    代码报错
    机器人学
    代码 colcon build
      sunrise@ubuntu:~/Desktop/stm32_communication$ colcon build
      Starting >>> stm32_communication
      [Processing: stm32_communication]
      --- stderr: stm32_communication
      gmake: 警告:文件“Makefile”的修改时间在未来 797342943 秒后
      gmake[1]: 警告:文件“CMakeFiles/Makefile2”的修改时间在未来 797342943 秒后
      gmake[2]: 警告:文件“CMakeFiles/stm32_serial_node.dir/flags.make”的修改时间在未来 797342396 秒后
      gmake[2]: 警告:检测到时钟错误。您的构建版本可能是不完整的。
      gmake[2]: 警告:文件“CMakeFiles/stm32_serial_node.dir/flags.make”的修改时间在未来 797342395 秒后
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp: In constructor ‘Stm32Communicator::Stm32Communicator()’:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:36:27: error: ‘class drivers::serial_driver::SerialPort’ has no member named ‘init_port’
      36 | serial_port_->init_port(port, {baud_rate, fc, pt, sb});
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:38:32: error: ‘class drivers::serial_driver::SerialPort’ has no member named ‘port_open’
      38 | if (!serial_port_->port_open()) {
      In file included from /opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:24,
      from /opt/ros/humble/include/rclcpp/rclcpp/client.hpp:40,
      from /opt/ros/humble/include/rclcpp/rclcpp/callback_group.hpp:24,
      from /opt/ros/humble/include/rclcpp/rclcpp/any_executable.hpp:20,
      from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategy.hpp:25,
      from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategies.hpp:18,
      from /opt/ros/humble/include/rclcpp/rclcpp/executor_options.hpp:20,
      from /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:37,
      from /opt/ros/humble/include/rclcpp/rclcpp/executors/multi_threaded_executor.hpp:25,
      from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:21,
      from /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:3:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:42:39: warning: format ‘%d’ expects argument of type ‘int’, but argument 6 has type ‘long int’ [-Wformat=]
      42 | RCLCPP_INFO(get_logger(), "Serial port %s opened at %d baud",
      43 | port.c_str(), baud_rate);
      | long int
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:42:66: note: format string is defined here
      | int
      | %ld
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp: In lambda function:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:67:58: error: ‘using element_type = class drivers::common::IoContext’ {aka ‘class drivers::common::IoContext’} has no member named ‘run’
      67 | io_thread_ = std::thread(this { io_context_->run(); });
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp: In destructor ‘virtual Stm32Communicator::~Stm32Communicator()’:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:72:22: error: ‘using element_type = class drivers::common::IoContext’ {aka ‘class drivers::common::IoContext’} has no member named ‘stop’
      72 | io_context_->stop();
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp: In member function ‘void Stm32Communicator::read_from_stm32()’:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:119:28: error: ‘class drivers::serial_driver::SerialPort’ has no member named ‘port_open’
      119 | if (!serial_port_->port_open()) return;
      In file included from /usr/include/c++/11/memory:76,
      from /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:1:
      /usr/include/c++/11/bits/unique_ptr.h: In instantiation of ‘typename std::_MakeUniq<_Tp>::__single_object std::make_unique(_Args&& ...) [with _Tp = drivers::serial_driver::SerialPort; _Args = {drivers::common::IoContext&}; typename std::_MakeUniq<_Tp>::__single_object = std::unique_ptrdrivers::serial_driver::SerialPort]’:
      /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:18:72: required from here
      /usr/include/c++/11/bits/unique_ptr.h:962:30: error: no matching function for call to ‘drivers::serial_driver::SerialPort::SerialPort(drivers::common::IoContext&)’
      962 | { return unique_ptr<_Tp>(new _Tp(std::forward<_Args>(__args)...)); }
      In file included from /opt/ros/humble/include/serial_driver/serial_driver.hpp:22,
      from /home/sunrise/Desktop/stm32_communication/src/stm32_communicate.cpp:5:
      /opt/ros/humble/include/serial_driver/serial_port.hpp:173:3: note: candidate: ‘drivers::serial_driver::SerialPort::SerialPort(const drivers::common::IoContext&, const string&, drivers::serial_driver::SerialPortConfig)’
      173 | SerialPort(
      /opt/ros/humble/include/serial_driver/serial_port.hpp:173:3: note: candidate expects 3 arguments, 1 provided
      gmake[2]: *** [CMakeFiles/stm32_serial_node.dir/build.make:76:CMakeFiles/stm32_serial_node.dir/src/stm32_communicate.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:137:CMakeFiles/stm32_serial_node.dir/all] 错误 2
      Failed <<< stm32_communication [42.6s, exited with code 2]
      Summary: 0 packages finished [45.5s]
      1 package failed: stm32_communication
      1 package had stderr output: stm32_communication
      @小伊
