    树莓派4B(Pi buster)一键安装apt存在问题,WARNING: apt does not have a stable CLI interface
    树莓派 4b 一键安装 apt存在问题
    2.7k
    • H
      huangguoming
      pi@raspberrypi:~ $ wget http://fishros.com/install -O fishros && . fishros      --2022-03-30 09:12:53--  http://fishros.com/install
      --2022-03-30 09:12:54--  http://fishros.com/install/
      Length: 300 [application/octet-stream]
      Saving to: ‘fishros’
      fishros             100%[===================>]     300  --.-KB/s    in 0s
      2022-03-30 09:12:54 (8.01 MB/s) - ‘fishros’ saved [300/300]
      --2022-03-30 09:12:54--  http://fishros.com/install/install1s/tools/base.py
      Length: 36343 (35K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]  35.49K   200KB/s    in 0.2s
      2022-03-30 09:12:55 (200 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [36343/36343]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs开发环境(通过nodejs可以预览小鱼官网噢)
      [7]:一键安装:VsCode
      [8]:一键安装:Docker
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2022-03-30 09:13:05--  http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 7989 (7.8K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]   7.80K  --.-KB/s    in 0.006s
      2022-03-30 09:13:06 (1.31 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [7989/7989]
      --2022-03-30 09:13:06--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2307 (2.3K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]   2.25K  --.-KB/s    in 0.002s
      2022-03-30 09:13:06 (1.06 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
      --2022-03-30 09:13:06--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 3340 (3.3K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>]   3.26K  --.-KB/s    in 0.002s
      2022-03-30 09:13:06 (1.53 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [3340/3340]
      小鱼:检测当前系统debian10.11:buster 支持一键安装ROS
      =========接下来这一步很重要,请小白关注,大佬请忽略========
      墙裂建议小白一定换源并清理三方源,换源!!!系统默认国外源容易失败!!
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用模板工程,本工具由作者小鱼提供
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      检测到当前系统架构为[armhf],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [-]Result:code:100                           0 443]uster-security Releaseeee
      镜像修复完成.....
      你的系统当前apt存在问题,请先使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "E: The repository 'https://mirrors.ustc.edu.cn/ubuntu-ports buster Release' does not have a Release file.\n", "E: The repository 'https://mirrors.ustc.edu.cn/ubuntu-ports buster-updates Release' does not have a Release file.\n", "E: The repository 'https://mirrors.ustc.edu.cn/ubuntu-ports buster-backports Release' does not have a Release file.\n", "E: The repository 'https://mirrors.ustc.edu.cn/ubuntu-ports buster-security Release' does not have a Release file.\n"]
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @huangguoming
        @huangguoming 完整测试后发现,官方虽然有buster镜像,但是发布的包并不全,所以无法完成二进制安装。建议使用原生系统的小伙伴转向ubuntu系统。
        1 条回复 最后回复 回复 引用 1
          @huangguoming 说一下问题,因为你用的是树莓派的原生系统,所以一键安装目前不兼容,不过如果你愿意配合测试,我可以添加对其的支持,因为我看到其系统版本已经被一键安装检测出来,并且和ubuntu是可以使用相同安装源的。
          H 1 条回复 最后回复 回复 引用 0
          • H
            huangguoming @小鱼
            @小鱼 嗯嗯,测试如果不麻烦的话,我可以的。但是如果太耗时,估计我搞不过来,我这边本来也有很多事情。
              @huangguoming 不麻烦,QQ上聊,我这边加几行代码就行。
              • H
                huangguoming
                pi@raspberrypi:~ $ wget http://fishros.com/install -O fishros && . fishros      --2022-03-30 11:42:31--  http://fishros.com/install
                --2022-03-30 11:42:31--  http://fishros.com/install/
                2022-03-30 11:42:32 (8.05 MB/s) - ‘fishros’ saved [300/300]
                --2022-03-30 11:42:32--  http://fishros.com/install/install1s/tools/base.py
                /tmp/fishinstall/to 100%[===================>]  35.49K  --.-KB/s    in 0.07s
                2022-03-30 11:42:32 (486 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [36343/36343]
                [-]Result:success
                基础检查通过...
                ---众多工具,等君来用---
                [7]:一键安装:VsCode
                [8]:一键安装:Docker
                [77]:测试模式:运行自定义工具测试
                [0]:quit
                请输入[]内的数字以选择:1
                --2022-03-30 11:42:44--  http://fishros.com/install/install1s/tools/tool_install_ros.py
                /tmp/fishinstall/to 100%[===================>]   7.80K  --.-KB/s    in 0.005s
                2022-03-30 11:42:44 (1.66 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [7989/7989]
                --2022-03-30 11:42:44--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
                /tmp/fishinstall/to 100%[===================>]   2.25K  --.-KB/s    in 0s
                2022-03-30 11:42:44 (39.1 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
                --2022-03-30 11:42:44--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
                Length: 4490 (4.4K) [application/octet-stream]
                /tmp/fishinstall/to 100%[===================>]   4.38K  --.-KB/s    in 0.004s
                2022-03-30 11:42:45 (1.22 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [4490/4490]
                [1]:更换系统源再继续安装
                [2]:不更换继续安装
                [0]:quit
                请输入[]内的数字以选择:1
                欢迎使用模板工程,本工具由作者小鱼提供
                请选择换源方式
                [1]:仅更换系统源
                [2]:更换系统源并清理第三方源
                [0]:quit
                请输入[]内的数字以选择:2
                [-]Result:success
                删除一个资源文件
                [-]Result:success
                替换完成,尝试第一次更新....
                [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[|]  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY DCC9[/]  The following signatures couldn't be verified because the public key is not[|]  The following signatures couldn't be verified because the public key is not[-]Err:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[/]  The following signatures couldn't be verified because the public key is not[-]Result:code:100                           KEY 54404762BBB6E853
                更新失败,开始更换导入方式并三次尝试...
                Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9]
                [\]Executing: /tmp/apt-key-gpghome.MXx3s0eCKZ/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
                Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517]
                [\]Executing: /tmp/apt-key-gpghome.JM3MLy1UjS/gpg.1.sh --keyserver keyserver.ubu[-]Result:success
                Run CMD Task:[apt-get install debian-keyring debian-archive-keyring]
                [/]Package debian-keyring is not available, but is referred to by another packag[-]Result:code:100                            has been obsoleted, or
                Run CMD Task:[apt-key update]
                [\]gpg: key 9165938D90FDDD2E: "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VF[-]Result:success
                [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[\]Get:5 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main armhf Packages [|]Err:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[-]  The following signatures couldn't be verified because the public key is not[/]Get:6 https://mirrors.tuna.tsinghua.edu.cn/debian buster/main Translation-en [\]Get:7 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib armhf Packag[|]Get:8 https://mirrors.tuna.tsinghua.edu.cn/debian buster/contrib Translation-[-]Get:9 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free armhf Packa[/]Get:10 https://mirrors.tuna.tsinghua.edu.cn/debian buster/non-free Translatio[\]Get:11 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main armhf [|]Get:12 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates/main Transl[-]Get:13 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main armh[/]Get:14 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/main Tran[\]Get:15 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib a[|]Get:16 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/contrib T[-]Get:17 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free [/]Get:18 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports/non-free [-]Result:code:100
                因为您的这块程序未经过充分测试,所以还是发生了错误,可以联系小鱼进行修复哦~
                镜像修复完成.....
                [|]Get:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [5[-]Get:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [/]Get:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[\]Err:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InR[|]  The following signatures couldn't be verified because the public key is not[-]Result:code:100                           KEY 54404762BBB6E853
                你的系统当前apt存在问题,请先使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "W: GPG error: https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853\n", "E: The repository 'https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease' is not signed.\n"]
                  1 条回复 最后回复 回复 引用 1
                  • 小鱼小 小鱼 将这个主题转为问答主题,在
                  • 小鱼小 小鱼 将这个主题标记为已解决,在
