    10.1.4章节cmakelists.txt错误
    动手学ROS2
    cmake报错 install文件位置
    1.5k
    • 4
      开心
      构建功能包错误日志:
      tingbo@tingbo-i7:~/chapt10/chapt10_ws$ colcon build
      Starting >>> learn_qos_cpp
      Starting >>> learn_qos_py
      --- stderr: learn_qos_cpp
      CMake Error at /opt/ros/humble/share/ament_cmake_target_dependencies/cmake/ament_target_dependencies.cmake:42 (message):
        ament_target_dependencies() the first argument must be a valid target name
        CMakeLists.txt:25 (ament_target_dependencies)
      gmake: *** [Makefile:267:cmake_check_build_system] 错误 1
      Failed   <<< learn_qos_cpp [2.66s, exited with code 2]
      Aborted  <<< learn_qos_py [3.33s]
      Summary: 0 packages finished [3.99s]
        1 package failed: learn_qos_cpp
        1 package aborted: learn_qos_py
        1 package had stderr output: learn_qos_cpp
      cmakelists.txt代码:
      project(learn_qos_cpp)
      endif()
      # find dependencies
      find_package(nav_msgs REQUIRED)
      find_package(rclcpp REQUIRED)
      if(BUILD_TESTING)
        # comment the line when a copyright and license is added to all source files
        # comment the line when this package is in a git repo and when
        # a copyright and license is added to all source files
      endif()
      add_executable(learn_qos_cpp src/reliability_test.cpp)
      ament_target_dependencies(reliability_test rclcpp nav_msgs)
      install(DIRECTORY
      reliability_test
      DESTINATION share/${PROJECT_NAME})
      ament_package()
      reliability_test代码:
      #include <rclcpp/rclcpp.hpp>
      class OdomPublsherSubscriber : public rclcpp::Node {
          public:
              OdomPublsherSubscriber() : Node("odom_publisher_subscriber") {
                  // 创建发布者并设置 qos为sensor
                  odom_publisher_ = this->create_publisher<nav_msgs::msg::Odometry>(
                      "odom", rclcpp::SensorDataQoS());
                  //创建订阅者(默认Qos配置)队列设深度设置为5
                  odom_subscription_ = this->create_subscription<nav_msgs::msg::Odometry>(
                      "odom", rclcpp::SensorDataQoS(), [this] (const nav_msgs::msg::Odometry::SharedPtr msg) {
                          (void)msg;
                          RCLCPP_INFO(this->get_logger(), "收到里程计消息");
                  //创建一个1秒的定时器,并指定回调函数
                  timer_ = this->create_wall_timer(std::chrono::seconds(1), [this](){
                      odom_publisher_->publish(nav_msgs::msg::Odometry());
          private:
              rclcpp::Publisher<nav_msgs::msg::Odometry>::SharedPtr odom_publisher_;
              rclcpp::Subscription<nav_msgs::msg::Odometry>::SharedPtr odom_subscription_;
              rclcpp::TimerBase::SharedPtr timer_;
      int main(int argc, char *argv[]) {
          rclcpp::init(argc, argv);
          auto odom_node = std::make_shared<OdomPublsherSubscriber>();
          rclcpp::spin(odom_node);
          rclcpp::shutdown();
          return 0;
        小鱼 技术大佬 @43996173
        @43996173 在你的 CMakeLists.txt 文件中,你使用了错误的目标名称。在 ament_target_dependencies() 中,第一个参数应该是你的可执行文件名,而不是源文件名。因此,你需要将 ament_target_dependencies() 中的目标名称修改为 learn_qos_cpp,而不是 reliability_test。修改后的 CMakeLists.txt 文件应该如下所示:
        endif()
        # find dependencies
        if(BUILD_TESTING)
        endif()
        ament_target_dependencies(learn_qos_cpp rclcpp nav_msgs)  # 修改此处目标名称
        install(TARGETS
          learn_qos_cpp
          DESTINATION lib/${PROJECT_NAME})
        ament_package()
        请尝试这样修改,并重新构建你的软件包,看看是否解决了问题。
        4 1 条回复 最后回复 回复 引用 0
        • 4
          开心 @小鱼
          @小鱼 🆗,小鱼老师
