    在chapter6的gazebo_sim.launch.py文件运行时报错,好像是gzclient打不开,gazebo也崩溃了
    gzclient gazebo崩溃
    2.5k
      指令$ ros2 launch robot_description gazebo_sim.launch.py
      结果:
      [INFO] [launch]: All log files can be found below /home/wang/.ros/log/2025-02-05-21-11-13-932937-wang-virtual-machine-3572
      [INFO] [robot_state_publisher-1]: process started with pid [3574]
      [INFO] [gzserver-2]: process started with pid [3576]
      [INFO] [gzclient-3]: process started with pid [3578]
      [INFO] [spawn_entity.py-4]: process started with pid [3580]
      [robot_state_publisher-1] [INFO] [1738761074.465208698] [robot_state_publisher]: got segment back_caster_link
      [robot_state_publisher-1] [INFO] [1738761074.465372962] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-1] [INFO] [1738761074.465381068] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1738761074.465386809] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-1] [INFO] [1738761074.465408091] [robot_state_publisher]: got segment front_caster_link
      [robot_state_publisher-1] [INFO] [1738761074.465413021] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-1] [INFO] [1738761074.465416979] [robot_state_publisher]: got segment laser_cylinder_link
      [robot_state_publisher-1] [INFO] [1738761074.465420826] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-1] [INFO] [1738761074.465424393] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-1] [INFO] [1738761074.465428121] [robot_state_publisher]: got segment right_wheel_link
      [gzclient-3]
      [gzserver-2]
      [spawn_entity.py-4] [INFO] [1738761074.757372182] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-4] [INFO] [1738761074.757749235] [spawn_entity]: Loading entity published on topic /robot_description
      [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
      [spawn_entity.py-4] warnings.warn(
      [spawn_entity.py-4] [INFO] [1738761074.759794482] [spawn_entity]: Waiting for entity xml on /robot_description
      [spawn_entity.py-4] [INFO] [1738761074.773813422] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
      [spawn_entity.py-4] [INFO] [1738761074.774110207] [spawn_entity]: Waiting for service /spawn_entity
      [gzserver-2] [Msg] Waiting for master.
      [gzserver-2] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
      [gzserver-2] [Msg] Publicized address: 192.168.248.128
      [gzserver-2] [Err] [RTShaderSystem.cc:480] Unable to find shader lib. Shader generating will fail. Your GAZEBO_RESOURCE_PATH is probably improperly set. Have you sourced <prefix>/share/gazebo/setup.bash?
      [spawn_entity.py-4] [INFO] [1738761075.530248963] [spawn_entity]: Calling service /spawn_entity
      [gzclient-3] [Msg] Publicized address: 192.168.248.128
      [gzclient-3] [Err] [RTShaderSystem.cc:480] Unable to find shader lib. Shader generating will fail. Your GAZEBO_RESOURCE_PATH is probably improperly set. Have you sourced <prefix>/share/gazebo/setup.bash?
      [gzclient-3] [Wrn] [GuiIface.cc:120] QSocketNotifier: Can only be used with threads started with QThread
      [spawn_entity.py-4] [INFO] [1738761075.772798805] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [Wrobot]
      [gzserver-2] [INFO] [1738761075.787871804] [diff_drive]: Wheel pair 1 separation set to [0.200000m]
      [gzserver-2] [INFO] [1738761075.788372420] [diff_drive]: Wheel pair 1 diameter set to [0.064000m]
      [gzserver-2] [INFO] [1738761075.789731446] [diff_drive]: Subscribed to [/cmd_vel]
      [gzserver-2] [INFO] [1738761075.792849377] [diff_drive]: Advertise odometry on [/odom]
      [gzserver-2] [INFO] [1738761075.795760529] [diff_drive]: Publishing odom transforms between [odom] and [base_footprint]
      [gzserver-2] [INFO] [1738761075.795813804] [diff_drive]: Publishing wheel transforms between [base_footprint], [left_wheel_joint] and [right_wheel_joint]
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/.gazebo/models/wp_map_tools"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/.gazebo/models/wpr_simulation2"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/config"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/include"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/launch"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/src"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/urdf"
      [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wang/chapter6/chapter6_ws/src/robot_description/world"
      [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 3580]
      [gzclient-3] [Err] [RenderEngine.cc:197] Failed to initialize scene
      [gzclient-3] [Err] [GLWidget.cc:177] GLWidget could not create a scene. This will likely result in a blank screen.
      [gzclient-3] [Err] [WindowManager.cc:132] Unable to create the rendering window
      [gzclient-3] [Err] [WindowManager.cc:139] EXCEPTION: Unable to create the rendering window
      [gzclient-3]
      [gzclient-3]
      [gzclient-3] terminate called after throwing an instance of 'gazebo::common::Exception'
      [ERROR] [gzclient-3]: process has died [pid 3578, exit code -6, cmd 'gzclient --verbose'].
      [gzclient-3]
        从您提供的日志信息来看,有几个关键问题导致了 gzclient 无法正常启动并崩溃:
        1. Shader 库找不到:
          这通常意味着 GAZEBO_RESOURCE_PATH 环境变量没有正确设置,或者相关的资源文件没有正确安装。您需要确保已经正确安装了 Gazebo,并且环境变量设置正确。通常,您需要在终端中运行以下命令来设置环境变量:
          source /opt/ros/humble/local/share/gazebo/setup.bash
          这些路径可能因您的安装方式和位置而异,请根据实际情况调整。
        2. 模型配置文件缺失:
          这些错误表明 Gazebo 试图加载一些模型,但找不到它们的配置文件。这可能是因为这些模型没有被正确安装或者路径指向了错误的位置。检查您的 URDF 或世界文件中引用的模型路径是否正确,并确保这些模型存在于指定的路径中。
        3. 渲染窗口创建失败:
          这通常与图形驱动或 OpenGL 设置有关。确保您的系统支持 OpenGL,并且图形驱动是最新的。此外,检查是否有任何图形相关的错误或警告信息在终端输出。
        解决步骤:
        1. 重新检查并设置环境变量:
          确保所有相关的 ROS 和 Gazebo 环境变量都已正确设置。
        2. 验证模型路径:
          检查您的 URDF 和世界文件,确保所有引用的模型路径都是正确的。如果模型是自定义的,确保它们已经被正确安装和配置。
        3. 更新图形驱动:
          确保您的图形驱动是最新的,并且与您的操作系统和硬件兼容。
        4. 重新运行 Gazebo:
          在解决了上述问题后,尝试重新运行您的 Gazebo 启动文件。
        如果问题仍然存在,您可能需要更详细地检查 Gazebo 的配置文件或寻求社区的帮助。
          1164894579 @小伊
          @小伊
          输入
          gazebo
          输出
          context mismatch in svga_surface_destroy
          这又是什么问题
            您提到的输入“gazebo”和输出“context mismatch in svga_surface_destroy”之间似乎没有直接的关联。这里分别解释一下这两个概念,并尝试分析可能的背景或原因。
            Gazebo
            Gazebo 是一个开源的机器人模拟器,广泛用于机器人系统、无人驾驶汽车、无人机等领域的开发和测试。它提供了一个高保真度的物理仿真环境,允许开发者在虚拟环境中测试他们的机器人算法和控制系统。
            svga_surface_destroy 和 Context Mismatch
            • svga_surface_destroy 可能是指在使用 SVGA(一种图形加速技术或库)时,用于销毁或释放图形表面的函数。这种技术或库通常用于图形渲染,尤其是在游戏或复杂图形应用中。
            • Context Mismatch 错误通常发生在图形上下文(OpenGL、Vulkan等图形API中的渲染上下文)被错误管理时。例如,尝试在一个渲染上下文中创建的对象上执行另一个上下文的操作,或者在销毁对象后仍然尝试使用它。
            可能的问题背景
            如果您在使用 Gazebo 的过程中遇到了 “context mismatch in svga_surface_destroy” 的错误,这可能意味着 Gazebo 在尝试管理或渲染图形时遇到了问题。可能的原因包括:
            1. 图形驱动问题:您的图形驱动可能不兼容或过时,导致 Gazebo 无法正确管理图形资源。
            2. 多GPU环境:如果您的系统有多个GPU,并且 Gazebo 或其依赖的图形库没有正确处理这种情况,可能会出现上下文不匹配的错误。
            3. 软件或库版本冲突:安装的某个库或软件可能与 Gazebo 不兼容,特别是在图形渲染方面。
            解决步骤
            1. 更新图形驱动:确保您的图形驱动是最新的,并且与您的硬件和操作系统兼容。
            2. 检查 Gazebo 和依赖库的版本:确保您安装的 Gazebo 和所有相关依赖库都是最新版本,或者至少是彼此兼容的版本。
            3. 单GPU运行:如果可能,尝试在只有一个GPU的环境中运行 Gazebo,看看问题是否仍然存在。
            4. 查看日志和错误报告:更详细地查看 Gazebo 的日志文件和系统错误报告,以获取更多关于何时何地发生错误的线索。
            5. 寻求社区帮助:如果问题仍然存在,考虑在 Gazebo 的用户论坛或社区中寻求帮助,那里可能有其他开发者遇到过类似的问题。
            希望这些信息对您有所帮助!如果还有其他具体的问题或错误日志,请提供更多信息以便进一步分析。
            • H
              haile.huang
              ros2@ros2-virtual-machine:~/gazebo7/gazebo7_ws$ ros2 launch fishbot_description gazebo_sim.launch.py
              [INFO] [launch]: All log files can be found below /home/ros2/.ros/log/2025-04-07-23-46-46-340059-ros2-virtual-machine-3547
              [INFO] [robot_state_publisher-1]: process started with pid [3552]
              [INFO] [gzserver-2]: process started with pid [3554]
              [INFO] [gzclient-3]: process started with pid [3556]
              [INFO] [spawn_entity.py-4]: process started with pid [3558]
              [robot_state_publisher-1] [INFO] [1744040807.377159369] [robot_state_publisher]: got segment back_caster_link
              [robot_state_publisher-1] [INFO] [1744040807.377316455] [robot_state_publisher]: got segment base_footprint
              [robot_state_publisher-1] [INFO] [1744040807.377330418] [robot_state_publisher]: got segment base_link
              [robot_state_publisher-1] [INFO] [1744040807.377335661] [robot_state_publisher]: got segment camera_link
              [robot_state_publisher-1] [INFO] [1744040807.377342463] [robot_state_publisher]: got segment camera_optical_link
              [robot_state_publisher-1] [INFO] [1744040807.377346971] [robot_state_publisher]: got segment front_caster_link
              [robot_state_publisher-1] [INFO] [1744040807.377351362] [robot_state_publisher]: got segment imu_link
              [robot_state_publisher-1] [INFO] [1744040807.377355076] [robot_state_publisher]: got segment laser_cylinder_link
              [robot_state_publisher-1] [INFO] [1744040807.377361287] [robot_state_publisher]: got segment laser_link
              [robot_state_publisher-1] [INFO] [1744040807.377365427] [robot_state_publisher]: got segment left_wheel_link
              [robot_state_publisher-1] [INFO] [1744040807.377369403] [robot_state_publisher]: got segment right_wheel_link
              [spawn_entity.py-4] [INFO] [1744040807.856921505] [spawn_entity]: Spawn Entity started
              [spawn_entity.py-4] [INFO] [1744040807.857448486] [spawn_entity]: Loading entity published on topic /robot_description
              [spawn_entity.py-4] [INFO] [1744040807.871811460] [spawn_entity]: Waiting for entity xml on /robot_description
              [spawn_entity.py-4] [INFO] [1744040807.894062623] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
              [spawn_entity.py-4] [INFO] [1744040807.894447124] [spawn_entity]: Waiting for service /spawn_entity
              [gzclient-3]
              [gzserver-2]
              [gzserver-2] [Wrn] [gazebo_ros_init.cpp:178]
              [gzserver-2] # # ####### ####### ### ##### #######
              [gzserver-2] ## # # # # # # # #
              [gzserver-2] # # # # # # # # #
              [gzserver-2] # # # # # # # # #####
              [gzserver-2] # ## # # # # # # #
              [gzserver-2] # # ####### # ### ##### #######
              [gzserver-2]
              [gzserver-2] This version of Gazebo, now called Gazebo classic, reaches end-of-life
              [gzserver-2] in January 2025. Users are highly encouraged to migrate to the new Gazebo
              [gzserver-2] using our migration guides (https://gazebosim.org/docs/latest/gazebo_classic_migration?utm_source=gazebo_ros_pkgs&utm_medium=cli)
              [gzserver-2]
              [gzserver-2]
              [gzclient-3] [Msg] Publicized address: 172.21.73.71
              [spawn_entity.py-4] [INFO] [1744040810.232075284] [spawn_entity]: Calling service /spawn_entity
              [gzclient-3] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
              [gzserver-2] [Msg] Publicized address: 172.21.73.71
              [gzserver-2] [Msg] Loading world file [/home/ros2/gazebo7/gazebo7_ws/install/fishbot_description/share/fishbot_description/world/custom_room.world]
              [gzserver-2] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
              [gzserver-2] [INFO] [1744040811.065571074] [depth_camera]: Publishing camera info to [/camera_sensor/camera_info]
              [gzserver-2] [INFO] [1744040811.066522094] [depth_camera]: Publishing depth camera info to [/camera_sensor/depth/camera_info]
              [gzserver-2] [INFO] [1744040811.066926896] [depth_camera]: Publishing pointcloud to [/camera_sensor/points]
              [gzclient-3]
              [gzclient-3]
              [spawn_entity.py-4] [INFO] [1744040811.432639054] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
              [gzserver-2] [INFO] [1744040811.571190276] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin
              [gzserver-2] [INFO] [1744040811.582191083] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in namespace: /
              [gzserver-2] [INFO] [1744040811.582267983] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros2_control
              [gzserver-2] [INFO] [1744040811.594804268] [gazebo_ros2_control]: connected to service!! robot_state_publisher
              [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 3558]
              [gzserver-2] [INFO] [1744040811.598949066] [gazebo_ros2_control]: Received urdf from param server, parsing...
              [gzserver-2] [INFO] [1744040811.599012201] [gazebo_ros2_control]: Loading parameter files /home/ros2/gazebo7/gazebo7_ws/install/fishbot_description/share/fishbot_description/config/fishbot_ros2_controller.yaml
              [INFO] [ros2-5]: process started with pid [3689]
              [gzserver-2] [INFO] [1744040811.623055913] [gazebo_ros2_control]: Loading joint: left_wheel_joint
              [gzserver-2] [INFO] [1744040811.623122339] [gazebo_ros2_control]: State:
              [gzserver-2] [INFO] [1744040811.623132355] [gazebo_ros2_control]: position
              [gzserver-2] [INFO] [1744040811.623139197] [gazebo_ros2_control]: velocity
              [gzserver-2] [INFO] [1744040811.623144468] [gazebo_ros2_control]: effort
              [gzserver-2] [INFO] [1744040811.623153684] [gazebo_ros2_control]: Command:
              [gzserver-2] [INFO] [1744040811.623774784] [gazebo_ros2_control]: velocity
              [gzserver-2] [INFO] [1744040811.624008631] [gazebo_ros2_control]: effort
              [gzserver-2] [INFO] [1744040811.624028777] [gazebo_ros2_control]: Loading joint: right_wheel_joint
              [gzserver-2] [INFO] [1744040811.624035477] [gazebo_ros2_control]: State:
              [gzserver-2] [INFO] [1744040811.624040860] [gazebo_ros2_control]: position
              [gzserver-2] [INFO] [1744040811.624049887] [gazebo_ros2_control]: velocity
              [gzserver-2] [INFO] [1744040811.624055967] [gazebo_ros2_control]: effort
              [gzserver-2] [INFO] [1744040811.624060962] [gazebo_ros2_control]: Command:
              [gzserver-2] [INFO] [1744040811.624069363] [gazebo_ros2_control]: velocity
              [gzserver-2] [INFO] [1744040811.624195869] [gazebo_ros2_control]: effort
              [gzserver-2] [INFO] [1744040811.624252902] [resource_manager]: Initialize hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.624399908] [resource_manager]: Successful initialization of hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.624490014] [resource_manager]: 'configure' hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.624500280] [resource_manager]: Successful 'configure' of hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.624505277] [resource_manager]: 'activate' hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.624509810] [resource_manager]: Successful 'activate' of hardware 'FishBotGazeboSystem'
              [gzserver-2] [INFO] [1744040811.625969242] [gazebo_ros2_control]: Loading controller_manager
              [gzserver-2] [WARN] [1744040811.697825097] [gazebo_ros2_control]: Desired controller update period (0.01 s) is slower than the gazebo simulation period (0.001 s).
              [gzserver-2] [INFO] [1744040811.698014270] [gazebo_ros2_control]: Loaded gazebo_ros2_control.
              [ERROR] [gzclient-3]: process has died [pid 3556, exit code -6, cmd 'gzclient --gui-client-plugin=libgazebo_ros_eol_gui.so --verbose'].
              [gzclient-3]
              [gzserver-2] [INFO] [1744040812.658632607] [controller_manager]: Loading controller 'fishbot_joint_state_broadcaster'
              [gzserver-2] [INFO] [1744040812.699560842] [controller_manager]: Configuring controller 'fishbot_joint_state_broadcaster'
              [gzserver-2] [INFO] [1744040812.700391520] [fishbot_joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
              [ros2-5] Successfully loaded controller fishbot_joint_state_broadcaster into state active
              [INFO] [ros2-5]: process has finished cleanly [pid 3689]
              [INFO] [ros2-6]: process started with pid [3731]
              [ros2-6] [INFO] [1744040813.862104856] [_ros2cli_3731]: waiting for service /controller_manager/load_controller to become available...
              [gzserver-2] [INFO] [1744040815.114848376] [controller_manager]: Loading controller 'fishbot_diff_drive_controller'
              [gzserver-2] [INFO] [1744040815.156646427] [controller_manager]: Configuring controller 'fishbot_diff_drive_controller'
              [ros2-6] Successfully loaded controller fishbot_diff_drive_controller into state active
              [INFO] [ros2-6]: process has finished cleanly [pid 3731]
              [gzserver-2] [Wrn] [Publisher.cc:135] Queue limit reached for topic /gazebo/default/pose/local/info, deleting message. This warning is printed only once.
              请问这个报错怎么解决呢
