    ROS与Qt冲突
    ros2 qt qt出错
    1.1k
      最后由 1511482029 编辑
      3.4.5订阅数据并用Qt显示
      按照书本编写程序,运行节点的时候报警:
      QSocketNotifier: Can only be used with threads started with QThread
      /home/mr/ros2/chapt3/topic_practice_ws/install/status_display/lib/status_display/sys_status_display: symbol lookup error: /snap/core20/current/lib/x86_64-linux-gnu/libpthread.so.0: undefined symbol: __libc_pthread_init, version GLIBC_PRIVATE
      [ros2run]: Process exited with failure 127
      以下为代码:
      #include <QApplication>
      #include <QLabel>
      #include <QString>
      #include "rclcpp/rclcpp.hpp"
      #include "status_interfaces/msg/system_status.hpp"
      using SystemStatus = status_interfaces::msg::SystemStatus;```
      class SysStatusDisplay : public rclcpp::Node{
      public:
      SysStatusDisplay() : Node("sys_status_display"){
      subscription_ =this->create_subscription<SystemStatus>(
      "sys_status",10,[&](const SystemStatus::SharedPtr msg) -> void{
      label_ -> setText(get_qstr_from_msg(msg));
      //创建一个空的SystemStatus 对象,转换成QS人tring 进行显示
      label_ = new QLabel(get_qstr_from_msg(std::make_shared<SystemStatus>()));
      label_->show();
      QString get_qstr_from_msg(const SystemStatus::SharedPtr msg){
      //TODO: 将msg中的内容提出出来并组装成字符串
      std::stringstream show_str;
      show_str
      <<"===========系统状态可视化显示工具===========\n"
      << "数据时间\t" << msg->stamp.sec << "\ts\n"
      << "用 户 名\t" << msg->host_name << "\t\n"
      << "CPU使用率\t" <<msg->cpu_percent << "\t%\n"
      << "内存使用率\t" <<msg->memory_percent << "\t%\n"
      << "内存总大小\t" << msg->memory_total <<"\tMB\n"
      << "剩余有效内存\t" << msg->memory_available << "\tMB\n"
      << "网络发送量\t" <<msg->net_sent <<"\tMB\n"
      << "网络接收量\t"<<msg->net_recv << "\tMB\n"
      return QString::fromStdString(show_str.str());
      private:
      rclcpp::Subscription<SystemStatus>::SharedPtr subscription_;
      QLabel* label_;
      int main(int argc,char* argv[]){
      rclcpp::init(argc,argv);
      QApplication app(argc,argv);
      auto node = std::make_shared<SysStatusDisplay>();
      std::thread spin_thread(& -> void
      rclcpp::spin(node);
      spin_thread.detach();
      app.exec();
      rclcpp::shutdown();
      return 0;
      CMakeLists.txt:
      project(status_display)
      endif()
      find_package(rclcpp REQUIRED)
      find_package(status_interfaces REQUIRED)
      find_package(Qt5 REQUIRED COMPONENTS Widgets)
      add_executable(hello_qt src/hello_qt.cpp)
      add_executable(sys_status_display src/sys_status_display.cpp)
      target_link_libraries(sys_status_display Qt5::Widgets) #对于非ROS功能使用Cmake原生指令进行链接库
      ament_target_dependencies(sys_status_display rclcpp status_interfaces)
      target_link_libraries(hello_qt
      Qt5::Widgets
      if(BUILD_TESTING)
      source files
      endif()
      install(TARGETS
      hello_qt
      sys_status_display
      ament_package()
      package.xml:
      <?xml version="1.0"?>
      <package format="3">
      <name>status_display</name>
      <version>0.0.0</version>
      <maintainer email="mr@todo.todo">mr</maintainer>
      <license>Apche-2.0</license>
      <depend>qtbase5-dev</depend>
      <depend>rclcpp</depend>
      <depend>status_interfaces</depend>
      <export>
      </export>
      </package>
      Ubuntu版本:Ubuntu 24.04.2 LTS
      ROS2版本:jazzy
      问过deepseek和文心一言,文心一言表示可能是因为detach()别用;可以改称spin_thread.join(),可没有效果,反馈后又说别用join和detach。deepseek则用QObject这种还没有接触到的,可能是操作步骤少了或者有问题deepseek方案照抄了也没有用。
      F 1 条回复 最后回复 回复 引用 0
      • F
        fishfly @1511482029
        @1511482029 可能是因为使用了snap安装VScode造成的,建议卸载后重新从官网下载
