    没有nav2_simple_commander,一直提示没有导入
    机器人学
    一直提示没有导入 不能初始化机器人位姿
    • O
      onoommoom
      在安装的navigation2中没有nav2_simple_commander这个命令,from nav2_simple_commander.robot_navigator import BasicNavigator输入该行代码时,下面一直有波浪线,下载navigation2也是跟着教程下载的,我的版本是foxy。
      具体细节和上下文:
      这是终端提示的错误:Traceback (most recent call last):
      File "/home/ros2/chapt7/chapt7_ws/install/fishbot_application/lib/fishbot_application/init_robot_pose", line 11, in <module>
      load_entry_point('fishbot-application==0.0.0', 'console_scripts', 'init_robot_pose')()
      File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 490, in load_entry_point
      return get_distribution(dist).load_entry_point(group, name)
      File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2854, in load_entry_point
      return ep.load()
      File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2445, in load
      return self.resolve()
      File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2451, in resolve
      module = import(self.module_name, fromlist=['name'], level=0)
      File "/home/ros2/chapt7/chapt7_ws/install/fishbot_application/lib/python3.8/site-packages/fishbot_application/init_robot_pose.py", line 2, in <module>
      ModuleNotFoundError: No module named 'nav2_simple_commander'
      尝试过的解决方法:
      重新克隆nav2包,但还是不行。
