    ros2 ethcat
    ros2 hamble ethercat cmake
      一桶珠子
      richma@richma-virtual-machine:~/ros2_ws$ colcon build
      Starting >>> ethercat_interface
      Starting >>> ethercat_msgs
      Starting >>> platform_driver_ethercat_ros2
      --- stderr: platform_driver_ethercat_ros2
      CMake Error at CMakeLists.txt:18 (find_package):
      By not providing "Findplatform_driver_ethercat.cmake" in CMAKE_MODULE_PATH
      this project has asked CMake to find a package configuration file provided
      by "platform_driver_ethercat", but CMake did not find one.
      "platform_driver_ethercat" with any of the following names:
      platform_driver_ethercatConfig.cmake
      platform_driver_ethercat-config.cmake
      Add the installation prefix of "platform_driver_ethercat" to
      CMAKE_PREFIX_PATH or set "platform_driver_ethercat_DIR" to a directory
      containing one of the above files. If "platform_driver_ethercat" provides
      a separate development package or SDK, be sure it has been installed.
      Failed <<< platform_driver_ethercat_ros2 [0.10s, exited with code 1]
      Aborted <<< ethercat_interface [0.78s]
      Aborted <<< ethercat_msgs [0.79s]
      Summary: 0 packages finished [0.94s]
      1 package failed: platform_driver_ethercat_ros2
      2 packages aborted: ethercat_interface ethercat_msgs
      2 packages had stderr output: ethercat_interface platform_driver_ethercat_ros2
      5 packages not processed
        这个错误表明在构建 platform_driver_ethercat_ros2 包时,CMake 无法找到名为 platform_driver_ethercat 的依赖包。这通常是因为 platform_driver_ethercat 没有被正确安装或者其安装位置没有被 CMake 识别。
        要解决这个问题,你可以尝试以下几个步骤:
        1. 确认 platform_driver_ethercat 是否已安装:
          确保你已经安装了 platform_driver_ethercat 包。如果你是在 ROS 2 环境中工作,这通常意味着你需要从源代码编译它,或者通过包管理器(如 apt)安装它(如果可用)。
        2. 检查安装位置:
          如果 platform_driver_ethercat 已经安装,检查其安装位置。通常,CMake 配置文件(如 platform_driver_ethercatConfig.cmake)位于安装目录下的 share/platform_driver_ethercat 文件夹中。
        3. 设置 CMAKE_PREFIX_PATH:
          如果你知道 platform_driver_ethercat 的安装路径,你可以在构建 platform_driver_ethercat_ros2 之前设置 CMAKE_PREFIX_PATH 环境变量,以便 CMake 能够找到它。例如,在 bash 中,你可以这样做:
          export CMAKE_PREFIX_PATH=/path/to/platform_driver_ethercat:$CMAKE_PREFIX_PATH
          替换 /path/to/platform_driver_ethercat 为实际的安装路径。
        4. 设置 platform_driver_ethercat_DIR:
          或者,你可以在构建 platform_driver_ethercat_ros2 时,通过 -Dplatform_driver_ethercat_DIR=/path/to/config 参数直接指定 CMake 配置文件的位置。
        5. 重新构建:
          设置完上述路径后,重新运行 colcon build。
        6. 检查 CMakeLists.txt:
          如果上述步骤都不能解决问题,检查 platform_driver_ethercat_ros2 的 CMakeLists.txt 文件,确认 find_package(platform_driver_ethercat) 调用是否正确。
        7. 查看文档和社区支持:
          如果以上步骤仍然无法解决问题,查看 platform_driver_ethercat 和 platform_driver_ethercat_ros2 的官方文档或寻求社区的帮助可能是一个好主意。
        希望这些步骤能帮助你解决问题!
