    在jupyter中导入rclpy库时报错
    jupyter rclpy
    1.1k
    • A
      a624323a
      import rclpy
      from rclpy.node import Node
      ModuleNotFoundError Traceback (most recent call last)
      Cell In[3], line 2
      1 import rclpy
      ----> 2 from rclpy.node import Node
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/node.py:42
      40 from rclpy.callback_groups import MutuallyExclusiveCallbackGroup
      41 from rclpy.callback_groups import ReentrantCallbackGroup
      ---> 42 from rclpy.client import Client
      43 from rclpy.clock import Clock
      44 from rclpy.clock import ROSClock
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/client.py:22
      20 from rclpy.callback_groups import CallbackGroup
      21 from rclpy.context import Context
      ---> 22 from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
      23 from rclpy.qos import QoSProfile
      24 from rclpy.task import Future
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/implementation_singleton.py:31
      15 """
      16 Provide singleton access to the rclpy C modules.
      17
      26 # ...
      27 """
      29 from rclpy.impl import _import
      ---> 31 rclpy_implementation = _import('._rclpy')
      32 rclpy_action_implementation = _import('._rclpy_action')
      33 rclpy_logging_implementation = _import('._rclpy_logging')
      File /opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/init.py:28, in _import(name)
      23 try:
      24 # Since Python 3.8, on Windows we should ensure DLL directories are
      25 # explicitly added to the search path.
      26 # See https://docs.python.org/3/whatsnew/3.8.html#bpo-36085-whatsnew
      27 with add_dll_directories_from_env('PATH'):
      ---> 28 return importlib.import_module(name, package='rclpy')
      29 except ImportError as e:
      30 if e.path is None:
      File ~/miniconda3/lib/python3.12/importlib/init.py:90, in import_module(name, package)
      88 break
      89 level += 1
      ---> 90 return _bootstrap._gcd_import(name[level:], package, level)
      ModuleNotFoundError: No module named 'rclpy._rclpy'
      The C extension '/opt/ros/foxy/lib/python3.8/site-packages/rclpy/_rclpy.cpython-312-x86_64-linux-gnu.so' isn't present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system' for possible solutions
        这个错误表明你尝试在Jupyter Notebook中使用rclpy库时遇到了问题,具体是因为Python环境中的rclpy库没有正确编译或安装其C扩展部分。这通常发生在Python环境版本与ROS 2安装时使用的Python版本不匹配时。
        在你的情况中,你使用的是Python 3.12,但是ROS 2 Foxy版本通常是为Python 3.8编译的。这导致了不兼容问题,因为rclpy的C扩展(如_rclpy.cpython-312-x86_64-linux-gnu.so)不存在于你的系统中,因为它是为Python 3.8编译的。
        解决方案
        1. 使用与ROS 2版本相匹配的Python版本:
          最直接的解决方案是使用与你的ROS 2安装相匹配的Python版本。对于ROS 2 Foxy,这通常是Python 3.8。你可以在Jupyter Notebook中创建一个新的虚拟环境,使用Python 3.8,并在这个环境中安装jupyter和rclpy。
          创建并激活Python 3.8的虚拟环境(如果你使用的是conda):
          conda create -n ros2_env python=3.8
          conda activate ros2_env
          安装Jupyter:
          pip install jupyter
          然后启动Jupyter Notebook,并在该环境中运行你的代码。
        2. 编译ROS 2以支持新的Python版本(不推荐,除非你有特殊需求):
          如果你确实需要使用Python 3.12,并且愿意投入时间来编译ROS 2,你可以尝试从源代码编译ROS 2,并确保在编译过程中使用Python 3.12。这通常是一个复杂且耗时的过程,可能会遇到各种依赖问题。
        3. 检查ROS 2的文档和社区:
          访问ROS 2的官方文档和社区论坛,看看是否有其他人遇到了类似的问题,并找到了解决方案。
        额外建议
        • 确保你的ROS 2环境设置正确,包括source /opt/ros/foxy/setup.bash(或相应的安装路径)在你的shell中。
        • 如果你使用的是特定的IDE或编辑器(如VSCode、PyCharm等),确保它们也使用了正确的Python解释器和ROS 2环境。
        希望这些信息能帮助你解决问题!
