    ros2 run nav2_map_server map_saver_cli -f 会有建图失败的问题
    ros2 hamble nav2map
    1.1k
    • 25739281302
      2573928130
      yingshi@localhost:~$ ros2 run nav2_map_server map_saver_cli -f map_test
      [INFO] [1756779170.449145940] [map_saver]:
      map_saver lifecycle node launched.
      Waiting on external lifecycle transitions to activate
      See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [INFO] [1756779170.453766981] [map_saver]: Creating
      [INFO] [1756779170.454343523] [map_saver]: Configuring
      [INFO] [1756779170.548227940] [map_saver]: Saving map from 'map' topic to '/home/yingshi/robot_ws/src/yingshi_robot/maps/map_test' file
      [WARN] [1756779170.549477815] [map_saver]: Free threshold unspecified. Setting it to default value: 0.250000
      [WARN] [1756779170.556668606] [map_saver]: Occupied threshold unspecified. Setting it to default value: 0.650000
      [ERROR] [1756779172.643780482] [map_saver]: Failed to spin map subscription
      [INFO] [1756779172.656481107] [map_saver]: Destroying
