    hpp-fcl 凸几何体碰撞检测返回的结果错误
    机械臂运动规划
    碰撞检测 运动规划
    • C
      chendaoming99
      相同的问题,我在 github 上也提交了 issue
      我正在使用与 ROS Humble 和 Ubuntu 22.04 兼容的hpp-fcl,版本2.4.0。
      C++ 版本和 Python 版本都是通过apt install ros-humble-hpp-fcl命令安装的。
      我正在尝试测试一个箱子和一个从.obj文件加载的凸几何体之间的碰撞检测。
      这是我的凸几何体的 .obj:
      你可以从这里下载到该 .obj 文件 here
      我首先写了一个Python程序,它运行得很好。你可以使用"w, s, a, d, q, e"键来移动箱子,当箱子进入凸形内部时,它会打印出"collision detected"(碰撞检测到)
      <details>
      <summary>here is my python code</summary>
      import numpy as np
      import trimesh
      import rclpy
      import hppfcl as fcl
      from pynput import keyboard
      from rclpy.node import Node
      from rclpy.qos import QoSProfile, DurabilityPolicy
      from visualization_msgs.msg import Marker
      class CollisionTest(Node):
          def __init__(self):
              super().__init__('collision_test')
              # config qos profile
              qos_profile = QoSProfile(depth=10)
              qos_profile.durability = DurabilityPolicy.TRANSIENT_LOCAL
              self.box_publisher = self.create_publisher(Marker, 'box', 10)
              self.env_publisher = self.create_publisher(Marker, 'env', qos_profile)
              self.timer = self.create_timer(0.1, self.timer_callback)
              self.box_position = np.array([0.0, 0.0, 0.0])
              self.step = 0.03
              self.init_box()
              self.init_env()
              # Setup keyboard listener
              self.listener = keyboard.Listener(on_press=self.on_press)
              self.listener.start()
          def init_box(self):
              # Initialize box collision object
              box_shape = fcl.Box(0.1, 0.1, 0.1)
              self.box_obj = fcl.CollisionObject(box_shape)
              # Initialize box marker
              self.box_marker = Marker()
              self.box_marker.header.frame_id = 'map'
              self.box_marker.ns = 'collision_test'
              self.box_marker.id = 0
              self.box_marker.type = Marker.CUBE
              self.box_marker.action = Marker.ADD
              self.box_marker.scale.x = 0.1
              self.box_marker.scale.y = 0.1
              self.box_marker.scale.z = 0.1
              self.box_marker.color.a = 1.0
              self.box_marker.color.r = 0.0
              self.box_marker.color.g = 1.0
              self.box_marker.color.b = 0.0
          def init_env(self):
              file_path = "/path/to/convex_hull.obj"
              scale = 1.0
              # Publish markers
              env_marker = Marker()
              env_marker.header.frame_id = 'map'
              env_marker.ns = 'collision_test'
              env_marker.id = 0
              env_marker.type = Marker.MESH_RESOURCE
              env_marker.mesh_resource = "file://" + file_path
              env_marker.action = Marker.ADD
              env_marker.scale.x = scale
              env_marker.scale.y = scale
              env_marker.scale.z = scale
              env_marker.color.r = 0.1
              env_marker.color.g = 0.0
              env_marker.color.b = 0.7
              env_marker.color.a = 0.3
              self.env_publisher.publish(env_marker)
              # Initialize environment collision object
              mesh = trimesh.load_mesh(file_path)
              mesh.apply_scale(scale)
              verts = fcl.StdVec_Vec3f()
              faces = fcl.StdVec_Triangle()
              verts.extend(mesh.vertices)
              for f in mesh.faces:
                  faces.append(fcl.Triangle(int(f[0]), int(f[1]), int(f[2])))
              convex = fcl.Convex(verts, faces)
              self.env_objs = [fcl.CollisionObject(convex)]
          def move_box(self):
              # Move the box marker
              self.box_marker.pose.position.x = self.box_position[0]
              self.box_marker.pose.position.y = self.box_position[1]
              self.box_marker.pose.position.z = self.box_position[2]
              self.box_publisher.publish(self.box_marker)
              # Move the box collision object
              transform = fcl.Transform3f()
              transform.setTranslation(self.box_position)
              self.box_obj.setTransform(transform)
              # Check collision
              for env_obj in self.env_objs:
                  if self.check_collision(self.box_obj, env_obj):
                      self.get_logger().info('Collision detected!')
                      break
          def check_collision(self, obj1, obj2):
              request = fcl.CollisionRequest()
              result = fcl.CollisionResult()
              fcl.collide(obj1, obj2, request, result)
              return result.isCollision()
          def on_press(self, key):
              try:
                  if key.char == 'w':
                      self.box_position[1] += self.step
                  elif key.char == 's':
                      self.box_position[1] -= self.step
                  elif key.char == 'a':
                      self.box_position[0] -= self.step
                  elif key.char == 'd':
                      self.box_position[0] += self.step
                  elif key.char == 'q':
                      self.box_position[2] += self.step
                  elif key.char == 'e':
                      self.box_position[2] -= self.step
              except AttributeError:
                  pass
          def timer_callback(self):
              self.move_box()
      def main(args=None):
          print(f"hpp-fcl version: {fcl.__version__}")
          rclpy.init(args=args)
          node = CollisionTest()
          rclpy.spin(node)
          rclpy.shutdown()
      if __name__ == '__main__':
      </details>
      然而,当我尝试用C++重写代码时,事情变得有些奇怪。它在错误的地方打印出“collision detection”(碰撞检测)。
      这里有一个短视频来展示这个问题:
      https://github.com/humanoid-path-planner/hpp-fcl/assets/69784031/efc4783c-fbb8-4476-acb7-0e45e3930c60
      <details>
      <summary>here is my c++ code</summary>
      #include <Eigen/Geometry>
      #include <termios.h>
      #include <unistd.h>
      #include <sys/select.h>
      #include <fstream>
      #include <rclcpp/rclcpp.hpp>
      #include <visualization_msgs/msg/marker.hpp>
      #include <geometry_msgs/msg/point.hpp>
      #include <hpp/fcl/collision.h>
      #include <hpp/fcl/distance.h>
      #include <hpp/fcl/shape/convex.h>
      #include <hpp/fcl/shape/geometric_shapes.h>
      #include <hpp/fcl/mesh_loader/loader.h>
      #include <hpp/fcl/BVH/BVH_model.h>
      #include <assimp/Importer.hpp>
      #include <assimp/scene.h>
      #include <assimp/postprocess.h>
      namespace fcl = hpp::fcl;
      using Convex_t = fcl::Convex<fcl::Triangle>;
      class CollisionTest : public rclcpp::Node {
       private:
        rclcpp::Publisher<visualization_msgs::msg::Marker>::SharedPtr box_publisher_;
        rclcpp::Publisher<visualization_msgs::msg::Marker>::SharedPtr env_publisher_;
        Eigen::Vector3d box_position_ = Eigen::Vector3d::Zero();
        double step = 0.03;
        visualization_msgs::msg::Marker box_marker_;
        fcl::CollisionObject box_obj_{ nullptr };
        std::vector<fcl::CollisionObject> env_objs_{};
        void init_collision_objs(aiNode* node, const aiScene* scene, visualization_msgs::msg::Marker& marker) {
          double scale_factor = 1;
          for (u_int i = 0; i < node->mNumMeshes; i++) {
            aiMesh* mesh = scene->mMeshes[node->mMeshes[i]];
            fcl::Vec3f* vertices = new fcl::Vec3f[mesh->mNumVertices];
            for (u_int j = 0; j < mesh->mNumVertices; j++) {
              double x = mesh->mVertices[j].x * scale_factor;
              double y = mesh->mVertices[j].y * scale_factor;
              double z = mesh->mVertices[j].z * scale_factor;
              vertices[j] = fcl::Vec3f(x, y, z);
            fcl::Triangle* triangles = new fcl::Triangle[mesh->mNumFaces];
            for (u_int j = 0; j < mesh->mNumFaces; j++) {
              aiFace face = mesh->mFaces[j];
              triangles[j] = fcl::Triangle(face.mIndices[0], face.mIndices[1], face.mIndices[2]);
              // add points to marker
              for (int k = 0; k < 3; k++) {
                geometry_msgs::msg::Point p;
                p.x = vertices[face.mIndices[k]].x();
                p.y = vertices[face.mIndices[k]].y();
                p.z = vertices[face.mIndices[k]].z();
                marker.points.push_back(p);
            // auto convex =
            //     std::make_shared<Convex_t>(true, vertices, mesh->mNumVertices, triangles, mesh->mNumFaces);
            auto convex = std::shared_ptr<Convex_t>(
                new Convex_t(true, vertices, mesh->mNumVertices, triangles, mesh->mNumFaces));
            // auto tf = fcl::Transform3f::Identity();
            fcl::CollisionObject obj(convex);
            env_objs_.emplace_back(obj);
          for (unsigned int i = 0; i < node->mNumChildren; i++) {
            init_collision_objs(node->mChildren[i], scene, marker);
        void init_env() {
          std::string file_path = "/home/developer/dd6ax/src/dd6ax_utils/test/dragon0_convex_hull.obj";
          // double angle_in_degrees = 90.0;
          // Eigen::AngleAxisd rotation_axis(angle_in_degrees * M_PI / 180.0, Eigen::Vector3d::UnitX());
          // Eigen::Quaterniond rotation_quaternion = Eigen::Quaterniond(rotation_axis);
          // rotation_quaternion.normalize();
          Assimp::Importer importer;
          const aiScene* scene = importer.ReadFile(file_path, aiProcess_Triangulate | aiProcess_FlipUVs);
          if (!scene || scene->mFlags & AI_SCENE_FLAGS_INCOMPLETE || !scene->mRootNode) {
            std::cerr << "Error::Assimp:: " << importer.GetErrorString() << std::endl;
            return;
          visualization_msgs::msg::Marker marker;
          marker.header.frame_id = "map";
          marker.header.stamp = this->now();
          marker.ns = "collision_test";
          marker.id = 0;
          marker.type = visualization_msgs::msg::Marker::TRIANGLE_LIST;
          // marker.type = visualization_msgs::msg::Marker::MESH_RESOURCE;
          // marker.mesh_resource = "file://" + file_path;
          marker.action = visualization_msgs::msg::Marker::ADD;
          marker.scale.x = 1.0;
          marker.scale.y = 1.0;
          marker.scale.z = 1.0;
          marker.color.r = 0.1;
          marker.color.g = 0.0;
          marker.color.b = 0.7;
          marker.color.a = 0.3;
          init_collision_objs(scene->mRootNode, scene, marker);
          RCLCPP_INFO(this->get_logger(), "Publishing marker with %zu points", marker.points.size());
          env_publisher_->publish(std::move(marker));
        void init_box() {
          // init box collision object
          box_obj_ =
              fcl::CollisionObject(std::make_shared<fcl::Box>(0.1, 0.1, 0.1), fcl::Transform3f::Identity());
          // init box marker
          box_marker_.header.frame_id = "map";
          box_marker_.header.stamp = this->now();
          box_marker_.ns = "collision_test";
          box_marker_.id = 0;
          box_marker_.type = visualization_msgs::msg::Marker::CUBE;
          box_marker_.action = visualization_msgs::msg::Marker::ADD;
          box_marker_.pose.orientation.x = 0.0;
          box_marker_.pose.orientation.y = 0.0;
          box_marker_.pose.orientation.z = 0.0;
          box_marker_.pose.orientation.w = 1.0;
          box_marker_.scale.x = 0.1;
          box_marker_.scale.y = 0.1;
          box_marker_.scale.z = 0.1;
          box_marker_.color.a = 1.0;
          box_marker_.color.r = 0.0;
          box_marker_.color.g = 1.0;
          box_marker_.color.b = 0.0;
        void get_box_position() {
          fd_set readfds;
          FD_ZERO(&readfds);
          FD_SET(STDIN_FILENO, &readfds);
          // Wait up to 20 milliseconds for input
          struct timeval timeout = { 0, 20 * 1000 };
          int result = select(STDIN_FILENO + 1, &readfds, NULL, NULL, &timeout);
          if (result <= 0) {
            return;
          if (!FD_ISSET(STDIN_FILENO, &readfds)) {
            return;
          char c;
          if (read(STDIN_FILENO, &c, 1) <= 0) {
            return;
          switch (c) {
            case 'w':
              box_position_.y() += step;
              break;
            case 's':
              box_position_.y() -= step;
              break;
            case 'a':
              box_position_.x() -= step;
              break;
            case 'd':
              box_position_.x() += step;
              break;
            case 'q':
              box_position_.z() += step;
              break;
            case 'e':
              box_position_.z() -= step;
              break;
            default:
              break;
        void move_box() {
          // move the box marker
          box_marker_.pose.position.x = box_position_.x();
          box_marker_.pose.position.y = box_position_.y();
          box_marker_.pose.position.z = box_position_.z();
          box_publisher_->publish(box_marker_);
          // move the box collision object
          auto fcl_tf = fcl::Transform3f::Identity();
          fcl_tf.setTranslation(box_position_);
          box_obj_.setTransform(fcl_tf);
          // check collision
          for (const auto& env_obj : env_objs_) {
            if (check_collision(box_obj_, env_obj)) {
              RCLCPP_INFO(this->get_logger(), "Collision detected!");
            break;
          // double distance = get_distance(box_obj_, env_obj);
          // RCLCPP_INFO(this->get_logger(), "Distance: %f", distance);
        bool check_collision(fcl::CollisionObject obj1, fcl::CollisionObject obj2) {
          fcl::CollisionRequest request;
          fcl::CollisionResult result;
          fcl::collide(&obj1, &obj2, request, result);
          return result.isCollision();
        double get_distance(fcl::CollisionObject obj1, fcl::CollisionObject obj2) {
          fcl::DistanceRequest request;
          fcl::DistanceResult result;
          fcl::distance(&obj1, &obj2, request, result);
          return result.min_distance;
        void timer_callback() {
          get_box_position();
          move_box();
       public:
        CollisionTest() : Node("collision_test") {
          // set the terminal to unbuffered input
          struct termios tty;
          memset(&tty, 0, sizeof tty);
          if (tcgetattr(STDIN_FILENO, &tty) != 0) {
            RCLCPP_ERROR(this->get_logger(), "Error from tcgetattr");
          tty.c_lflag &= ~ICANON;
          tty.c_lflag &= ~ECHO;
          tty.c_cc[VMIN] = 1;   // Minimum of one character for getc
          tty.c_cc[VTIME] = 0;  // Wait indefinetly
          if (tcsetattr(STDIN_FILENO, TCSANOW, &tty) != 0) {
            RCLCPP_ERROR(this->get_logger(), "Error from tcsetattr");
          // init publishers and timer
          box_publisher_ = create_publisher<visualization_msgs::msg::Marker>("box", 10);
          init_box();
          timer_ = create_wall_timer(std::chrono::milliseconds(100),
                                     std::bind(&CollisionTest::timer_callback, this));
          env_publisher_ = create_publisher<visualization_msgs::msg::Marker>(
              "env", rclcpp::QoS(rclcpp::KeepLast(10)).transient_local());
          init_env();
        ~CollisionTest() {
          // reset the terminal to buffered input
          struct termios tty;
          tcgetattr(STDIN_FILENO, &tty);
          tty.c_lflag |= ICANON;
          tty.c_lflag |= ECHO;
          tcsetattr(STDIN_FILENO, TCSANOW, &tty);
      int main(int argc, char* argv[]) {
        std::cout << "HPP-FCL version is: " << HPP_FCL_VERSION << std::endl;
        rclcpp::init(argc, argv);
        rclcpp::spin(std::make_shared<CollisionTest>());
        rclcpp::shutdown();
        return 0;
      </details>
      我将init_collision_objs()函数写成递归函数的原因是,我将来会处理一个.obj文件中的一组几何体。凸形的顶点是正确的,因为TRIANGLE_LIST可视化标记正常工作。
      感谢大佬们的帮助
