    使用一键安装过程中遇到程序崩溃(树莓派,换源)
    一键安装 换源
    1.9k
    • 23715639892
      阳光君
      系统版本
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=Raspbian
      ID_LIKE=Debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      报错信息:
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 415, in run
      self.install_ros()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 402, in install_ros
      self.check_sys_source()
      File "/tmp/fishinstall/tools/tool_install_ros.py", line 218, in check_sys_source
      tool.change_sys_source()
      File "/tmp/fishinstall/tools/tool_config_system_source.py", line 180, in change_sys_source
      source = self.replace_source(failed_sources)
      File "/tmp/fishinstall/tools/tool_config_system_source.py", line 169, in replace_source
      source,template = self.get_source_by_system(system,codename,arch,failed_sources)
      File "/tmp/fishinstall/tools/tool_config_system_source.py", line 154, in get_source_by_system
      return fast_source[0],template
      IndexError: list index out of range
      23715639892 1 条回复 最后回复 回复 引用 0
      • 23715639892
        阳光君 @2371563989
        检测到当前系统:debian 架构:arm64 代号:buster,正在为你搜索适合的源...
        搜索到可用源:[]
        接下来将进行自动测速以为您选择最快的源:
