    用到wsl运行ros2 run turtlesim turtlesim_node报错
    wsl 运行小海龟失败
    2.1k
      1635731080 年度VIP
      标题:无法用到wsl运行ros2 run turtlesim turtlesim_node
      提问模板:
      背景(可选):
      [在这里详细描述您遇到的问题。请确保您提供了足够的背景信息,以便其他人能够理解您的问题。]
      具体细节和上下文:
      PS C:\Users\Administrator> wsl
      xiangyang@DESKTOP-2KPADL6:/mnt/c/Users/Administrator$ ros2 run turtlesim turtlesim_node
      qt.qpa.xcb: could not connect to display
      qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
      This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb. [ros2run]: Aborted
      尝试过的解决方法:
      从网上以及的deep seek搜索解决方法,感觉不行;也没太弄明白如何一步步操作
      L 1 条回复 最后回复 回复 引用 0
        luqixuan 年度VIP @1635731080
        @1635731080 在Windows上安装X服务器
        https://sourceforge.net/projects/vcxsrv/
        配置VcXsrv(安装后操作):
        启动XLaunch,配置选项:
            选择"One large window"
            Display number设为0
            勾选"Disable access control"(关键步骤)
            其他保持默认
        在WSL中设置环境变量:
        echo "export DISPLAY=$(grep nameserver /etc/resolv.conf | awk '{print $2}'):0" >> ~/.bashrc
        source ~/.bashrc
        安装Qt依赖库:
        sudo apt update
        sudo apt install -y libxcb-xinerama0 libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-render-util0 libxcb-xkb1
        1 2 条回复 最后回复 回复 引用 1
          1635731080 年度VIP @luqixuan
            @luqixuan 好的非常感谢,可以啦
