    安装ros-humble-ros-gz-bridge包的时候出现有可安装候选的报错
    gazebo 仿真 安装问题 编译错误
    1.3k
      我在编译一个gazebo仿真项目的时候出现缺少包的情况,这个开源项目的环境是ros2Humble与我的系统环境一致,并且这个项目在intel的NUC工控机上能成功编译并且运行,但是在我自己的电脑上编译出现问题
      项目地址:https://github.com/robomaster-oss/rmoss_gazebo.git
      系统环境:
      Ubuntu22.04
      Ros2Humble
      笔记本双系统,非ARM架构
      spaaaaace@spaaaaace-DRA-XX:~/Code/HBUT2025_rm_vision/lc_navigation/lc_navigation_2025/simulation_ws$ colcon build
      Starting >>> rmoss_interfaces
      Starting >>> rmoss_gz_resources
      Starting >>> rmoss_gz_plugins
      Starting >>> rmoss_projectile_motion
      Starting >>> sdformat_tools
      Finished <<< rmoss_gz_resources [0.23s]
      Finished <<< rmoss_gz_plugins [0.25s]
      Finished <<< rmoss_projectile_motion [0.25s]
      Finished <<< sdformat_tools [0.62s]
      Starting >>> pb2025_robot_description
      Finished <<< pb2025_robot_description [0.06s]
      Finished <<< rmoss_interfaces [0.89s]
      Starting >>> rmoss_util
      Starting >>> rmoss_base
      Starting >>> rmoss_gz_base
      Starting >>> rmoss_gz_bridge
      Starting >>> rmoss_gz_cam
      Finished <<< rmoss_util [0.13s]
      Starting >>> rmoss_cam
      Finished <<< rmoss_base [0.13s]
      --- stderr: rmoss_gz_cam
      CMake Error at CMakeLists.txt:19 (find_package):
        By not providing "Findros_gz_bridge.cmake" in CMAKE_MODULE_PATH this
        project has asked CMake to find a package configuration file provided by
        "ros_gz_bridge", but CMake did not find one.
        Could not find a package configuration file provided by "ros_gz_bridge"
        with any of the following names:
          ros_gz_bridgeConfig.cmake
          ros_gz_bridge-config.cmake
        Add the installation prefix of "ros_gz_bridge" to CMAKE_PREFIX_PATH or set
        "ros_gz_bridge_DIR" to a directory containing one of the above files.  If
        "ros_gz_bridge" provides a separate development package or SDK, be sure it
        has been installed.
      Failed   <<< rmoss_gz_cam [0.36s, exited with code 1]
      Aborted  <<< rmoss_gz_base [0.41s]
      Aborted  <<< rmoss_gz_bridge [0.42s]
      Aborted  <<< rmoss_cam [0.40s]
      Summary: 8 packages finished [1.59s]
        1 package failed: rmoss_gz_cam
        3 packages aborted: rmoss_cam rmoss_gz_base rmoss_gz_bridge
        4 packages had stderr output: rmoss_cam rmoss_gz_base rmoss_gz_bridge rmoss_gz_cam
        2 packages not processed
      缺少ros_gz_bridge这个包,尝试通过apt安装:sudo apt install ros-humble-ros-gz-bridge
      报错
      spaaaaace@spaaaaace-DRA-XX:~/Code/HBUT2025_rm_vision/lc_navigation/lc_navigation_2025/simulation_ws$ sudo apt install ros-humble-ros-gz-bridge
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树... 完成
      正在读取状态信息... 完成
      没有可用的软件包 ros-humble-ros-gz-bridge,但是它被其它的软件包引用了。
      这可能意味着这个缺失的软件包可能已被废弃,
      或者只能在其他发布源中找到
      E: 软件包 ros-humble-ros-gz-bridge 没有可安装候选
      查看官网的文档,使用官方的推荐ROS2Humble下载方法:sudo apt-get install ros-${ROS_DISTRO}-ros-gz还是出现同样的报错
      spaaaaace@spaaaaace-DRA-XX:~/Code/HBUT2025_rm_vision/lc_navigation/lc_navigation_2025/simulation_ws$ sudo apt-get install ros-${ROS_DISTRO}-ros-gz
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树... 完成
      正在读取状态信息... 完成
      没有可用的软件包 ros-humble-ros-gz,但是它被其它的软件包引用了。
      或者只能在其他发布源中找到
      E: 软件包 ros-humble-ros-gz 没有可安装候选
      尝试过换源,无果,求助
      mjcaooM 1 条回复 最后回复 回复 引用 0
      • mjcaooM
        mjcaoo @3481856462
        @3481856462 试试一键安装工具里更新一下ros源呢?我可以搜索到这个包,换完源在apt update更新一下索引数据库
