    使用一键安装过程中遇到程序崩溃
    一键安装程序崩溃 rosdep一键安装
    1.2k
      报错信息:
        File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file
        File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 94, in run
          self.install_rosdepc()
        File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 85, in install_rosdepc
          PrintUtils.print_warning("安装失败,尝试使用其他方式安装...")
      AttributeError: type object 'PrintUtils' has no attribute 'print_warning'
      日志文件(/tmp/fishros_install.log)内容:
      [/][0.00s] amd64
      [-][0.00s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/translator.py -O /tmp/fishinstall//tools/translation/translator.py --no-check-certificate]
      [/][0.00s] --2025-09-06 09:05:13--  http://mirror.fishros.com/install/tools/translation/translator.py
      [\][0.05s] 正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      [|][0.05s] 正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... 已连接。
      [-][0.05s] 已发出 HTTP 请求,正在等待回应... 200 OK
      [/][0.05s] 长度: 2957 (2.9K) [application/octet-stream]
      [\][0.05s] 正在保存至: ‘/tmp/fishinstall//tools/translation/translator.py’
      [-][0.05s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/zh_CN.py -O /tmp/fishinstall//tools/translation/assets/zh_CN.py --no-check-certificate]
      [/][0.00s] --2025-09-06 09:05:17--  http://mirror.fishros.com/install/tools/translation/assets/zh_CN.py
      [\][0.04s] 正在解析主机 mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      [|][0.04s] 正在连接 mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... 已连接。
      [-][0.04s] 已发出 HTTP 请求,正在等待回应... 200 OK
      [/][0.04s] 长度: 23 [application/octet-stream]
      [\][0.04s] 正在保存至: ‘/tmp/fishinstall//tools/translation/assets/zh_CN.py’
      [-][0.04s] CMD Result:success
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/translation/assets/en_US.py -O /tmp/fishinstall//tools/translation/assets/en_US.py --no-check-certificate]
      [/][0.00s] --2025-09-06 09:05:17--  http://mirror.fishros.com/install/tools/translation/assets/en_US.py
      [/][0.05s] 长度: 5808 (5.7K) [application/octet-stream]
      [\][0.05s] 正在保存至: ‘/tmp/fishinstall//tools/translation/assets/en_US.py’
      Run CMD Task:[wget https://fishros.org.cn/forum/topic/1733 -O /tmp/t1733 -q  --timeout 10 && rm -rf /tmp/t1733]
      [-][0.50s] CMD Result:success
      已为您切换语言至当前所在国家语言:zh_CN
      基础检查通过...
                      .'// 可以多看看小鱼的文章  | 关注B站鱼香ROS机器人 \ `.
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      ROS相关:
      常用软件:
        [6]:一键安装:NodeJS环境
        [7]:一键安装:VsCode开发工具
        [8]:一键安装:Docker
        [10]:一键安装:微信(可以在Linux上使用的微信)
        [15]:一键安装:QQ for Linux
      配置工具:
        [13]:一键配置:python国内源
      [0]:quit
      Run CMD Task:[wget http://mirror.fishros.com/install/tools/tool_config_rosdep.py -O /tmp/fishinstall/tools/tool_config_rosdep.py --no-check-certificate]
      [/][0.00s] --2025-09-06 09:05:29--  http://mirror.fishros.com/install/tools/tool_config_rosdep.py
      [/][0.05s] 长度: 3609 (3.5K) [application/octet-stream]
      [\][0.05s] 正在保存至: ‘/tmp/fishinstall/tools/tool_config_rosdep.py’
      欢迎使用模板工程,本工具由作者小鱼提供
      Run CMD Task:[sudo apt install python3-pip -y]
      [/][0.00s] 正在读取软件包列表...
      [\][0.06s] 正在分析软件包的依赖关系树...
      [|][0.24s] 正在读取状态信息...
      [-][0.24s] python3-pip 已经是最新版 (22.0.2+dfsg-1ubuntu0.6)。
      [/][0.50s] 升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 0 个软件包未被升级。
      [-][0.60s] CMD Result:success
      请选择要使用的pip源:
      请选择pip源:
      [1]:清华源 - https://pypi.tuna.tsinghua.edu.cn/simple
      [2]:阿里云 - https://mirrors.aliyun.com/pypi/simple
      [3]:中国科技大学 - https://pypi.mirrors.ustc.edu.cn/simple
      [4]:华为云 - https://repo.huaweicloud.com/repository/pypi/simple
      [0]:quit
      您选择了: https://pypi.mirrors.ustc.edu.cn/simple
      正在使用 https://pypi.mirrors.ustc.edu.cn/simple 安装 rosdepc...
      Run CMD Task:[sudo pip3 install -i https://pypi.mirrors.ustc.edu.cn/simple rosdepc --break-system-packages]
      [-][0.00s] CMD Result:code:2
      Execute Command: sudo pip3 install -i https://pypi.mirrors.ustc.edu.cn/simple rosdepc --break-system-packages Error Code2
      ====================OUT====================
      ====================ERR====================
