    9.5.5 完成机器人建图并保存地图。问题:'discarding message because the queue is full', no map received
    9.5.5章节 queue is full no map
    • 9
      905399126
      最后由 905399126 编辑
      我在执行完ros2 launch fishbot_bringup bringup.launch.py已经看到雷达正在运行提示了。
      这时我运行:ros2 launch slam_toolbox online_async_launch.py use_sim_time:=False.提示:
      [async_slam_toolbox_node-1] [INFO] [1743240557.095263110] [slam_toolbox]: Message Filter dropping message: frame 'laser_link' at time 1743240556.855 for reason 'discarding message because the queue is full'
      [async_slam_toolbox_node-1] [INFO] [1743240557.213141763] [slam_toolbox]: Message Filter dropping message: frame 'laser_link' at time 1743240556.974 for reason 'discarding message because the queue is full'。
      这时我再打开rviz2,添加map后,提示no map received。
