安装失败 报错:AttributeError: module 'tools.tool_install_ros' has no attribute 'Tool'
大佬看看怎么回事 -
我也出现了一样的问题 等大佬解决 明明之前还不会的
我也是这个问题。
一样的问题,求解决!!!
@1412644878 还有吗,最近准备升级一波了
@小鱼 有的 我现在还出现这个情况
Type the number in [] to choose a function:1 Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_install_ros.py -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate] [|][0.01s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.01s] CMD Result:code:4 . Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_rosenv.py -O /tmp/fishinstall/tools/tool_config_rosenv.py --no-check-certificate] [|][0.00s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.00s] CMD Result:code:4 . Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_system_source.py -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate] [/][0.00s] --2024-09-08 18:24:40-- https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_system_so[|][0.01s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.01s] CMD Result:code:4 . 检测到程序发生异常退出,请打开:https://fishros.org.cn/forum 携带如下内容进行反馈 标题:使用一键安装过程中遇到程序崩溃Traceback (most recent call last):
File "/tmp/fishinstall/install.py", line 133, in <module>
File "/tmp/fishinstall/install.py", line 122, in main
File "/tmp/fishinstall/tools/base.py", line 1473, in run_tool_file
tool = importlib.import_module(file.replace(".py","")).Tool()
AttributeError: module 'tools.tool_install_ros' has no attribute 'Tool'本次运行详细日志文件已保存至 /tmp/fishros_install.log 检测到本次运行出现失败命令,直接退出按Ctrl+C,按任意键上传日志并退出 ^Croot@a0788b5e3633:/# ^C root@a0788b5e3633:/# ^C root@a0788b5e3633:/# pip3 install run_tool_file ERROR: Could not find a version that satisfies the requirement run_tool_file (from versions: none) ERROR: No matching distribution found for run_tool_file -
@JayJoker 有代理吗,咋给你整到国外去了
开了代理的原因吧
