    自定义通信接口例子中 SystemStatus.msg构建功能包时报错 CMakeLists.txt:16 (rosidl_generate_interfaces),哪位i大神能否指点下?非常感谢
    通信接口例子中构建功能包时报错 ros2学习
    • D
      davidliu77
      自定义通信接口例子,SystemStatus.msg 构建功能包时,命令行
      colcon build --packages-select status_interfaces
      报错信息如下:
      Starting >>> status_interfaces
      --- stderr: status_interfaces
      CMake Error at /opt/ros/jazzy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:234 (list):
      list index: 1 out of range (-1, 0)
      CMake Error at /opt/ros/jazzy/share/rosidl_generator_type_description/cmake/rosidl_generator_type_description_generate_interfaces.cmake:68 (message):
      Target dependency
      '/ROS2/pkg_ws/build/status_interfaces/rosidl_adapter/status_interfaces/msg/SystemStatus.idl'
      does not exist
      /opt/ros/jazzy/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
      /opt/ros/jazzy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:280 (ament_execute_extensions)
      操作步骤如下:
      1.使用下面命令创建工作区间后
      ros2 pkg create status_interfaces --build-type ament_cmake --dependencies rosidl_default_generators builtin_interfaces --license Apache-2.0
      2.建立文件 status_interfaces/msg/SystemStatus.msg
      3.CMLists.txt内容如下
      project(status_interfaces)
      endif()
      find dependencies
      find_package(rclcpp REQUIRED)
      find_package(builtin_interfaces REQUIRED)
      "msg/SystemStatus.msg"
      DEPENDENCIES builtin_interfaces
      if(BUILD_TESTING)
      the following line skips the linter which checks for copyrights
      comment the line when a copyright and license is added to all source files
      the following line skips cpplint (only works in a git repo)
      comment the line when this package is in a git repo and when
      endif()
      ament_package()
      4.package.xml内容如下
      <?xml version="1.0"?>
      <package format="3">
      <name>status_interfaces</name>
      <version>0.0.0</version>
      <maintainer email="d@todo.todo">d</maintainer>
      <license>Apache-2.0</license>
      <depend>rclcpp</depend>
      <depend>std_msgs</depend>
      <build_depend>rosidl_default_generators</build_depend>
      <exec_depend>rosidl_default_runtime</exec_depend>
      <depend>builtin_interfaces</depend>
      <export>
      </export>
      </package>
        从你提供的错误信息和构建步骤来看,这里有几个潜在的问题和改进点:
        1. CMakeLists.txt 中的依赖项:
          • 你在 CMakeLists.txt 中包含了 find_package(rclcpp REQUIRED) 和 find_package(std_msgs REQUIRED),但这两个包在生成消息接口时并不是必需的。rclcpp 是用于 ROS 2 客户端库的,而 std_msgs 包含了标准消息类型。对于你的自定义消息包,这些依赖是不必要的。
        2. 错误的依赖声明:
          • 在 rosidl_generate_interfaces 调用中,你指定了 DEPENDENCIES builtin_interfaces。这通常是正确的,但错误可能源于其他配置问题或版本不兼容。
        3. CMake 和 ROS 2 版本兼容性:
          • 错误信息中提到了列表索引超出范围,这可能是由于 ROS 2 的某个版本与你的 CMakeLists.txt 配置不兼容。确保你的 ROS 2 环境是最新的,或者至少是与你的教程或示例代码兼容的版本。
        4. 清理和重建:
          • 有时候,旧的构建文件可能会导致问题。尝试完全清理你的工作空间(删除 build 和 install 文件夹),然后重新构建。
        5. 检查 SystemStatus.msg 文件:
          • 确保 SystemStatus.msg 文件格式正确,没有语法错误。
        6. 更新 package.xml:
          • 你的 package.xml 中包含了不必要的依赖,如 rclcpp 和 std_msgs。这些应该只在需要使用这些库的功能时才包含。
        下面是一个简化和更新的 CMakeLists.txt 和 package.xml 示例:
        CMakeLists.txt
        # 默认设置编译选项
        endif()
        # 查找必需的包
        # 生成接口
        install(TARGETS
          ${PROJECT_NAME}__msg__target
        ament_package()
        package.xml
          <description>The status_interfaces package</description>
          <maintainer email="your_email@todo.todo">your_name</maintainer>
          <export>
          </export>
        </package>
        请确保你的 ROS 2 环境设置正确,并且所有依赖项都已正确安装。然后尝试再次构建你的包。如果问题仍然存在,请检查 ROS 2 的版本和任何已知的兼容性问题。
