    micro_ros国外源下载错误
    micro-ros github cmake library库
    1.8k
    • 铁
      铁盒的序 年度VIP
      我人在海外,在小鱼的教程中2.你的第一个MicroROS节点
      使用的源是
      lib_deps =
          https://gitee.com/ohhuo/micro_ros_platformio.git
      我在想使用github上的官方源
      https://github.com/micro-ROS/micro_ros_platformio.git
      但是vscode克隆这个库出现了错误,错误如下
      Building micro-ROS library
      Build mcu micro-ROS environment failed:
      --- stderr: rcl_logging_interface
      CMake Warning at /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/ament_cmake_export_libraries-extras.cmake:116 (message):
        Package 'rcutils' exports library 'dl' which couldn't be found
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/rcutilsConfig.cmake:41 (include)
        CMakeLists.txt:20 (find_package)
      --- stderr: rosidl_runtime_c
        CMakeLists.txt:15 (find_package)
      --- stderr: rosidl_dynamic_typesupport
        CMakeLists.txt:26 (find_package)
      --- stderr: rcl_logging_noop
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/rcl_logging_interfaceConfig.cmake:41 (include)
        CMakeLists.txt:16 (find_package)
      --- stderr: rmw
        CMakeLists.txt:22 (find_package)
      --- stderr: rosidl_typesupport_microxrcedds_c
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/rosidl_runtime_cConfig.cmake:41 (include)
      --- stderr: micro_ros_utilities
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_introspection_c/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_introspection_c/cmake/rosidl_typesupport_introspection_cConfig.cmake:41 (include)
        CMakeLists.txt:18 (find_package)
      --- stderr: rosidl_typesupport_c
        CMakeLists.txt:34 (find_package)
      --- stderr: builtin_interfaces
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/rosidl_typesupport_c-extras.cmake:13 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/rosidl_typesupport_cConfig.cmake:41 (include)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_core_generators/cmake/rosidl_core_generators-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_core_generators/cmake/rosidl_core_generatorsConfig.cmake:41 (include)
        CMakeLists.txt:17 (find_package)
      CMake Error at /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/get_used_typesupports.cmake:35 (message):
        No 'rosidl_typesupport_cpp' found
        /opt/ros/humble/share/rosidl_typesupport_cpp/cmake/rosidl_typesupport_cpp-extras.cmake:8 (get_used_typesupports)
        /opt/ros/humble/share/rosidl_typesupport_cpp/cmake/rosidl_typesupport_cppConfig.cmake:41 (include)
      Failed   <<< builtin_interfaces [0.41s, exited with code 1]
      想请问各位大佬这是为啥?
        小鱼 技术大佬 @铁盒的序
        @铁盒的序 系统什么环境
        铁 2 条回复 最后回复 回复 引用 0
        • 铁
          铁盒的序 年度VIP @小鱼
          @小鱼 您好,用的是Ubuntu 22.04
          • 铁
            铁盒的序 年度VIP @小鱼
            @小鱼 是不是国外的源本来就是不能直接编译使用的?必须用小鱼您修改后的国内仓库的源才能正常编译运行?
              小鱼 技术大佬 @铁盒的序
              @铁盒的序 我给的仓库里面放了编译好的库了,国外的要重新构建,因为无法访问github,很容易失败
