    ROS1 运行出现了奇怪的问题
    ros1 noetic 运行
      hzx@hzx:~/catkin_ws$ catkin_make
      Base path: /home/hzx/catkin_ws
      Source space: /home/hzx/catkin_ws/src
      Build space: /home/hzx/catkin_ws/build
      Devel space: /home/hzx/catkin_ws/devel
      Install space: /home/hzx/catkin_ws/install
      Running command: "make cmake_check_build_system" in "/home/hzx/catkin_ws/build"
      Running command: "make -j20 -l20" in "/home/hzx/catkin_ws/build"
      [ 50%] Building CXX object learning_communication/CMakeFiles/talker.dir/src/talker.cpp.o
      [100%] Linking CXX executable /home/hzx/catkin_ws/devel/lib/learning_communication/talker
      [100%] Built target talker
      hzx@hzx:~/catkin_ws$ source ./devel/setup.bash
      hzx@hzx:~/catkin_ws$ rosrun learning_communication talker
      Error in XmlRpcClient::writeRequest: write error (Connection refused).
      Error in XmlRpcDispatch::work: couldn't find source iterator
      [ERROR] [1748073702.812459570]: [registerPublisher] Failed to contact master at [localhost:11311]. Retrying...
      ^CError in XmlRpcClient::writeRequest: write error (Connection refused).
        2560941503 @3323633192
        @3323633192 +1
