    colcon build失败 提示:CMake Error: The source directory "/opt/ros/humble/share/gtest_vendor" does not appear to contain CMakeLists.txt.
    colcon build报错 gtestvendor
    • Q
      qic
      root@cq-virtual-machine:/opt/ros/humble# colcon build
      Starting >>> ament_package
      Starting >>> ament_lint
      Starting >>> gtest_vendor
      Starting >>> gtest
      Starting >>> ament_pycodestyle
      Starting >>> ament_cppcheck
      Starting >>> osrf_pycommon
      Starting >>> google_benchmark_vendor
      [2.564s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_package' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.564s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_package' doesn't explicitly install the 'package.xml' file (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.568s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_lint' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.568s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_lint' doesn't explicitly install the 'package.xml' file (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.586s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_pycodestyle' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.586s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_pycodestyle' doesn't explicitly install the 'package.xml' file (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.593s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_cppcheck' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.595s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'ament_cppcheck' doesn't explicitly install the 'package.xml' file (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.599s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'osrf_pycommon' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      [2.599s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'osrf_pycommon' doesn't explicitly install the 'package.xml' file (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      --- stderr: gtest_vendor
      Specify --help for usage, or press the help button on the CMake GUI.
      Failed <<< gtest_vendor [0.12s, exited with code 1]
      Aborted <<< google_benchmark_vendor [0.10s]
      Aborted <<< ament_package [0.14s]
      Aborted <<< ament_cppcheck [0.11s]
      Aborted <<< ament_lint [0.13s]
      Aborted <<< ament_pycodestyle [0.12s]
      Aborted <<< osrf_pycommon [0.11s]
      Aborted <<< gtest [0.34s]
      Summary: 0 packages finished [2.78s]
      1 package failed: gtest_vendor
      7 packages aborted: ament_cppcheck ament_lint ament_package ament_pycodestyle google_benchmark_vendor gtest osrf_pycommon
      2 packages had stderr output: google_benchmark_vendor gtest_vendor
      290 packages not processed
