    控制OLED-自定义消息接口 按步骤删除.pio/libdeps/featheresp32/micro_ros_platformio/libmicroros重新编译出错
    cmake报错 micro-ros
    • 铁
      铁盒的序 年度VIP
      问题 :按步骤删除.pio/libdeps/featheresp32/micro_ros_platformio/libmicroros重新编译出错
      错误如下
      Building micro-ROS library
       *  Build mcu micro-ROS environment failed:
       *  --- stderr: rosidl_typesupport_interface
       *  CMake Warning:
       *    Manually-specified variables were not used by the project:
       *      CMAKE_POSITION_INDEPENDENT_CODE
       *      THIRDPARTY
       *  --- stderr: test_interface_files
       *  CMake Warning:
       *      BUILD_SHARED_LIBS
       *      THIRDPARTY
       *  --- stderr: microcdr
       *  CMake Warning:
       *      BUILD_TESTING
       *      THIRDPARTY
       *  --- stderr: rmw_implementation_cmake
       *  CMake Warning:
       *      BUILD_SHARED_LIBS
       *      THIRDPARTY
       *  --- stderr: rosidl_adapter
       *  CMake Warning:
       *      BUILD_SHARED_LIBS
       *      THIRDPARTY
       *  --- stderr: rcutils
       *  CMake Warning:
       *      ENABLE_TESTING
       *      THIRDPARTY
       *  In function 'rcutils_char_array_strncat',
       *      inlined from 'rcutils_char_array_strcat' at /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10:
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:224:3: warning: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
       *     strncat(char_array->buffer, src, n);
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c: In function 'rcutils_char_array_strcat':
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10: note: length computed here
       *     return rcutils_char_array_strncat(char_array, src, strlen(src));
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c: In function 'rcutils_get_error_string':
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: warning: initializer-string for array of chars is too long
       *       return (rcutils_error_string_t) {"error not set"};  // NOLINT(readability/braces)
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: note: (near initialization for '(anonymous).str')
       *  In file included from /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:35:
       *  At top level:
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:109:1: warning: '__rcutils_convert_uint64_t_into_c_str' defined but not used [-Wunused-function]
       *   __rcutils_convert_uint64_t_into_c_str(uint64_t number, char * buffer, size_t buffer_size)
       *  /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:91:1: warning: '__rcutils_reverse_str' defined but not used [-Wunused-function]
       *   __rcutils_reverse_str(char * string_in, size_t string_len)
       *  --- stderr: tracetools
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rosidl_parser
       *  CMake Warning:
       *      BUILD_SHARED_LIBS
       *      THIRDPARTY
       *  --- stderr: rosidl_runtime_c
       *  CMake Warning at /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/ament_cmake_export_libraries-extras.cmake:116 (message):
       *    Package 'rcutils' exports library 'dl' which couldn't be found
       *  Call Stack (most recent call first):
       *    /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/rcutilsConfig.cmake:41 (include)
       *    CMakeLists.txt:15 (find_package)
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: microxrcedds_client
       *  CMake Warning:
       *      BUILD_TESTING
       *      THIRDPARTY
       *  --- stderr: rosidl_cmake
       *  CMake Warning:
       *      BUILD_SHARED_LIBS
       *      THIRDPARTY
       *  --- stderr: rcl_logging_interface
       *    CMakeLists.txt:19 (find_package)
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rmw
       *    CMakeLists.txt:21 (find_package)
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rcl_logging_noop
       *    /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
       *    /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/rcl_logging_interfaceConfig.cmake:41 (include)
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rosidl_generator_c
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rosidl_typesupport_introspection_c
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: rosidl_typesupport_microxrcedds_c
       *    /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
       *    /home/zrc/ESP32Code/OLED/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/rosidl_runtime_cConfig.cmake:41 (include)
       *    CMakeLists.txt:22 (find_package)
       *  CMake Warning:
       *      THIRDPARTY
       *  --- stderr: fishbot_interfaces
       *  CMake Error at CMakeLists.txt:25 (find_package):
       *    By not providing "Findrosidl_default_generators.cmake" in CMAKE_MODULE_PATH
       *    this project has asked CMake to find a package configuration file provided
       *    by "rosidl_default_generators", but CMake did not find one.
       *    Could not find a package configuration file provided by
       *    "rosidl_default_generators" with any of the following names:
       *      rosidl_default_generatorsConfig.cmake
       *      rosidl_default_generators-config.cmake
       *    Add the installation prefix of "rosidl_default_generators" to
       *    CMAKE_PREFIX_PATH or set "rosidl_default_generators_DIR" to a directory
       *    containing one of the above files.  If "rosidl_default_generators" provides
       *    a separate development package or SDK, be sure it has been installed.
       *  Failed   <<< fishbot_interfaces [1.40s, exited with code 1]
       *  ================================================================= [FAILED] Took 210.74 seconds =================================================================
      我的Cmakelists.txt和package.xml全是按照作者的复制粘贴。
      Cmakelists.txt如下
      project(fishbot_interfaces)
      endif()
      # find dependencies
      if(BUILD_TESTING)
        # comment the line when a copyright and license is added to all source files
        # comment the line when this package is in a git repo and when
        # a copyright and license is added to all source files
      endif()
        "srv/OledControl.srv"
      ament_package()
      package.xml如下
      <?xml version="1.0"?>
      <package format="3">
        <name>fishbot_interfaces</name>
        <version>0.0.0</version>
        <maintainer email="zrc@todo.todo">zrc</maintainer>
        <export>
        </export>
      </package>
      之前直接colcon build这一步都成功的,但是到这就失败了。求小鱼大佬和过往的英雄好汉们解答,感谢!
      系统版本Ubuntu 22.04
      我人在海外,我不知道是不是网络的问题
      此外,我将库的源替换成海外源
      https://github.com/micro-ROS/micro_ros_platformio.git
      又发生了错误
      CMake Warning at /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/ament_cmake_export_libraries-extras.cmake:116 (message):
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/rcutilsConfig.cmake:41 (include)
        CMakeLists.txt:20 (find_package)
      --- stderr: rosidl_dynamic_typesupport
        CMakeLists.txt:26 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/rcl_logging_interfaceConfig.cmake:41 (include)
        CMakeLists.txt:16 (find_package)
      --- stderr: rmw
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_runtime_c/cmake/rosidl_runtime_cConfig.cmake:41 (include)
      --- stderr: micro_ros_utilities
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_introspection_c/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_introspection_c/cmake/rosidl_typesupport_introspection_cConfig.cmake:41 (include)
        CMakeLists.txt:18 (find_package)
      --- stderr: rosidl_typesupport_c
        CMakeLists.txt:34 (find_package)
      --- stderr: builtin_interfaces
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/rosidl_typesupport_c-extras.cmake:13 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/rosidl_typesupport_cConfig.cmake:41 (include)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_core_generators/cmake/rosidl_core_generators-extras.cmake:21 (find_package)
        /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_core_generators/cmake/rosidl_core_generatorsConfig.cmake:41 (include)
        CMakeLists.txt:17 (find_package)
      CMake Error at /home/zrc/ESP32Code/OLED1/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rosidl_typesupport_c/cmake/get_used_typesupports.cmake:35 (message):
        No 'rosidl_typesupport_cpp' found
        /opt/ros/humble/share/rosidl_typesupport_cpp/cmake/rosidl_typesupport_cpp-extras.cmake:8 (get_used_typesupports)
        /opt/ros/humble/share/rosidl_typesupport_cpp/cmake/rosidl_typesupport_cppConfig.cmake:41 (include)
      Failed   <<< builtin_interfaces [0.41s, exited with code 1]
        小鱼 技术大佬 @铁盒的序
        @铁盒的序 你好,这两天有点忙,今天才抽空看,变更下代码路径试试
        铁 1 条回复 最后回复 回复 引用 0
        • 铁
          铁盒的序 年度VIP @小鱼
          @小鱼 老师您好,可以告诉一下详细的步骤吗?我刚刚接触ros2,有些地方还很生疏,谢谢您
