    Ubuntu16.04安装ROS kinetic失败
    一键安装ros kinetic
    • 9
      953368815
      最后由 953368815 编辑
      求解Ubuntu16.04安装ROS kinetic中的依赖问题
      背景
      我在win系统上用WSL2安装了Ubuntu子系统,然后像试试在这个平台上安装ROS控制我的pepper机器人运动。
      问题描述
      安装ROS失败了。安装的过程总是会报依赖错误,如下。
       ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going to be installed
                                  Depends: ros-kinetic-perception but it is not going to be installed
                                  Depends: ros-kinetic-simulators but it is not going to be installed
                                  Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
      怀疑子系统问题
      在CSDN上看到有其他人用子系统安装成功,所以我想应该不是这个原因。
      尝试使用aptitude
      有尝试使用aptitude进行安装,但是在ubuntu上好像aptitude会和apt产生冲突,安装了aptitude了,apt会被自动卸载掉。然后aptitude会报这样的错误。
      E: The method driver /usr/lib/apt/methods/http could not be found.
      The following actions will resolve these dependencies:
      好像和 apt 的 HTTP 方法驱动程序缺失有关。但apt被aptitude干掉了。后边是卸载了aptitude,重新装回了apt。
      尝试修改镜像
      因为我这边已经配置过清华镜像了,所以这里镜像的选项没有改。
      (之前也试过一件更换镜像,最终也都是卡在依赖问题这里)
      完整的日志:
      zzy@PV-X00255684:/mnt/e/subSystemLinux/pkg$ su root
      Password:
      root@PV-X00255684:/mnt/e/subSystemLinux/pkg# wget http://fishros.com/install -O fishros && . fishros
      --2024-08-30 13:27:08--  http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2024-08-30 13:27:08--  http://fishros.com/install/
      Length: 579 [application/octet-stream]
      Saving to: ‘fishros’
      fishros                          100%[=========================================================>]     579  --.-KB/s    in 0s
      2024-08-30 13:27:08 (48.9 MB/s) - ‘fishros’ saved [579/579]
      Reading package lists... Done
      Building dependency tree
      sudo is already the newest version (1.8.16-0ubuntu1.10).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Package python3-distro is not available, but is referred to by another package.
      This may mean that the package is missing, has been obsoleted, or
      is only available from another source
      E: Package 'python3-distro' has no installation candidate
      --2024-08-30 13:27:09--  http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 44650 (44K) [application/octet-stream]
      /tmp/fishinstall/tools/base.py   100%[=========================================================>]  43.60K  --.-KB/s    in 0.08s
      2024-08-30 13:27:09 (550 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [44650/44650]
      WARN:No Yaml Module!
      [-]Result:success
      [-]Result:code:8
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
        [6]:一键安装:NodeJS环境
        [7]:一键安装:VsCode开发工具
        [8]:一键安装:Docker
        [10]:一键安装:微信(可以在Linux上使用的微信)
        [14]:一键安装:科学上网代理工具
        [15]:一键安装:QQ for Linux
      配置工具:
        [13]:一键配置:python国内源
      [0]:quit
      请输入[]内的数字以选择:1
      --2024-08-30 13:27:19--  http://mirror.fishros.com/install/tools/tool_install_ros.py
      Length: 19723 (19K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_inst 100%[=========================================================>]  19.26K  --.-KB/s    in 0.03s
      2024-08-30 13:27:19 (633 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19723/19723]
      --2024-08-30 13:27:19--  http://mirror.fishros.com/install/tools/tool_config_rosenv.py
      Length: 2455 (2.4K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_conf 100%[=========================================================>]   2.40K  --.-KB/s    in 0s
      2024-08-30 13:27:19 (207 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2455/2455]
      --2024-08-30 13:27:19--  http://mirror.fishros.com/install/tools/tool_config_system_source.py
      Length: 7738 (7.6K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_conf 100%[=========================================================>]   7.56K  --.-KB/s    in 0s
      2024-08-30 13:27:19 (15.3 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7738/7738]
      小鱼:检测当前系统ubuntu16.04:xenial 支持一键安装ROS
      [0]:quit
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      请输入[]内的数字以选择:2
      [-]Result:success                           enial-security InReleases InRelease
      Run CMD Task:[sudo apt search curl ]
      [\]  This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into m[/]  This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into m[-]Result:success                           3 amd64dock app0.12-5ubuntu3.2 amd644amd64
      [-]Result:success                           e and 0 not upgraded.
      Run CMD Task:[sudo apt search gnupg2 ]
      [-]Result:success                           ent (dummy transitional package)
      [-]Result:success
      [-]Result:success
      [-]Result:success                           n/ros/ubuntu xenial/main amd64 Packages [854 kB]]
      Run CMD Task:[sudo apt search ros-base ]
      [/]  A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, a[-]  A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure, nodelets, a[-]Result:success
      [0]:quit
      [1]:kinetic(ROS1)
      [2]:lunar(ROS2)
      [3]:ardent(ROS2)
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [0]:quit
      [1]:kinetic(ROS1)桌面版
      [2]:kinetic(ROS1)基础版(小)
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt install   ros-kinetic-desktop-full -y]
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      E: Unable to correct problems, you have held broken packages.
      [-]Result:code:100                           inetic-urdf-tutorial but it is not going to be installed
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-kinetic-desktop-full)
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo apt install   ros-kinetic-desktop-full]
      Run CMD Task:[sudo apt search python-catkin-tools ]
      [-]Result:success                           kin.0.6.1-1 all [installed]
      Run CMD Task:[sudo apt search python-rosdep ]
      [-]Result:success                            for ROS-1 all
      [-]Result:success                           1) .....l.deb ....deb .....64 python-rosdep all 0.21.0-1 [3,236 B]51.5 kB]B]
      Run CMD Task:[ls /opt/ros/kinetic/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
      请各位大佬能帮忙看看?
        在Windows Subsystem for Linux (WSL) 上安装 ROS(尤其是较旧版本如 ROS Kinetic)可能会遇到一些依赖问题,因为 WSL 并不总是完全等同于传统的 Linux 环境。这里有几个步骤和建议可以帮助你解决安装 ROS Kinetic 时遇到的问题:
        1. 确认依赖关系:
          ROS Kinetic 需要特定的依赖包,而这些包可能不在默认的 WSL 仓库中。首先确保你的系统源是最新的,并且已经包含了 ROS 的依赖。你已经尝试使用清华的源,这是一个好的开始。
        2. 使用 aptitude:
          虽然你提到 aptitude 和 apt 之间的冲突,但 aptitude 在解决依赖问题上通常更强大。你可以尝试临时安装 aptitude,解决依赖问题后,再卸载它(如果确实需要的话)。在 WSL 中,你可以使用如下命令来安装 aptitude(如果它还没有被卸载 apt):
          sudo apt-get install aptitude
          如果 aptitude 解决了问题,你可以考虑保留它,或者再次使用 apt-get 卸载它(如果需要)。
        3. 检查 Python 版本:
          ROS Kinetic 支持 Python 2.7。确保你的 WSL 系统中的 Python 版本与之兼容。在 WSL 中,你可以通过运行 python --version 和 python3 --version 来检查 Python 的版本。如果默认 Python 版本是 Python 3,你可能需要安装 Python 2.7 并设置适当的别名或链接。
        4. 检查 ROS 源:
          确保你的 ROS 源是正确的。你已经添加了清华的源,这是一个很好的选择。但请确保没有其他的 ROS 源可能导致冲突。
        5. 手动安装依赖:
          如果自动安装失败,你可以尝试手动安装那些缺失的依赖。这通常涉及到查找每个缺失包的依赖,并使用 apt-get install 或 aptitude install 来安装它们。
        6. 考虑使用 ROS Noetic:
          如果可能,考虑使用 ROS Noetic 而不是 Kinetic。ROS Noetic 是 ROS 1 的最新长期支持版本,它支持 Python 3,并且与 WSL 的兼容性可能更好。
        7. 查看 WSL 的限制:
          请注意,WSL 可能不完全支持 ROS 的所有功能,特别是那些需要硬件交互(如机器人硬件)的功能。如果你需要这些功能,考虑在虚拟机或双启动的 Linux 环境中安装 ROS。
        8. 查看社区和文档:
          查看 ROS 社区和文档,看看是否有其他人遇到并解决了类似的问题。这可以帮助你找到解决方案或工作区。
        希望这些步骤和建议能帮助你解决在 WSL 上安装 ROS Kinetic 时遇到的问题!
