并相对世界坐标静止,我用了下述Python代码调用get_link_state和set_link_state,首先获取当前的位姿,然后循环执行set link state的服务。
      **### 问题描述:**以下是完整的脚本:
      #!/usr/bin/env python
      import rospy
      from gazebo_msgs.srv import GetLinkState, GetLinkStateRequest, SetLinkState, SetLinkStateRequest
      from geometry_msgs.msg import Pose, Point, Quaternion
      from std_msgs.msg import Header
      def get_current_pose(link_name):
          获取指定链接的当前位姿。
          :param link_name: 要获取位姿的链接名称
          :return: 当前位姿的Pose对象
          rospy.wait_for_service('/gazebo/get_link_state')
          try:
              get_link_state_service = rospy.ServiceProxy('/gazebo/get_link_state', GetLinkState)
              get_link_state_request = GetLinkStateRequest()
              get_link_state_request.link_name = link_name
              get_link_state_request.reference_frame = 'world'
              response = get_link_state_service(get_link_state_request)
              return response.pose
          except rospy.ServiceException as e:
              print("获取链接状态服务调用失败: %s"%e)
      def set_link_state(link_name, pose):
          设置链接状态,使指定的链接相对于世界保持静止。
          :param link_name: 要设置状态的链接名称
          :param pose: 设置的位姿,这里我们将位置和方向都设置为0
          rospy.wait_for_service('/gazebo/set_link_state')
          try:
              set_link_state_service = rospy.ServiceProxy('/gazebo/set_link_state', SetLinkState)
              set_link_state_request = SetLinkStateRequest()
              # 设置请求头信息
              set_link_state_request.header = Header()
              set_link_state_request.header.stamp = rospy.Time.now()
              set_link_state_request.header.frame_id = 'world'
              # 设置链接名称
              set_link_state_request.link_name = link_name
              # 设置目标位姿
              set_link_state_request.pose = pose
              # 设置角速度和线速度为0
              set_link_state_request.twist.linear.x = 0
              set_link_state_request.twist.linear.y = 0
              set_link_state_request.twist.linear.z = 0
              set_link_state_request.twist.angular.x = 0
              set_link_state_request.twist.angular.y = 0
              set_link_state_request.twist.angular.z = 0
              # 发送请求并等待响应
              response = set_link_state_service(set_link_state_request)
              return response.success
              print("设置链接状态服务调用失败: %s"%e)
      if __name__ == '__main__':
          # 初始化ROS节点
          rospy.init_node('keep_link_static_example')
          # 设置要保持静止的链接名称
          link_name = 'mobile_link'  # 这里替换为目标链接名称
          rate = rospy.Rate(10)  # 设置循环频率为10Hz
          while not rospy.is_shutdown():
              # 获取当前位姿
              current_pose = get_current_pose(link_name)
              if current_pose:
                  # 创建一个Pose消息,将位置和方向都设置为当前值
                  pose = Pose()
                  pose.position = current_pose.position
                  pose.orientation = current_pose.orientation
                  # 调用函数设置链接状态
                  success = set_link_state(link_name, pose)
                  # 打印结果
                  if success:
                      print("链接 '%s' 设置为相对于世界静止成功。" % link_name)
                  else:
                      print("链接 '%s' 设置为相对于世界静止失败。" % link_name)
              else:
                  print("无法获取链接 '%s' 的当前位姿。" % link_name)
              rate.sleep()  # 根据设定的循环频率休眠
      附英文版
      import rospy
          Get the current pose of the specified link.
          :param link_name: The name of the link to get the pose for
          :return: The current pose of the link as a Pose object
          try:
              print("Failed to call get link state service: %s"%e)
          Set the state of the specified link to keep it static relative to the world.
          :param link_name: The name of the link to set the state for
          :param pose: The desired pose, here we set all position and orientation components to 0
          try:
              # Set request header information
              # Set the link name
              # Set the target pose
              # Set the angular and linear velocities to 0
              # Send the request and wait for the response
              print("Failed to call set link state service: %s"%e)
          # Initialize the ROS node
          # Set the link name to keep it static
          link_name = 'mobile_link'  # Replace with the name of the link  intended to be static
          rate = rospy.Rate(10)  # Set the loop frequency to 10Hz
              # Get the current pose of the link
              if current_pose:
                  # Create a Pose message with all position and orientation components set to the current values
                  pose = Pose()
                  # Call the function to set the link state
                  # Print the result
                  if success:
                      print("Link '%s' set to static relative to the world successfully." % link_name)
                  else:
                      print("Failed to set link '%s' to static relative to the world." % link_name)
              else:
                  print("Could not get the current pose of link '%s'." % link_name)
              rate.sleep()  # Sleep based on the set loop frequency
      但在运行中出现许多类似的报错,经过多次反复修改依然无果,在此请教各位。报错举例(截取关键行):
      AttributeError: 'SetLinkStateRequest' object has no attribute 'link_name'
      AttributeError: 'SetLinkStateRequest' object has no attribute 'header'
      AttributeError: 'GetLinkStateResponse' object has no attribute 'position'
      AttributeError: 'GetLinkStateResponse' object has no attribute 'pose'
      ### 具体细节和上下文:
      完整报错举例如下:
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 73, in <module>
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 22, in get_current_pose
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 77, in <module>
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 81, in <module>
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 39, in set_link_state
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 82, in <module>
        File "/home/hyh/catkin_ws/src/bigmama0225_py/scripts/fix_link_pose0502.py", line 45, in set_link_state
      都是致命报错,但我还是觉得该思路是最有希望的道路,因为之前试着用Python调用set_model_state能成功实现让机器人整体模型frame悬在空中(gravity=true条件下),下面附上调set_model_state服务的代码:
      #coding=utf-8
      from gazebo_msgs.srv import GetModelState, SetModelState
      import rospy
      from gazebo_msgs.msg import ModelState
      from gazebo_msgs.srv import *
      # Initialize ROS node
      rospy.init_node('set_model_state_fixed')
      # Wait for Gazebo services to start
      rospy.wait_for_service('/gazebo/get_model_state')
      rospy.wait_for_service('/gazebo/set_model_state')
      # Create GetModelState service proxy
      get_model_state_proxy = rospy.ServiceProxy('/gazebo/get_model_state', GetModelState)
      # Create SetModelState service proxy
      set_model_state_proxy = rospy.ServiceProxy('/gazebo/set_model_state', SetModelState)
      # Get the current state of the model
      model_name = 'robot'  # Replace with your model name
      reference_frame= 'world'
      current_state = get_model_state_proxy(model_name,reference_frame)
      # Set the new model state to keep the model fixed in its current position
      model_state = ModelState()
      model_state.model_name = model_name
      model_state.pose = current_state.pose  # Keep the current position
      # Set the linear and angular velocities of the model to zero
      #model_state.twist = Twist(linear=Vector3(x=0.0, y=0.0, z=0.0), angular=Vector3(x=0.0, y=0.0, z=0.0))
      model_state.twist.linear.x = 0.0
      model_state.twist.linear.y = 0.0
      model_state.twist.linear.z = 0.0
      model_state.twist.angular.x = 0.0
      model_state.twist.angular.y = 0.0
      model_state.twist.angular.z = 0.0
      model_state.reference_frame = 'world'
      # Call the SetModelState service to set the model state
      set_model_state_proxy(model_state)
      # Output result
      print("Model state set successfully, model is now fixed in its current position.")
      # To ensure that the model stays fixed in its current position in future updates, we need to continuously call the SetModelState service
      # This can be done using a loop or other logic based on your specific requirements
          rospy.sleep(0.01)  # Sleep for 0.01 second, adjust frequency as needed
      ### 尝试过的解决方法:
      代码部分试着删过报错中提到的各个参量,结果参量全删完了还用个毛。然后仿真部分为了让特定的link固定在管壁上试过(ros-melodic环境下)apply_body_wrench,grasp_fix_plugin,摩擦mu1mu2给到100了还是会滑移,也试过换Ubuntu22.04+RosHumble+gazebo11环境里用 apply_link_force, ros2_grasping(https://github.com/IFRA-Cranfield/ros2_RobotSimulation/tree/foxy/ros2_grasping),ros2_LinkAttacher(https://github.com/IFRA-Cranfield/IFRA_LinkAttacher),都是只能在静态时稳定,base_link那端一抬起来整个模型就飞掉最后坍缩到世界原点处。
      最后还是回到ROS-melodic里面舒服点,我这VM17的虚拟机跑ros-humble跑的提心吊胆的,时不时就给你崩一下子真受不了。在座的各位前辈大神有没有用过set_link_state服务,救救我谢谢了。
      3 2 条回复 最后回复 回复 引用 0
        Landson Housebigger @3436845452
        @3436845452 bc737c61-db1f-46fb-8b2e-3688f2dbf1b8-image.png 问题里提到的robot长这个样,想人为固定住末端mobile_link(黄色),然后通过相对运动把base_link(绿色)抬起来翻过去。
          @3436845452 终端输入 rostopic list
          返回里包含有/gazebo/set_link_state, 完整返回字段如下:
          /arm_position_controller/command
          /arm_position_controller/follow_joint_trajectory/cancel
          /arm_position_controller/follow_joint_trajectory/feedback
          /arm_position_controller/follow_joint_trajectory/goal
          /arm_position_controller/follow_joint_trajectory/result
          /arm_position_controller/follow_joint_trajectory/status
          /arm_position_controller/state
          /attached_collision_object
          /clock
          /collision_object
          /execute_trajectory/cancel
          /execute_trajectory/feedback
          /execute_trajectory/goal
          /execute_trajectory/result
          /execute_trajectory/status
          /gazebo/link_states
          /gazebo/model_states
          /gazebo/parameter_descriptions
          /gazebo/parameter_updates
          /joint_states
          /move_group/cancel
          /move_group/display_contacts
          /move_group/display_cost_sources
          /move_group/display_grasp_markers
          /move_group/display_planned_path
          /move_group/feedback
          /move_group/goal
          /move_group/monitored_planning_scene
          /move_group/motion_plan_request
          /move_group/ompl/parameter_descriptions
          /move_group/ompl/parameter_updates
          /move_group/plan_execution/parameter_descriptions
          /move_group/plan_execution/parameter_updates
          /move_group/planning_scene_monitor/parameter_descriptions
          /move_group/planning_scene_monitor/parameter_updates
          /move_group/result
          /move_group/sense_for_plan/parameter_descriptions
          /move_group/sense_for_plan/parameter_updates
          /move_group/status
          /move_group/trajectory_execution/parameter_descriptions
          /move_group/trajectory_execution/parameter_updates
          /pickup/cancel
          /pickup/feedback
          /pickup/goal
          /pickup/result
          /pickup/status
          /place/cancel
          /place/feedback
          /place/goal
          /place/result
          /place/status
          /planning_scene
          /planning_scene_world
          /recognized_object_array
          /rosout
          /rosout_agg
          /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/feedback
          /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/update
          /rviz_moveit_motion_planning_display/robot_interaction_interactive_marker_topic/update_full
          /rviz_ubuntu_38423_7706691175209945188/motionplanning_planning_scene_monitor/parameter_descriptions
          /rviz_ubuntu_38423_7706691175209945188/motionplanning_planning_scene_monitor/parameter_updates
          /tf
          /tf_static
          /trajectory_execution_event
          3 1 条回复 最后回复 回复 引用 0
            @3436845452 终端单纯命令调用rosservice call gazebo/get_link_state '{link_name: Link_3}'可以正常返回
            link_state:
              link_name: "Link_3"
              pose:
                position:
                  x: -0.0169728441434
                  y: -0.239294662543
                  z: 1.27101571602
                orientation:
                  x: 0.506675069487
                  y: -0.506605807831
                  z: 0.493296103713
                  w: -0.493244243244
              twist:
                linear:
                  x: 0.00139357024937
                  y: 0.000851167082131
                  z: -0.00139001604216
                angular:
                  x: -0.00435862833302
                  y: 0.00725633894658
                  z: 6.4154873921e-05
              reference_frame: ''
            success: True
            status_message: "GetLinkState: got state"
              Landson Housebigger
              通宵跑通了,下面是改好的两款,一个是get一次然后循环set,第二个是循环get and set:
              #coding=utf-8
              import rospy
              import geometry_msgs.msg
              from gazebo_msgs.msg import LinkState
              from geometry_msgs.msg import Pose, Point, Quaternion, Twist
              def get_current_state(link_name):
                  try:
                      return response
              def set_link_state(link_name, poseinput):
                  try:
                      # Set the link name
                      set_link_state_request.link_state.link_name = link_name
                      set_link_state_request.link_state.reference_frame = 'world'
                      set_link_state_request.link_state.pose = poseinput
                      set_link_state_request.link_state.twist = geometry_msgs.msg.Twist(linear= geometry_msgs.msg.Vector3( x = 0, y = 0, z = 0), angular = geometry_msgs.msg.Vector3( x = 0, y = 0, z = 0))
                      #set_link_state_request.twist.linear.x = 0
                      #set_link_state_request.twist.linear.y = 0
                      #set_link_state_request.twist.linear.z = 0
                      #set_link_state_request.twist.angular.x = 0
                      #set_link_state_request.twist.angular.y = 0
                      #set_link_state_request.twist.angular.z = 0
                      result = set_link_state_service(set_link_state_request)
                      return result
                  link_name = 'Link_3'  # Replace with the name of the link you want to keep static
                  current_state = get_current_state(link_name)
                  poseoutput = Pose()
                  poseoutput.position.x = current_state.link_state.pose.position.x
                  poseoutput.position.y = current_state.link_state.pose.position.y
                  poseoutput.position.z = current_state.link_state.pose.position.z
                  poseoutput.orientation.w = current_state.link_state.pose.orientation.w
                  poseoutput.orientation.x = current_state.link_state.pose.orientation.x
                  poseoutput.orientation.y = current_state.link_state.pose.orientation.y
                  poseoutput.orientation.z = current_state.link_state.pose.orientation.z
                  rate = rospy.Rate(50)  # Set the loop frequency to 50Hz
                      if current_state:
                          success = set_link_state(link_name, poseoutput)
                          # Print the result
                          if success:
                          else:
                      else:
              第二个:
              #coding=utf-8
              from gazebo_msgs.srv import GetLinkState, SetLinkState
              import rospy
              rospy.init_node('set_link_state_fixed')
              # Create GetLinkState service proxy
              get_link_state_proxy = rospy.ServiceProxy('/gazebo/get_link_state', GetLinkState)
              # Create SetLinkState service proxy
              set_link_state_proxy = rospy.ServiceProxy('/gazebo/set_link_state', SetLinkState)
              # Get the current state of the link
              link_name = 'Link_3'  # Replace with your link name
              current_state = get_link_state_proxy(link_name,reference_frame)
              # Set the new link state to keep the link fixed in its current position
              link_state = LinkState()
              link_state.pose = current_state.link_state.pose  # Keep the current position
              # Set the linear and angular velocities of the link to zero
              #link_state.twist = Twist(linear=Vector3(x=0.0, y=0.0, z=0.0), angular=Vector3(x=0.0, y=0.0, z=0.0))
              link_state.twist.linear.x = 0.0
              link_state.twist.linear.y = 0.0
              link_state.twist.linear.z = 0.0
              link_state.twist.angular.x = 0.0
              link_state.twist.angular.y = 0.0
              link_state.twist.angular.z = 0.0
              # Call the SetlinkState service to set the link state
              set_link_state_proxy(link_state)
              # Output result
              print("link state set successfully, link is now fixed in its current position.")
              # To ensure that the link stays fixed in its current position in future updates, we need to continuously call the SetlinkState service
                  rospy.sleep(0.002)  # Sleep for 0.002 second, adjust frequency as needed
