    C++行为树中config().blackboard->template语法如何理解?
    1.4k
      小鱼 技术大佬
      在行为树使用中看到了一个比较陌生的语法,问一下C++大佬们。
      这行代码的意思是从blackboard(存储数据的地方)中获取一个key为goal,类型为Pose2D的value。
      Pose2D mygoal =  config().blackboard->template get<Pose2D>("goal");
      不太理解的地方是config().blackboard->template和get<Pose2D>("goal")之间的空格。
      该开源库地址:https://github.com/BehaviorTree/BehaviorTree.CPP
      其中blackboard.h代码如下
      #ifndef BLACKBOARD_H
      #define BLACKBOARD_H
      #include <iostream>
      #include <string>
      #include <memory>
      #include <stdint.h>
      #include <unordered_map>
      #include <mutex>
      #include <sstream>
      #include "behaviortree_cpp_v3/basic_types.h"
      #include "behaviortree_cpp_v3/utils/safe_any.hpp"
      #include "behaviortree_cpp_v3/exceptions.h"
      namespace BT
       * @brief The Blackboard is the mechanism used by BehaviorTrees to exchange
       * typed data.
      class Blackboard
        public:
          typedef std::shared_ptr<Blackboard> Ptr;
        protected:
          // This is intentionally protected. Use Blackboard::create instead
          Blackboard(Blackboard::Ptr parent): parent_bb_(parent)
        public:
          /** Use this static method to create an instance of the BlackBoard
          *   to share among all your NodeTrees.
          static Blackboard::Ptr create(Blackboard::Ptr parent = {})
              return std::shared_ptr<Blackboard>( new Blackboard(parent) );
          virtual ~Blackboard() = default;
           * @brief The method getAny allow the user to access directly the type
           * erased value.
           * @return the pointer or nullptr if it fails.
          const Any* getAny(const std::string& key) const
              std::unique_lock<std::mutex> lock(mutex_);
              if( auto parent = parent_bb_.lock())
                  auto remapping_it = internal_to_external_.find(key);
                  if( remapping_it != internal_to_external_.end())
                      return parent->getAny( remapping_it->second );
              auto it = storage_.find(key);
              return ( it == storage_.end()) ? nullptr : &(it->second.value);
          /** Return true if the entry with the given key was found.
           *  Note that this method may throw an exception if the cast to T failed.
          template <typename T>
          bool get(const std::string& key, T& value) const
              const Any* val = getAny(key);
              if (val)
                  value = val->cast<T>();
              return (bool)val;
           * Version of get() that throws if it fails.
          T get(const std::string& key) const
              if (val)
                  return val->cast<T>();
              else
                  throw RuntimeError("Blackboard::get() error. Missing key [", key, "]");
          /// Update the entry with the given key
          void set(const std::string& key, const T& value)
                      const auto& remapped_key = remapping_it->second;
                      if( it == storage_.end() ) // virgin entry
                          auto parent_info = parent->portInfo(remapped_key);
                          if( parent_info )
                              storage_.insert( {key, Entry( *parent_info ) } );
                          else{
                              storage_.insert( {key, Entry( PortInfo() ) } );
                      parent->set( remapped_key, value );
                      return;
              if( it != storage_.end() ) // already there. check the type
                  const PortInfo& port_info = it->second.port_info;
                  auto& previous_any = it->second.value;
                  const auto locked_type = port_info.type();
                  Any temp(value);
                  if( locked_type && *locked_type != typeid(T) && *locked_type != temp.type() )
                      bool mismatching = true;
                      if( std::is_constructible<StringView, T>::value )
                          Any any_from_string = port_info.parseString( value );
                          if( any_from_string.empty() == false)
                              mismatching = false;
                              temp = std::move( any_from_string );
                      if( mismatching )
                          debugMessage();
                          throw LogicError( "Blackboard::set() failed: once declared, the type of a port shall not change. "
                                           "Declared type [", demangle( locked_type ),
                                           "] != current type [", demangle( typeid(T) ),"]" );
                  previous_any = std::move(temp);
              else{ // create for the first time without any info
                  storage_.emplace( key, Entry( Any(value), PortInfo() ) );
              return;
          void setPortInfo(std::string key, const PortInfo& info);
          const PortInfo *portInfo(const std::string& key);
          void addSubtreeRemapping(StringView internal, StringView external);
          void debugMessage() const;
          std::vector<StringView> getKeys() const;
          void clear()
              storage_.clear();
              internal_to_external_.clear();
        private:
          struct Entry{
              Any value;
              const PortInfo port_info;
              Entry( const PortInfo& info ):
                port_info(info)
              Entry(Any&& other_any, const PortInfo& info):
                value(std::move(other_any)),
                port_info(info)
          mutable std::mutex mutex_;
          std::unordered_map<std::string, Entry> storage_;
          std::weak_ptr<Blackboard> parent_bb_;
          std::unordered_map<std::string,std::string> internal_to_external_;
      } // end namespace
      #endif   // BLACKBOARD_H
        小鱼 技术大佬 @小鱼
        @小鱼 已经解决了,这句话是指定调用某个模板函数,避免二义性。(来自十多年的C++大佬回答)
          小鱼 技术大佬 @小鱼
          捞一下帖子,求C++大佬回答一下。
          • 小鱼小 小鱼 将这个主题转为问答主题,在
            小鱼 技术大佬 @小鱼
            • 小鱼小 小鱼 将这个主题标记为已解决,在
