    一键安装ROS2 humble出现问题
    ros2 wsl
    1.9k
    • Y
      yangkang
      Run CMD Task:[sudo apt install ros-humble-desktop -y]
      Reading package lists... Done
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      libboost-iostreams1.74-dev : Depends: libboost-iostreams1.74.0 (= 1.74.0-14ubuntu3) but 1.74.0+ds1-23.1ubuntu3 is to be installed
      libboost-mpi-python1.74.0 : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      libcurl4-openssl-dev : Depends: libcurl4 (= 7.81.0-1ubuntu1.20)
      libgdal-dev : Depends: libnetcdf-dev but it is not installable
      libglib2.0-dev-bin : Depends: python3-distutils but it is not installable
      libhdf4-alt-dev : Depends: libnetcdf-dev but it is not installable
      libhdf5-dev : Depends: libssl-dev but it is not installable
      libhdf5-openmpi-dev : Depends: libssl-dev but it is not installable
      libmysqlclient-dev : Depends: libssl-dev but it is not installable
      libnetcdf-cxx-legacy-dev : Depends: libnetcdf-dev but it is not installable
      libopenjp2-7-dev : Depends: libopenjp2-7 (= 2.4.0-6ubuntu0.3) but 2.5.0-2ubuntu0.3 is to be installed
      libpq-dev : Depends: libssl-dev but it is not installable
      libpulse-dev : Depends: libpulse0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but 1:16.1+dfsg1-2ubuntu10.1 is to be installed
      Depends: libpulse-mainloop-glib0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but it is not going to be installed
      libshiboken2-py3-5.15 : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      libvtk9-dev : Depends: libnetcdf-dev but it is not installable
      libwebp-dev : Depends: libwebp7 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      Depends: libwebpmux3 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      Depends: libwebpdemux2 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      libzstd-dev : Depends: libzstd1 (= 1.4.8+dfsg-3build1) but 1.5.5+dfsg2-2build1.1 is to be installed
      python3-cairo : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-lxml : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Recommends: python3-bs4 but it is not going to be installed
      Recommends: python3-html5lib but it is not going to be installed
      python3-matplotlib : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Depends: python3-fonttools but it is not going to be installed
      Depends: python3-kiwisolver but it is not going to be installed
      python3-numpy : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-opencv : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-psutil : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pykdl : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pyqt5.sip : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pyside2.qtsvg : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Depends: python3-pyside2.qtwidgets but it is not going to be installed
      Depends: python3-pyside2.qtgui but it is not going to be installed
      Depends: python3-pyside2.qtcore but it is not going to be installed
      python3-sip : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-vtk9 : Depends: python3-mpi4py but it is not going to be installed
      qtbase5-dev : Depends: qt5-qmake (= 5.15.3+dfsg-2ubuntu0.2) but 5.15.13+dfsg-1ubuntu1 is to be installed
      ros-humble-demo-nodes-cpp-native : Depends: ros-humble-fastrtps but it is not installable
      Depends: ros-humble-rmw-fastrtps-cpp but it is not installable
      ros-humble-rviz-assimp-vendor : Depends: libassimp-dev but it is not installable
      E: Unable to correct problems, you have held broken packages.
      [][0.22s] libboost-iostreams1.74-dev : Depends: libboost-iostreams1.74.0 (= 1.74.0-14ubuntu3) but 1.74.0+ds1-2[-][0.26s] libopenjp2-7-dev : Depends: libopenjp2-7 (= 2.4.0-6ubuntu0.3) but 2.5.0-2ubuntu0.3 is to be installe[][0.26s] libpulse-dev : Depends: libpulse0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but 1:16.1+dfsg1-2ubuntu10.1 is to [|][0.26s] Depends: libpulse-mainloop-glib0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but it is not going t[-][0.26s] Depends: libwebpdemux2 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be install[/][0.26s] qtbase5-dev : Depends: qt5-qmake (= 5.15.3+dfsg-2ubuntu0.2) but 5.15.13+dfsg-1ubuntu1 is to be insta[-][0.26s] CMD Result:code:100 e
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo
      aptitude install ros-humble-desktop)
      确认了解情况,请输入回车继续安装
        从错误信息来看,你在安装 ROS 2 Humble 时遇到了依赖关系问题。这通常是由于系统中的某些软件包版本与 ROS 2 Humble 所需的版本不兼容所致。错误信息指出多个软件包存在依赖冲突,特别是与 Python 3 的版本、libnetcdf-dev、libssl-dev 等相关。
        以下是一些解决此问题的建议步骤:
        1. 更新系统软件包列表和升级现有软件包:
          sudo apt update
          sudo apt upgrade
        2. 尝试使用 aptitude 而不是 apt 来安装:
          aptitude 在处理依赖关系方面通常比 apt 更智能,能够尝试找到更多的解决方案。按照错误提示,你可以尝试:
          sudo aptitude install ros-humble-desktop
        3. 手动解决依赖问题:
          如果 aptitude 仍然无法解决问题,你可能需要手动安装或降级某些依赖包。根据错误信息,你可能需要安装或指定特定版本的软件包,例如:
          sudo apt install libssl-dev=特定版本
          sudo apt install libnetcdf-dev=特定版本  # 注意:如果 libnetcdf-dev 不可用,可能需要查找替代方案或安装源
        4. 检查 Ubuntu 版本和 ROS 2 Humble 的兼容性:
          确保你的 Ubuntu 版本与 ROS 2 Humble 兼容。ROS 2 Humble 官方支持的 Ubuntu 版本通常是较新的 LTS 版本。如果你的 Ubuntu 版本较旧,可能需要升级到支持的版本。
        5. 使用 Docker 或虚拟机:
          如果直接在主机上安装遇到困难,考虑使用 Docker 或虚拟机来运行 ROS 2。这可以提供一个干净的环境,避免依赖冲突。
        6. 查看 ROS 社区和论坛:
          ROS 社区和论坛可能有人遇到过类似的问题,并分享了解决方案。
        在执行上述步骤后,如果问题仍未解决,请确保备份重要数据,并考虑寻求更专业的帮助或考虑使用不同的安装方法。
