microros-agent会话频繁断连,销毁重建
问题描述:
刚拿到四驱版fishbot时下载官方固件并使用WIFI连接,使用ROS2键盘控制FishBot移动时经常发生控制无响应问题,车载的OLED屏也频繁显示WIFI断连重新连接。
后学习至16.6节《做个遥控车-订阅ROS2 Twist》时,使用WIFI连接控制小车也出现控制无响应问题,遂怀疑是WIFI问题,并将程序改为通过串口发布控制指令,并添加OLED显示,显示当前车辆运行状况(线速度指令/角速度指令)
使用数据线连接小车,通过ROS2键盘控制时,按下i(前进键)小车开始前进,OLED显示屏显示当前线速度及角速度指令,但一段时间后小车自动停止,OLED屏幕显示清空,需重新按下键盘按键控制其继续移动(且有时无反应)导致控制不连续,查看运行microros-agent的终端发现会话,客户端,服务端,话题不停销毁重建串口控制microros-agent界面显示如下
[1733226894.314018] info | TermiosAgentLinux.cpp | init | running... | fd: 3 [1733226894.314568] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4 [1733226894.763491] info | Root.cpp | create_client | create | client_key: 0x227F3C7A, session_id: 0x81 [1733226894.763565] info | SessionManager.hpp | establish_session | session established | client_key: 0x227F3C7A, address: 0 [1733226894.786831] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x227F3C7A, participant_id: 0x000(1) [1733226894.802584] info | ProxyClient.cpp | create_topic | topic created | client_key: 0x227F3C7A, topic_id: 0x000(2), participant_id: 0x000(1) [1733226894.813539] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0x227F3C7A, subscriber_id: 0x000(4), participant_id: 0x000(1) [1733226894.826249] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0x227F3C7A, datareader_id: 0x000(6), subscriber_id: 0x000(4) ---------------------------------------------------------此处断连并自动销毁重建会话--------------------------------------------------------------------------------- [1733226933.706977] info | Root.cpp | delete_client | delete | client_key: 0x227F3C7A [1733226933.707028] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x227F3C7A, address: 0 [1733226933.707059] info | Root.cpp | create_client | create | client_key: 0x78542B7B, session_id: 0x81 [1733226933.707075] info | SessionManager.hpp | establish_session | session established | client_key: 0x78542B7B, address: 0 [1733226933.720749] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x78542B7B, participant_id: 0x000(1) [1733226933.736451] info | ProxyClient.cpp | create_topic | topic created | client_key: 0x78542B7B, topic_id: 0x000(2), participant_id: 0x000(1) [1733226933.747355] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0x78542B7B, subscriber_id: 0x000(4), participant_id: 0x000(1) [1733226933.759909] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0x78542B7B, datareader_id: 0x000(6), subscriber_id: 0x000(4)
WIFI控制microros-agent界面显示如下
[1733227467.146393] debug | UDPv4AgentLinux.cpp | send_message | [** <<UDP>> **] | client_key: 0x08D2B914, len: 13, data: 0000: 81 00 00 00 0B 01 05 00 05 00 05 00 80 ---------------------------------------------------------此处发送多次消息但无响应--------------------------------------------------------------------------------- [1733227467.346800] debug | UDPv4AgentLinux.cpp | send_message | [** <<UDP>> **] | client_key: 0x08D2B914, len: 13, data: 0000: 81 00 00 00 0B 01 05 00 05 00 05 00 80 [1733227467.547222] debug | UDPv4AgentLinux.cpp | send_message | [** <<UDP>> **] | client_key: 0x08D2B914, len: 13, data: 0000: 81 00 00 00 0B 01 05 00 05 00 05 00 80 [1733227467.557690] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x08D2B914, len: 24, data: 0000: 80 00 00 00 00 01 10 00 58 52 43 45 01 00 01 0F 16 80 BD 26 81 00 FC 03 ---------------------------------------------------------此处断连并自动销毁重建会话--------------------------------------------------------------------------------- [1733227467.586688] info | Root.cpp | delete_client | delete | client_key: 0x08D2B914 [1733227467.586739] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x08D2B914, address: 192.168.31.229:47138 [1733227467.586775] info | Root.cpp | create_client | create | client_key: 0x1680BD26, session_id: 0x81 [1733227467.586792] info | SessionManager.hpp | establish_session | session established | client_key: 0x1680BD26, address: 192.168.31.229:47138 [1733227467.586983] debug | UDPv4AgentLinux.cpp | send_message | [** <<UDP>> **] | client_key: 0x1680BD26, len: 19, data: 0000: 81 00 00 00 04 01 0B 00 00 00 58 52 43 45 01 00 01 0F 00 [1733227467.796858] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x1680BD26, len: 13, data: 0000: 81 00 00 00 0A 01 05 00 00 00 00 3F 80 [1733227467.797311] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x1680BD26, len: 40, data: 0000: 81 80 00 00 01 07 20 00 00 0A 00 01 01 03 00 00 12 00 00 00 00 01 00 00 0A 00 00 00 65 73 70 33 0020: 32 5F 63 61 72 00 00 00
补充
系统为ubuntu22.04,humble 双系统,非虚拟机
一直采用usb供电,未使用电池供电,不知是否有影响
WIFI使用小米路由器,未连接网线,单独提供给fishbot连接#include <Arduino.h> #include <Esp32McpwmMotor.h> #include <micro_ros_platformio.h> #include <rcl/rcl.h> #include <rclc/rclc.h> #include <rclc/executor.h> #include <geometry_msgs/msg/twist.h> #include <Adafruit_SSD1306.h> #include <Adafruit_GFX.h> #include "Wire.h" // 定义 ROS2 执行器和支持结构 rclc_executor_t executor; rclc_support_t support; // 定义 ROS2 内存分配器 rcl_allocator_t allocator; // 定义 ROS2 节点和订阅者 rcl_node_t node; rcl_subscription_t subscriber; // 定义接收到的消息结构体 geometry_msgs__msg__Twist sub_msg; Adafruit_SSD1306 display(128, 64, &Wire); // 初始化 OLED 显示屏 // 定义控制两个电机的对象 Esp32McpwmMotor motor; // 回调函数,当接收到新的 Twist 消息时会被调用 void twist_callback(const void *msg_in) { // 将接收到的消息指针转化为 geometry_msgs__msg__Twist 类型 const geometry_msgs__msg__Twist *twist_msg = (const geometry_msgs__msg__Twist *)msg_in; // 从 Twist 消息中获取线速度和角速度 float linear_x = twist_msg->linear.x; float angular_z = twist_msg->angular.z; // 更新 OLED 显示屏 display.clearDisplay(); display.setCursor(0, 0); display.print("Linear X: "); display.println(linear_x); display.print("Angular Z: "); display.println(angular_z); display.display(); // 如果速度为零,则停止两个电机 if (linear_x == 0 && angular_z == 0) { motor.updateMotorSpeed(0, 0); motor.updateMotorSpeed(1, 0); motor.updateMotorSpeed(2, 0); motor.updateMotorSpeed(3, 0); return; } // 根据线速度和角速度控制两个电机的转速 if (linear_x > 0) { motor.updateMotorSpeed(0, 80); motor.updateMotorSpeed(1, 80); motor.updateMotorSpeed(2, 80); motor.updateMotorSpeed(3, 80); } if (linear_x < 0) { motor.updateMotorSpeed(0, -80); motor.updateMotorSpeed(1, -80); motor.updateMotorSpeed(2, -80); motor.updateMotorSpeed(3, -80); } if (angular_z > 0) { motor.updateMotorSpeed(0, -80); motor.updateMotorSpeed(1, 80); motor.updateMotorSpeed(2, -80); motor.updateMotorSpeed(3, 80); } if (angular_z < 0) { motor.updateMotorSpeed(0, 80); motor.updateMotorSpeed(1, -80); motor.updateMotorSpeed(2, 80); motor.updateMotorSpeed(3, -80); } } void setup() { Serial.begin(115200); // 设置通过串口进行MicroROS通信 set_microros_serial_transports(Serial); // 延时时一段时间,等待设置完成 delay(2000); // 初始化两个电机的引脚 motor.attachMotor(0, 25, 33); // 左前 motor.attachMotor(1, 26, 27); // 右前 motor.attachMotor(2, 12, 22); // 左后 motor.attachMotor(3, 16, 17); // 右后 // 初始化 ROS2 执行器和支持结构 allocator = rcl_get_default_allocator(); Wire.begin(18, 19); display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // 设置OLED的I2C地址,默认0x3C display.setTextSize(2); // 设置字体大小,最小为1 display.setTextColor(SSD1306_WHITE); // 设置字体颜色 display.clearDisplay(); // 清空屏幕 display.display(); // 显示内容 rclc_support_init(&support, 0, NULL, &allocator); // 初始化 ROS2 节点 rclc_node_init_default(&node, "esp32_car", "", &support); // 初始化订阅者 rclc_subscription_init_default( &subscriber, &node, ROSIDL_GET_MSG_TYPE_SUPPORT(geometry_msgs, msg, Twist), "/cmd_vel"); rclc_executor_init(&executor, &support.context, 2, &allocator); // 设置订阅的回调函数 rclc_executor_add_subscription(&executor, &subscriber, &sub_msg, &twist_callback, ON_NEW_DATA); } void loop() { rclc_executor_spin_some(&executor, RCL_MS_TO_NS(100)); // 循环处理数据 }
@Mostima 在 microros-agent会话频繁断连,销毁重建 中说:
这个有影响,小米路由器我以前遇到过这个问题,如果是双频合一的,一定要拆开,电脑连网线或者5g,小车连2.4g
@小鱼 已解决,采用电池供电后控制正常,应该是串口供电同时启动电机,控制板供电不足重启导致的断连
