    请教一下,ROS_DISTRO was set to 'humble' before. Please make sure that the environment does not mix paths from different distributions.该咋解决啊阿
    ros2编译报错 缺少依赖 cmakelist
    2.3k
      まほう しょうじょ うめ
      编译日志如图,用的是humble,之前重装过一次humble
        まほう しょうじょ うめ @2593721619
          小鱼 技术大佬 @2593721619
          @2593721619 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
