    关于配置助手运动控制板上传端口写死成/dev/ttyUSB0的bug及解决方法
    bug 端口错误
      Ryan🎸
      将esp_helper.py的第71行代码进行修改,将/dev/ttyUSB0修改为{serial_port}
      修改前
          def write_flash(self, serial_port, baud_rate, chip, firmware_image,cwd=None):
              try:
                  if not cwd:
                      cwd = os.environ['FISHBOT_CURRENT_DIR']
                  def update_log(log): self.logger(log)
                  self.logger("[提示]开始烧录固件...")
                  self.cmd_task = CmdTask()
                  esptool = select_esptool()
                  cmd = f"{esptool} -p /dev/ttyUSB0 -b {baud_rate} --before default_reset --after hard_reset --chip {chip} write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x00 {firmware_image}"
                  print('----------------------------------------------')
                  print(cmd)
                  self.cmd_task.run(cmd, cwd=cwd)
                  self.cmd_task.getlog(update_log)
                  if self.cmd_task.is_finish() == 0:
                      # self.logger("[提示]固件写入完成!")
                      return True
                  else:
                      # self.logger("[错误]固件写入失败,请检查日志或重试。。。")
                      return False
              except Exception as e:
                  print(e)
                  return False
      修改后
              try:
                  if not cwd:
                  cmd = f"{esptool} -p {serial_port} -b {baud_rate} --before default_reset --after hard_reset --chip {chip} write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x00 {firmware_image}"
                  print(cmd)
                      return True
                  else:
                      return False
                  print(e)
                  return False
        小鱼 技术大佬 @1006076811
        @1006076811 ok
