    gazebo显示不了fishbot机器人模型
    gazebo gazebo11 模型导入失败 gazebo仿真环境搭建 gazebo不显示
    • 刘豪刘
      豪哥
      最后由 刘豪 编辑
      3月份购买了两套fishbot小车,按照先学习理论的思路我先开始学习了《动手学ros》,在学习到了机器人仿真章节(第九章→”9.2为机器人URDF模型注入物理属性并在Gazebo中显示“→ 4. 将启动gazebo和生产fishbot写成launch文件,小节),
      在利用launch文件自动导入fishbot小车模型文件时出现问题:,
      • 我在终端窗口执行完列表命令执行完命令,如下:
        (base) rosmaster@ubuntu:~/fishbot_ws/src/fishbot_description$ ros2 launch fishbot_description gazebo.launch.py
        之后,出现如下反馈提示:
        gazebo2是启动了,但是界面空空如也。😞
      终端反馈的原始信息下如:
      [INFO] [launch]: All log files can be found below /home/rosmaster/.ros/log/2024-05-18-19-25-58-941896-ubuntu-3989
      [INFO] [gazebo-1]: process started with pid [3991]
      [INFO] [spawn_entity.py-2]: process started with pid [3993]
      [spawn_entity.py-2] Traceback (most recent call last):
      [spawn_entity.py-2] File "/opt/ros/foxy/lib/gazebo_ros/spawn_entity.py", line 33, in <module>
      [spawn_entity.py-2] from rclpy.node import Node
      [spawn_entity.py-2] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/node.py", line 42, in <module>
      [spawn_entity.py-2] from rclpy.client import Client
      [spawn_entity.py-2] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/client.py", line 22, in <module>
      [spawn_entity.py-2] from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
      [spawn_entity.py-2] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/implementation_singleton.py", line 31, in <module>
      [spawn_entity.py-2] rclpy_implementation = _import('._rclpy')
      [spawn_entity.py-2] File "/opt/ros/foxy/lib/python3.8/site-packages/rclpy/impl/init.py", line 28, in _import
      [spawn_entity.py-2] return importlib.import_module(name, package='rclpy')
      [spawn_entity.py-2] File "/home/rosmaster/miniconda3/lib/python3.9/importlib/init.py", line 127, in import_module
      [spawn_entity.py-2] return _bootstrap._gcd_import(name[level:], package, level)
      [spawn_entity.py-2] ModuleNotFoundError: No module named 'rclpy._rclpy'
      [spawn_entity.py-2] The C extension '/opt/ros/foxy/lib/python3.8/site-packages/rclpy/_rclpy.cpython-39-x86_64-linux-gnu.so' isn't present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system' for possible solutions
      [ERROR] [spawn_entity.py-2]: process has died [pid 3993, exit code 1, cmd '/opt/ros/foxy/lib/gazebo_ros/spawn_entity.py -entity fishbot -file /home/rosmaster/fishbot_ws/src/fishbot_description/install/fishbot_description/share/fishbot_description/urdf/fishbot_gazebo.urdf --ros-args'].
      [gazebo-1] Gazebo multi-robot simulator, version 11.11.0
      [gazebo-1] Copyright (C) 2012 Open Source Robotics Foundation.
      [gazebo-1] Released under the Apache 2 License.
      [gazebo-1] http://gazebosim.org
      [gazebo-1]
      [gazebo-1]
      [gazebo-1] [INFO] [1716031561.325380813] [gazebo_ros_node]: ROS was initialized without arguments.
      追加内容1:
      • 列表我的功能包结构、lanuch文件内容如下,
        launch文件原码如下:
      import os
          robot_name_in_model = 'fishbot'
          urdf_name = "fishbot_gazebo.urdf"
          ld = LaunchDescription()
          # Start Gazebo server
          start_gazebo_cmd = ExecuteProcess(
              cmd=['gazebo', '--verbose', '-s', 'libgazebo_ros_factory.so'],
              output='screen')
          # Launch the robot
          spawn_entity_cmd = Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-entity', robot_name_in_model,  '-file', urdf_model_path ], output='screen')
          ld.add_action(spawn_entity_cmd)
          return ld
      追加信息2:
      • 另外,我的模型文件是正常的(从小鱼的github网址中下载的),我使用rqt中的service calls 的xml方式导入到gazebo是显示正常的,见下图:
        此问题我已经重新做过很多遍这个例程,网上找了很多方法,一直不能解决,反复折腾已经5天了,还请知道的兄弟帮忙研究下可能是那里的问题。
        我看了一下,这个问题不解决,后面的章节无法进行,因为都是相互关联的内容,谢谢!
      N 1 条回复 最后回复 回复 引用 0
      • N
        niuniu36 @刘豪
        @刘豪 可以试试退出conda:conda deactivate 后再运行
