    wsl2所有有图形界面的程序都打不开,显示This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
    报错问题 求助
    1.2k
      QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms" ...
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqeglfs.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqeglfs.so, metadata=
      "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
      "MetaData": {
      "Keys": [
      "eglfs"
      "archreq": 0,
      "className": "QEglFSIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("eglfs")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so, metadata=
      "MetaData": {
      "Keys": [
      "linuxfb"
      "archreq": 0,
      "className": "QLinuxFbIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("linuxfb")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimal.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimal.so, metadata=
      "MetaData": {
      "Keys": [
      "minimal"
      "archreq": 0,
      "className": "QMinimalIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("minimal")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so, metadata=
      "MetaData": {
      "Keys": [
      "minimalegl"
      "archreq": 0,
      "className": "QMinimalEglIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("minimalegl")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so, metadata=
      "MetaData": {
      "Keys": [
      "offscreen"
      "archreq": 0,
      "className": "QOffscreenIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("offscreen")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqvnc.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqvnc.so, metadata=
      "MetaData": {
      "Keys": [
      "vnc"
      "archreq": 0,
      "className": "QVncIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("vnc")
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
      Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so, metadata=
      "MetaData": {
      "Keys": [
      "xcb"
      "archreq": 0,
      "className": "QXcbIntegrationPlugin",
      "debug": false,
      "version": 331520
      Got keys from plugin meta data ("xcb")
      QFactoryLoader::QFactoryLoader() checking directory path "/opt/ros/humble/lib/turtlesim/platforms" ...
      loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
      qt.qpa.xcb: could not connect to display
      qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
      Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
        您遇到的问题是在尝试在 WSL2(Windows Subsystem for Linux 2)中运行具有图形界面的 Qt 应用程序时,无法初始化 Qt 平台插件。这通常是因为 WSL2 不直接支持图形用户界面(GUI)。尽管 WSL2 改进了对 Linux 内核功能的支持,但它仍然运行在 Windows 的内部,并且没有直接访问 Windows 的图形显示服务器。
        错误信息表明 Qt 试图使用 xcb 平台插件(这是用于 X Window System 的插件),但无法连接到显示服务器。在 WSL2 中,没有默认的 X 服务器运行,因此无法显示 GUI。
        解决方案
        1. 使用 X Server for Windows:
          • 您可以在 Windows 上安装一个 X Server,如 VcXsrv、Xming 或 X410。这些工具允许 Windows 主机作为 X 服务器运行,从而可以显示 Linux GUI 应用程序。
          • 安装后,启动 X 服务器,并确保它配置为接受来自 WSL2 的连接。
          • 在 WSL2 中,设置 DISPLAY 环境变量以指向 Windows 上的 X 服务器。通常,这可以通过运行 export DISPLAY=$(hostname -I | awk '{print $1}'):0.0 来完成(假设 X 服务器运行在默认端口上)。
        2. 使用 Windows Subsystem for Linux GUI (WSLg):
          • 从 Windows 11 版本 21H2 开始,微软引入了 WSLg,它内置了对 GUI 应用程序的支持。如果您的 Windows 版本支持 WSLg,您可以尝试安装或更新到支持 WSLg 的 WSL 版本。
          • 确保您的 WSL 发行版是基于 WSLg 的。在 Windows 功能中启用 WSLg 后,您可能需要重新安装或更新您的 Linux 发行版。
        3. 远程 X11 会话:
          • 如果可能,考虑将 GUI 应用程序运行在远程 Linux 服务器上,并通过 SSH 和 X11 转发来显示 GUI。这通常用于开发环境,其中有一个专用的服务器用于运行 GUI 密集型应用程序。
        实施步骤示例(使用 VcXsrv)
        1. 下载并安装 VcXsrv。
        2. 启动 VcXsrv,在“Extra settings”中选择“Disable access control”。
        3. 在 WSL2 中,设置 DISPLAY 变量并运行您的 Qt 应用程序:
          ./your-qt-application
        确保您的防火墙设置允许这种类型的连接,并且您的网络配置不会阻止 WSL2 与 Windows 主机上的 X 服务器通信。
