    sudo rosdep init失败求解疑
    失败了怎么解决 错误 报错 网络问题 源配置错误
    1.2k
    • 庶
      庶几
      sudo rosdep init
      /usr/bin/rosdep:6: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
      from pkg_resources import load_entry_point
      ERROR: cannot download default sources list from:
      https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
      Website may be down.
      <urlopen error <urlopen error [Errno 111] Connection refused> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list)>
      配置ros源时:小鱼:检测当前系统ubuntu22.04:jammy 支持一键安装ROS
      ============正在添加ROS源密钥=================
      [-][11.15s] CMD Result:success
      Run CMD Task:[sudo apt search curl ]
      [-][0.45s] CMD Result:success
      [-][0.33s] CMD Result:success
      Run CMD Task:[sudo apt search gnupg2 ]
      [-][0.43s] CMD Result:success
      [-][0.31s] CMD Result:success
      正在挑选最快的密钥服务:['https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc', 'https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc']
      • https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc 延时:0.33s
      • https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc 超时
        已自动选择最快密钥服务:https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc
        [-][0.38s] CMD Result:success
      [-][10.07s] CMD Result:code:2
      Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
      [-][0.36s] CMD Result:success
      Run CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
      [-][0.00s] CMD Result:success
      根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-][11.62s] CMD Result:success
      Run CMD Task:[sudo apt search ros-base ]
      [-][0.50s] CMD Result:success
