    这个问题怎么解决
    rosman机器人,入门 入门 安装失败
    3.6k
      妫€娴嬪埌绋嬪簭鍙戠敓寮傚父閫€鍑猴紝璇锋墦寮€锛歨ttps://fishros.org.cn/forum 鎼哄甫濡備笅鍐呭杩涜鍙嶉
      鏍囬锛氫娇鐢ㄤ竴閿畨瑁呰繃绋嬩腑閬囧埌绋嬪簭宕╂簝
        File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 417, in run
          self.install_ros()
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 404, in install_ros
          self.check_sys_source()
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 220, in check_sys_source
          tool.change_sys_source()
        File "/tmp/fishinstall/tools/tool_config_system_source.py", line 302, in change_sys_source
          source = self.replace_source(failed_sources)
        File "/tmp/fishinstall/tools/tool_config_system_source.py", line 294, in replace_source
          FileUtils.new('/etc/apt/','sources.list',template.replace("<code-name>",codename).replace('<sources>',source))
        File "/tmp/fishinstall/tools/base.py", line 1222, in new
          with open(path+name,"w") as f:
      PermissionError: [Errno 13] Permission denied: '/etc/apt/sources.list'
      鏈杩愯璇︾粏鏃ュ織鏂囦欢宸蹭繚瀛樿嚦 /tmp/fishros_install.log
