clion执行cmake报错,但是使用命令行执行cmake ..没有报错
ubuntu-22.04环境下使用clion执行cmake报错,但是使用命令行执行cmake ..没有报错
/usr/bin/cmake -DCMAKE_BUILD_TYPE=Debug -DCMAKE_MAKE_PROGRAM=/snap/clion/296/bin/ninja/linux/x64/ninja -DCMAKE_PREFIX_PATH=/opt/ros/humble -G Ninja -S /home/lfy/workspace/ros2/village_wang -B /home/lfy/workspace/ros2/village_wang/cmake-build-debug -- The C compiler identification is GNU 11.4.0 -- The CXX compiler identification is GNU 11.4.0 -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /usr/bin/cc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /usr/bin/c++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found ament_cmake: 1.3.10 (/opt/ros/humble/share/ament_cmake/cmake) -- Found Python3: /usr/bin/python3 (found version "3.10.12") found components: Interpreter -- Found rclcpp: 16.0.10 (/opt/ros/humble/share/rclcpp/cmake) -- Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake) -- Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake) -- Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake) CMake Error at /opt/ros/humble/share/rosidl_typesupport_c/cmake/get_used_typesupports.cmake:35 (message): No 'rosidl_typesupport_c' found Call Stack (most recent call first): /opt/ros/humble/share/rosidl_typesupport_c/cmake/rosidl_typesupport_c-extras.cmake:8 (get_used_typesupports) /opt/ros/humble/share/rosidl_typesupport_c/cmake/rosidl_typesupport_cConfig.cmake:41 (include) /opt/ros/humble/share/builtin_interfaces/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package) /opt/ros/humble/share/builtin_interfaces/cmake/builtin_interfacesConfig.cmake:41 (include) /opt/ros/humble/share/libstatistics_collector/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package) /opt/ros/humble/share/libstatistics_collector/cmake/libstatistics_collectorConfig.cmake:41 (include) /opt/ros/humble/share/rclcpp/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package) /opt/ros/humble/share/rclcpp/cmake/rclcppConfig.cmake:41 (include) CMakeLists.txt:11 (find_package) -- Configuring incomplete, errors occurred! See also "/home/lfy/workspace/ros2/village_wang/cmake-build-debug/CMakeFiles/CMakeOutput.log". [已完成]
命令行运行cmake ..
make .. -- The C compiler identification is GNU 11.4.0 -- The CXX compiler identification is GNU 11.4.0 -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /usr/bin/cc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /usr/bin/c++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found ament_cmake: 1.3.10 (/opt/ros/humble/share/ament_cmake/cmake) -- Found Python3: /usr/bin/python3 (found version "3.10.12") found components: Interpreter -- Found rclcpp: 16.0.10 (/opt/ros/humble/share/rclcpp/cmake) -- Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake) -- Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake) -- Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake) -- Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c -- Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp -- Found rmw_implementation_cmake: 6.1.2 (/opt/ros/humble/share/rmw_implementation_cmake/cmake) -- Found rmw_fastrtps_cpp: 6.2.7 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake) -- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libcrypto.so (found version "3.0.2") -- Found FastRTPS: /opt/ros/humble/include -- Using RMW implementation 'rmw_fastrtps_cpp' as default -- Looking for pthread.h -- Looking for pthread.h - found -- Performing Test CMAKE_HAVE_LIBC_PTHREAD -- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success -- Found Threads: TRUE -- Found ament_lint_auto: 0.12.11 (/opt/ros/humble/share/ament_lint_auto/cmake) -- Added test 'cppcheck' to perform static code analysis on C / C++ code -- Configured cppcheck include dirs: -- Configured cppcheck exclude dirs and/or files: -- Added test 'lint_cmake' to check CMake code style -- Added test 'uncrustify' to check C / C++ code style -- Configured uncrustify additional arguments: -- Added test 'xmllint' to check XML markup files -- Configuring done -- Generating done -- Build files have been written to: /home/lfy/workspace/ros2/village_wang/build
从你提供的错误信息来看,CLion在尝试使用CMake配置项目时遇到了一个特定的错误,而命令行执行CMake则没有这个问题。这个错误是关于找不到
。下面是一些可能的解决步骤和原因分析:-
环境差异:
- CLion和命令行可能使用不同的环境变量。检查CLion中配置的环境变量,确保它们与命令行中的环境一致。
- 特别是
CMAKE_PREFIX_PATH
和PATH
,这些变量对CMake查找库和工具的位置至关重要。
CMake配置差异:
- CLion中使用的CMake命令包含了一些特定的参数,如
,这指定了使用Ninja作为构建系统。 - 确保Ninja配置正确,并且与你的系统兼容。
- 尝试在CLion中更改构建系统为Makefile或其他,看看是否仍然出现问题。
依赖问题:
- 错误提示
表明CMake在配置过程中未能找到rosidl_typesupport_c
。这可能是因为CLion的CMake配置没有正确设置搜索路径。 - 检查
CMakeLists.txt
文件,确保有正确的find_package
调用和相关的依赖项设置。 - 确保ROS 2环境已经正确安装,并且所有相关的包都可用。
- 错误提示
缓存问题:
- 有时候,旧的CMake缓存可能导致问题。尝试在CLion中清除CMake缓存(通常在CMake工具窗口中有一个“清除缓存并重新加载”的选项)。
- 你也可以手动删除
cmake-build-debug
目录,然后重新构建。
权限问题:
- 确保你有足够的权限访问所有相关的文件和目录。
详细日志:
- 查看CLion中CMake生成的详细日志,可能会有更多关于问题的线索。
尝试更新或重新安装:
- 如果问题依旧存在,尝试更新CLion到最新版本,或者重新安装ROS 2和CLion。
通过上述步骤,你应该能够诊断并解决CLion中CMake配置的问题。如果问题仍然存在,可能需要更详细地检查CLion的配置或寻求CLion社区的帮助。
此回复已被删除! -
如果您在使用 CLion(JetBrains 的 C/C++ 集成开发环境)时,能够正常地包含和使用 Point Cloud Library(PCL)库,而没有遇到任何编译或运行时错误,这通常意味着您的项目配置是正确的,并且所有必要的依赖项都已正确安装和链接。
以下是一些关键点,确保您的项目能够顺利使用 PCL:
CMakeLists.txt 配置:
确保您的CMakeLists.txt
文件中包含了 PCL 的查找和链接指令。通常,这包括find_package(PCL REQUIRED)
以及在target_link_libraries
中添加相应的 PCL 组件。例如:cmake_minimum_required(VERSION 3.10) project(PCL_Example) find_package(PCL 1.8 REQUIRED) include_directories(${PCL_INCLUDE_DIRS}) link_directories(${PCL_LIBRARY_DIRS}) add_definitions(${PCL_DEFINITIONS}) add_executable(pcl_example main.cpp) target_link_libraries(pcl_example ${PCL_LIBRARIES})
PCL 安装:
确保 PCL 库已经正确安装在您的系统上,并且pcl_config.cmake
文件(或其他相关的 CMake 配置文件)可以被 CMake 找到。这通常意味着 PCL 是通过标准的包管理器(如 apt-get, brew, vcpkg 等)安装的,或者通过源代码编译并安装了正确的 CMake 配置。 -
环境变量:
确保相关的环境变量(如PCL_ROOT
,如果设置的话)指向了正确的 PCL 安装目录。此外,LD_LIBRARY_PATH
(Linux)或DYLD_LIBRARY_PATH
(macOS)可能需要包含 PCL 库文件的路径,以确保运行时可以找到这些库。 -
CLion 配置:
在 CLion 中,确保您选择了正确的 CMake 构建配置(如 Debug 或 Release),并且 CMake 缓存是最新的。有时候,清理 CMake 缓存(通过 CLion 的“File” -> “Invalidate Caches / Restart...”)可以解决一些看似无关的问题。 -
编译器和依赖:
确保您的编译器(如 GCC, Clang, MSVC)和所有依赖项(如 Boost, Eigen, VTK 等,这些通常是 PCL 的依赖)都是最新的,或者至少是与 PCL 兼容的版本。
如果您已经检查了以上所有点,并且一切看起来都是正确的,那么您应该能够顺利地在 CLion 中使用 PCL 库进行开发。如果遇到具体的错误或问题,请提供详细的错误信息,以便进行更具体的故障排除。
