    为啥git clone模型了,还是会出现这些问题?
    ros2 gazebo ros2启动
    1.0k
    • Y
      yunduo_12
      gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/zephyr_delta_wing]
      [gzclient-3] [Wrn] [Publisher.cc:135] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/iris_with_standoffs_demo/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/iris_with_standoffs_demo]
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/stereo_camera/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/stereo_camera]
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/wooden_case/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/wooden_case]
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/robocup_spl_ball/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/robocup_spl_ball]
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/drc_practice_door_4x8/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/drc_practice_door_4x8]
      [gzclient-3] [Wrn] [ModelDatabase.cc:212] Unable to connect to model database using [http://models.gazebosim.org/disk_part/model.config]. Only locally installed models will be available.
      [gzclient-3] [Err] [ModelDatabase.cc:394] Unable to get model name[http://models.gazebosim.org/disk_part]
      ^[[B^[[B^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
      [robot_state_publisher-1] [INFO] [1745992845.540325384] [rclcpp]: signal_handler(signum=2)
      [INFO] [robot_state_publisher-1]: process has finished cleanly [pid 36983]
