    wsl2一键安装ros2,显示安装成功后 运行demo报错
    一键安装 ros2一键安装 ros2-humble
      快快乐乐毕业
      root@LAPTOP-T519TJGF:~# wget http://fishros.com/install -O fishros && . fishros
      --2024-06-12 22:10:20-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2024-06-12 22:10:20-- http://fishros.com/install/
      Length: 579 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[====================================================>] 579 --.-KB/s in 0s
      2024-06-12 22:10:20 (145 MB/s) - ‘fishros’ saved [579/579]
      Reading package lists... Done
      sudo is already the newest version (1.9.9-1ubuntu2.4).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      python3-distro is already the newest version (1.7.0-1).
      python3-yaml is already the newest version (5.4.1-1ubuntu1).
      --2024-06-12 22:10:21-- http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 44650 (44K) [application/octet-stream]
      /tmp/fishinstall/tools/base.py 100%[====================================================>] 43.60K --.-KB/s in 0.07s
      2024-06-12 22:10:21 (593 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [44650/44650]
      [-]Result:success
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [14]:一键安装:科学上网代理工具
      [15]:一键安装:QQ for Linux
      配置工具:
      [13]:一键配置:python国内源
      请输入[]内的数字以选择:1
      --2024-06-12 22:10:30-- http://mirror.fishros.com/install/tools/tool_install_ros.py
      Length: 19723 (19K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_in 100%[====================================================>] 19.26K --.-KB/s in 0.04s
      2024-06-12 22:10:30 (502 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19723/19723]
      --2024-06-12 22:10:30-- http://mirror.fishros.com/install/tools/tool_config_rosenv.py
      Length: 2455 (2.4K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_co 100%[====================================================>] 2.40K --.-KB/s in 0s
      2024-06-12 22:10:30 (509 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2455/2455]
      --2024-06-12 22:10:30-- http://mirror.fishros.com/install/tools/tool_config_system_source.py
      Length: 7738 (7.6K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_co 100%[====================================================>] 7.56K --.-KB/s in 0s
      2024-06-12 22:10:31 (1.26 GB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7738/7738]
      小鱼:检测当前系统ubuntu22.04:jammy 支持一键安装ROS
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      0:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      0:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[amd64:jammy],正在为你更换对应源..
      创建文件:/etc/apt/sources.list
      替换完成,尝试第一次更新....
      [-]Result:success jammy-security InReleasee
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu jammy InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu jammy-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu jammy-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu jammy-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', 'All packages are up to date.']
      镜像修复完成.....
      Run CMD Task:[sudo apt search curl ]
      This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data[-]Result:success 22ubuntu0.1 amd64md640ubuntu0.22.04 amd64md64
      [-]Result:success e and 0 not upgraded.
      Run CMD Task:[sudo apt search gnupg2 ]
      [-]Result:success ent (dummy transitional package)
      [-]Result:success
      Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
      [-]Result:success
      Run CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
      [-]Result:success
      [-]Result:success
      根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-]Result:success jammy-security InReleaseemd64 Packages [1,532 kB]
      Run CMD Task:[sudo apt search ros-base ]
      Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using the MQTT prot[] Node that enables connected ROS-based devices or robots to exchange ROS messages via an MQTT broker using the MQTT prot[-]Result:success includes other basic functionalities like tf2 and urdf.
      [1]:humble(ROS2)
      [2]:iron(ROS2)
      [3]:rolling(ROS2)
      0:quit
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:humble(ROS2)桌面版
      [2]:humble(ROS2)基础版(小)
      0:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt search aptitude ]
      [-]Result:success r Debian/Ubuntument files)trained
      Run CMD Task:[sudo apt install ros-humble-desktop -y]
      ros-humble-desktop is already the newest version (0.10.0-1jammy.20240530.113728).
      [-]Result:success e and 0 not upgraded.y.20240530.113728).
      Run CMD Task:[sudo apt search python3-colcon-common-extensions ]
      [-]Result:success d common extensions.lled]
      [-]Result:success e and 0 not upgraded. (0.3.0-1).
      Run CMD Task:[sudo apt search python3-argcomplete ]
      [-]Result:success ython 3)alled]
      [-]Result:success for Robot OS (Python 3)c]
      Run CMD Task:[ls /opt/ros/humble/setup.bash]
      [-]Result:success
      欢迎使用一键配置ROS开发环境,本工具由作者小鱼提供
      Run CMD Task:[ls /opt/ros/*/setup.bash]
      [-]Result:success
      Run CMD Task:[ls /home/*/.bashrc]
      [-]Result:success
      检测到系统有1个ROS环境,已为你生成启动选择,修改~/.bashrc可关闭
      恭喜你,安装成功了,再附赠你机器人学习宝藏网站:鱼香社区:https://fishros.org.cn/forum
      [-]Result:success
      小鱼:黄黄的提示:您安装的是ROS2,ROS2是没有roscore的,请打开新终端输入ros2测试!小鱼制作了ROS2课程,关注公众号《鱼香ROS》即 可获取~
      root@LAPTOP-T519TJGF:~# ros2 run demo_nodes_cpp
      ros2: command not found
        从您提供的日志来看,您已经成功安装了ROS 2 Humble桌面版。但是,当您尝试运行ros2 run demo_nodes_cpp时,系统提示ros2: command not found,这意味着ros2命令没有在当前的环境变量中。
        出现这个问题的原因可能是您没有正确配置ROS 2的环境变量,或者您当前所在的终端会话还没有加载这些环境变量。ROS 2的环境变量通常通过在~/.bashrc或~/.bash_profile中添加相应的source命令来设置。
        以下是一些步骤,您可以按照这些步骤来确保ROS 2的环境变量被正确加载:
        1. 打开一个新的终端窗口。
        2. 检查~/.bashrc或~/.bash_profile文件中是否包含如下行:
          如果没有,请添加它,并保存文件。
        3. 在当前终端中,运行以下命令来使更改生效:
          source ~/.bashrc
          或者,如果您使用的是~/.bash_profile,则运行:
          source ~/.bash_profile
        4. 现在再次尝试运行ros2命令:
          ros2 run demo_nodes_cpp talker
          如果您成功安装了demo_nodes_cpp包,这个命令应该会启动一个名为talker的节点。
        5. 如果您在安装过程中没有安装demo_nodes_cpp包,您需要先安装它。在ROS 2中,您可以使用colcon来构建示例包,或者如果您使用的是Debian包,则可以使用apt来安装。
          使用apt安装示例包(如果可用):
          sudo apt install ros-humble-demo-nodes-cpp
          或者,如果您想从源代码构建示例包,请按照ROS 2的官方文档进行操作。
        如果上述步骤仍然不能解决问题,请检查您是否以正确的用户身份(如root用户或具有适当权限的普通用户)运行了这些命令,并确保您没有在安装或配置过程中遇到任何错误。
          快快乐乐毕业
          @214747281 在 wsl2一键安装ros2,显示安装成功后 运行demo报错 中说:
          [-]Result:success
          请各位佬帮帮看看吧,感激感激
