    相机无法启动
    相机 无法启动
    519
    • H
      hhhang
      rikibot@rikibot:~/catkin_ws$ roslaunch rikibot camera.launch
      ... logging to /home/rikibot/.ros/log/6267bd0e-d710-11ef-a685-a08869fa52a8/roslaunch-rikibot-4674.log
      Press Ctrl-C to interrupt
      started roslaunch server http://192.168.1.9:43945/
      SUMMARY
      PARAMETERS
      • /rosdistro: melodic
      • /rosversion: 1.14.13
      • /uvc_camera_node/auto_focus: False
      • /uvc_camera_node/camera_info_url: file:///home/riki...
      • /uvc_camera_node/device: /dev/video0
      • /uvc_camera_node/focus_absolute: 0
      • /uvc_camera_node/fps: 30
      • /uvc_camera_node/frame: wide_stereo
      • /uvc_camera_node/height: 480
      • /uvc_camera_node/width: 640
      NODES
      compressed_image (topic_tools/transform)
      uvc_camera_node (uvc_camera/uvc_camera_node)
      auto-starting new master
      process[master]: started with pid [4687]
      ROS_MASTER_URI=http://192.168.1.9:11311
      setting /run_id to 6267bd0e-d710-11ef-a685-a08869fa52a8
      process[rosout-1]: started with pid [4704]
      started core service [/rosout]
      process[uvc_camera_node-2]: started with pid [4713]
      process[compressed_image-3]: started with pid [4722]
      [ INFO] [1737365087.656056707]: camera calibration URL: file:///home/rikibot/catkin_ws/src/camera_umd/uvc_camera/example.yaml
      [ INFO] [1737365087.663470500]: Unable to open camera calibration file [/home/rikibot/catkin_ws/src/camera_umd/uvc_camera/example.yaml]
      [ WARN] [1737365087.663823216]: Camera calibration file /home/rikibot/catkin_ws/src/camera_umd/uvc_camera/example.yaml not found.
      opening /dev/video0
      pixfmt 0 = 'YUYV' desc = 'YUYV 4:2:2'
      discrete: 1280x720: 1/9
      discrete: 640x480: 1/30
      discrete: 352x288: 1/30
      discrete: 320x240: 1/30
      discrete: 176x144: 1/30
      discrete: 160x120: 1/30
      discrete: 1280x800: 1/9
      pixfmt 1 = 'MJPG' desc = 'Motion-JPEG'
      discrete: 1280x720: 1/30
      discrete: 1280x800: 1/30
      int (Brightness, 0, id = 980900): -64 to 64 (1)
      int (Contrast, 0, id = 980901): 0 to 95 (1)
      int (Saturation, 0, id = 980902): 0 to 128 (1)
      int (Hue, 0, id = 980903): -2000 to 2000 (1)
      bool (White Balance Temperature, Auto, 0, id = 98090c): 0 to 1 (1)
      int (Gamma, 0, id = 980910): 100 to 300 (1)
      int (Gain, 0, id = 980913): 0 to 100 (1)
      menu (Power Line Frequency, 0, id = 980918): 0 to 2 (1)
      0: Disabled
      1: 50 Hz
      2: 60 Hz
      int (White Balance Temperature, 16, id = 98091a): 2800 to 6500 (1)
      int (Sharpness, 0, id = 98091b): 1 to 7 (1)
      int (Backlight Compensation, 0, id = 98091c): 0 to 65535 (1)
      menu (Exposure, Auto, 0, id = 9a0901): 0 to 3 (1)
      int (Exposure (Absolute), 16, id = 9a0902): 1 to 5000 (1)
      bool (Exposure, Auto Priority, 0, id = 9a0903): 0 to 1 (1)
      Setting auto_focus is not supported
        从日志信息来看,相机启动过程中遇到了一些问题,主要问题是无法打开相机校准文件。以下是一些可能的解决步骤:
        1. 检查相机校准文件路径:
          日志中提到无法打开相机校准文件 /home/rikibot/catkin_ws/src/camera_umd/uvc_camera/example.yaml。请检查这个文件是否真的存在于该路径下。如果不存在,你需要提供一个正确的校准文件路径,或者如果该文件仅作为示例,你可能需要创建或获取一个适用于你的相机的校准文件。
        2. 创建或获取正确的校准文件:
          相机校准文件通常包含相机的内部参数,如焦距、光心等,这些参数对于图像处理和计算机视觉任务非常重要。如果你没有这个文件,你可能需要手动校准你的相机或使用相机制造商提供的校准工具来获取这些参数。
        3. 检查相机设备:
          日志显示相机设备 /dev/video0 被成功打开,并且列出了支持的分辨率和格式。这表明相机硬件在操作系统层面被正确识别。确保没有其他程序正在使用此相机设备。
        4. 权限问题:
          确保你的用户账户有权限访问 /dev/video0 设备。通常,访问视频设备需要属于 video 组。你可以使用 sudo usermod -a -G video $USER 命令将你的用户添加到 video 组,然后重新登录。
        5. 重新启动 ROS 节点:
          在解决上述问题后,尝试重新启动 ROS 节点来看是否解决了问题。
        6. 查看详细的错误日志:
          如果问题依旧存在,可以查看更详细的 ROS 日志文件,通常位于 /home/rikibot/.ros/log/ 目录下,以获取更多关于错误的详细信息。
        通过上述步骤,你应该能够诊断并解决相机无法启动的问题。如果问题依旧无法解决,可能需要检查相机驱动或硬件是否存在问题。
        H 1 条回复 最后回复 回复 引用 0
        • H
          hhhang @小伊
          @小伊
          @小伊 在 相机无法启动 中说:
          1. 检查相机校准文件路径:
          2. 创建或获取正确的校准文件:
          3. 检查相机设备:
          4. 权限问题:
          5. 重新启动 ROS 节点:
          6. 查看详细的错误日志:
          没有用
            如果上述步骤没有解决相机无法启动的问题,这里有一些额外的排查步骤和建议,可能有助于进一步定位问题:
            1. 检查 ROS 节点和话题:
              • 使用 rosnode list 命令查看当前运行的 ROS 节点,确保相机相关的节点正在运行。
              • 使用 rostopic list 命令查看当前发布和订阅的话题,确保相机发布图像数据的话题存在且被正确订阅。
            2. 检查相机驱动:
              • 确认相机驱动是否与你的相机型号兼容。有些相机需要特定的驱动程序才能正常工作。
              • 如果你是通过 ROS 包(如 uvc_camera)来启动相机,确保该包支持你的相机型号和操作系统版本。
            3. 检查相机固件:
              • 有些相机问题可能是由于固件过时或损坏引起的。访问相机制造商的网站,查看是否有可用的固件更新。
            4. 使用其他工具测试相机:
              • 使用如 guvcview 或 cheese 等工具测试相机是否可以正常工作。这些工具可以在不使用 ROS 的情况下直接访问相机设备。
            5. 检查系统日志:
              • 查看 /var/log/syslog 或 /var/log/messages 等系统日志文件,以获取更多关于相机设备或驱动程序错误的详细信息。
            6. 硬件检查:
              • 检查相机与计算机之间的连接是否牢固,包括 USB 线缆等。
              • 尝试将相机连接到另一台计算机上,以排除是计算机硬件或设置问题导致的相机无法启动。
            7. 寻求社区帮助:
              • 如果以上步骤都没有解决问题,你可以在 ROS 社区论坛、GitHub 仓库或其他相关社区中寻求帮助。提供尽可能详细的信息,包括相机型号、操作系统版本、ROS 版本以及你尝试过的解决步骤。
            请注意,解决相机无法启动的问题可能需要一些时间和耐心。在排查过程中,保持清晰的思路和详细的记录将有助于你更快地定位并解决问题。
            • H
              hhhang @小伊
              @小伊 在 相机无法启动 中说:
              1. 检查 ROS 节点和话题:
              2. 检查相机驱动:
              3. 检查相机固件:
              4. 使用其他工具测试相机:
              5. 检查系统日志:
              6. 硬件检查:
              7. 寻求社区帮助:
              如何创建或获取一个适用于你的相机的校准文件
                创建或获取一个适用于相机的校准文件,可以根据相机的类型和所需校准的具体内容采取不同的方法。以下是一些通用的步骤和建议:
                一、针对特定软件平台获取或创建相机校准文件
                以Adobe Lightroom(LR)和Adobe Camera Raw(ACR)为例,可以通过以下步骤创建适用于相机的校准文件(DCP文件):
                1. 下载并安装DCP编辑器:
                  • 在网上查找并下载一个免安装的DCP编辑器。
                2. 找到现有校准文件:
                  • 打开指定的目录(例如,在Windows 7系统中为C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Camera),可以看到各品牌相机的DCP文件。
                3. 导出目标相机的RAW文件:
                  • 启动LR,打开想为其制作DCP的相机RAW文件。
                  • 右键导出或在“文件”菜单中选择“导出为DNG”,并将其保存在一个易于访问的位置。
                4. 使用DCP编辑器创建新的校准文件:
                  • 打开DCP编辑器,点击“File”->“Open DNG Image”,打开刚才生成的DNG图片。
                  • 在编辑器的右侧面板中,选择“Color Tables”下的“Base Profile”,然后选择“Choose external profile”。
                  • 在文件选择界面中,找到之前保存的各家相机配置文件夹,选择一个喜欢的色彩风格文件并打开。
                  • 此时,编辑器中的原图色彩风格会发生改变。在右侧面板的配置文件列表中,刚才选择的色彩文件也会显示出来。
                  • 点击“File”并选择导出目标相机的配置文件(例如“Export Nikon D800 profile”)。
                  • 存储文件并重命名,以便以后识别。存储完成后,编辑器会显示导出成功的信息。
                5. 应用新的校准文件:
                  • 按照指定路径(例如,C:\Users\用户名\AppData\Roaming\Adobe\CameraRaw\CameraProfiles)找到刚导出的DCP文件。AppData文件夹默认是隐藏的,需要手动显示隐藏文件夹才能看到。
                  • 重启LR,再次打开目标相机的RAW文件。在“相机校准”下的配置文件列表中,可以看到刚才导出的DCP文件。
                请注意,这些DCP文件仅对RAW文件(包括宾得、徕卡的DNG文件)有效,对JPG或TIFF文件无效。并且,用什么相机RAW做的DCP,就只能在打开这款相机RAW时显示。如果想为其他相机型号创建DCP文件,需要重复上述步骤。
                二、针对特定相机品牌获取校准文件
                以尼康相机为例,可以通过以下步骤获取或应用优化校准文件:
                1. 下载预设:从可靠的来源下载适用于尼康相机的优化校准文件。
                2. 挑选预设:使用捕影工匠等软件挑选适合自己的预设。
                3. 导入预设:通过Picture Control Utility 2等工具导入预设。但请注意,导入的预设色彩可能不完全准确。
                4. 应用预设:在捕影工匠中打开一张NEF原片,在右侧找到优化校准设置,选择喜欢的预设。然后,通过相机管理优化校准来设定。
                三、通用建议
                1. 参考相机制造商的文档:相机制造商通常会提供有关如何创建或获取校准文件的详细文档。查阅相机的用户手册或在线支持页面,以获取更多指导。
                2. 使用专业软件:除了上述的DCP编辑器和捕影工匠等软件外,还可以使用其他专业软件来创建或编辑相机校准文件。这些软件通常提供更多的自定义选项和高级功能。
                3. 寻求社区帮助:如果无法找到适用于相机的校准文件或创建自己的校准文件时遇到困难,可以在相机制造商的论坛、摄影社区或专业论坛中寻求帮助。其他用户或专家可能能够提供有用的建议或解决方案。
                总之,创建或获取适用于相机的校准文件需要一定的技术知识和耐心。通过遵循上述步骤和建议,可以更容易地找到或创建符合需求的校准文件。
