    1.命名空间问题;2.在RViz中不加载模型图像
    ros2机器人 ros2编译报错 缺少依赖
      本来是生成两个模型的,只生成了一个模型的关节坐标轴
      代码如下:
      import os
      from ament_index_python import get_package_share_path
      from launch.substitutions import LaunchConfiguration, Command
          # 获取包路径
          myarm_m750_description_pkg = FindPackageShare('myarm_m750').find('myarm_m750')
          # myarm_c650_description_pkg = FindPackageShare('myarm_c650').find('myarm_c650')
          mycobot_description_pkg = FindPackageShare('mycobot_description').find('mycobot_description')
          # 定义 URDF 文件路径
          urdf_m750 = os.path.join(mycobot_description_pkg, 'urdf','myarm_m750', 'myarm_m750.urdf.xacro')
          urdf_c650 = os.path.join(mycobot_description_pkg, 'urdf','myarm_c650', 'myarm_c650.urdf.xacro')
          # 定义 RViz 配置文件路径
          rviz_config_file = os.path.join(myarm_m750_description_pkg, 'config', 'myarm_m750_with_myarm_c650.rviz')
          ns1_arg = LaunchConfiguration('ns1')
          ns2_arg = LaunchConfiguration('ns2')
          return LaunchDescription([
              # 定义是否使用仿真时间参数
              DeclareLaunchArgument('use_sim_time', default_value='false', description='Use simulation (Gazebo) clock if true'),
              # myarm_m750 的 robot_state_publisher 节点
              Node(
                  namespace='myarm_m750',
                  parameters=[{
                      'use_sim_time': LaunchConfiguration('use_sim_time'),
                      'robot_description': Command(['xacro ', urdf_m750])
                  output='screen',
              # myarm_m750 的 joint_state_publisher_gui 节点
              Node(
                  package='joint_state_publisher_gui',
                  executable='joint_state_publisher_gui',
                  parameters=[{'use_sim_time': LaunchConfiguration('use_sim_time')}],
                  output='screen',
              # myarm_c650 的 robot_state_publisher 节点
              Node(
                  namespace='myarm_c650',
                  parameters=[{
                      'robot_description': Command(['xacro ', urdf_c650])
                  output='screen',
              # myarm_c650 的 joint_state_publisher_gui 节点
              Node(
                  output='screen',
              # RViz 节点
              Node(
                  package='rviz2',
                  executable='rviz2',
                  name='rviz2',
                  output='screen',
                  arguments=['-d', rviz_config_file],
              # 静态 TF 发布节点
                  'ns1',
                  default_value='myarm_m750',
                  description='Namespace 1'
                  'ns2',
                  default_value='myarm_c650',
                  description='Namespace 2'
              # Transform for ns2
              Node(
                  package='tf2_ros',
                  executable='static_transform_publisher',
                  name='static_transform_publisher1_ns2',
                  output='screen',
                  arguments=['0', '-0.5', '0', '0', '0', '0', '/map', [ns2_arg, '/base']]
              # Transform for ns1
              Node(
                  package='tf2_ros',
                  name='static_transform_publisher1_ns1',
                  output='screen',
                  arguments=['0', '0.5', '0', '0', '0', '0', '/map', [ns1_arg, '/base']]
      终端显示信息为下图:
