    使用一键安装过程中遇到程序崩溃
    一键安装ros 失败 报错
    1.5k
    • Z
      zz2ethan
      遇到了一些问题
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 407, in install_ros
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 391, in config_env_and_tip
      File "/tmp/fishinstall/tools/base.py", line 1473, in run_tool_file
      File "/usr/lib/python3.8/importlib/init.py", line 127, in import_module
      File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
      File "<frozen importlib._bootstrap>", line 991, in _find_and_load
      File "<frozen importlib._bootstrap>", line 973, in _find_and_load_unlocked
      ModuleNotFoundError: No module named 'tools.tool_config_rosenv'
        小鱼 技术大佬 @zz2ethan
        @zz2ethan 多运行几次试试
