    rosdepc update常见错误及解决方案
    rosdepc update
    18
    29
    30.2k
    • 9
      1 @497505919
      @497505919 老哥,你的问题解决了吗,我也遇到了这个问题
        贾永豪
        大佬你好,我在使用resdepc update中报错如下:
        kip end-of-life distro "groovy"
        Add distro "humble"
        ERROR: Rosdep experienced an error: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'raspbian', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'conda', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora-asahi', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
        Please go to the rosdep page [1] and file a bug report with the stack trace below.
        [1] : http://www.ros.org/wiki/rosdep
        rosdep version: 0.23.1
        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 146, in rosdep_main
        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 450, in _rosdep_main
        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 459, in _no_args_handler
        File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 676, in command_update
        quiet=options.quiet)
        File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 517, in update_sources_list
        File "/usr/lib/python2.7/dist-packages/rosdep2/gbpdistro_support.py", line 148, in get_gbprepo_as_rosdep_data
        ctx = create_default_installer_context()
        File "/usr/lib/python2.7/dist-packages/rosdep2/init.py", line 91, in create_default_installer_context
        m.register_platforms(context)
        File "/usr/lib/python2.7/dist-packages/rosdep2/platforms/arch.py", line 53, in register_platforms
        register_manjaro(context)
        File "/usr/lib/python2.7/dist-packages/rosdep2/platforms/arch.py", line 58, in register_manjaro
        (os_name, os_version) = context.get_os_name_and_version()
        File "/usr/lib/python2.7/dist-packages/rosdep2/installers.py", line 115, in get_os_name_and_version
        os_name = self.os_detect.get_name()
        File "/usr/lib/python2.7/dist-packages/rospkg/os_detect.py", line 638, in get_name
        self.detect_os()
        File "/usr/lib/python2.7/dist-packages/rospkg/os_detect.py", line 608, in detect_os
        OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'raspbian', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'conda', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora-asahi', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
        目前已经尝试了换源、本地编译等方法,但是都不能解决,并且尝试了rosdepc update --rosdistro=melodic仍然不能正常运行,我是ubuntu 1804的,应该是指令没有问题的
        2 19775388121 2 条回复 最后回复 回复 引用 0
          贾永豪 @2269810364
          @2269810364 请问大佬有什么解决方法没有
            凌@乱
            大佬怎么解决这个问题啊@小鱼
              凌@乱
              @小鱼 在 rosdepc update常见错误及解决方案 中说:
              ess sou
              @小鱼 怎么解决这个问题阿
                流年的][雨 @3360331610
                @3360331610 大佬请问解决了吗
                • 19775388121
                  ai @2269810364
                  @2269810364 解决了吗
                    见贤 @490872561
                    @490872561 我也是这个问题,现在问题解决了吗兄弟?
                      1040831491 @小鱼
                      @小鱼那应该怎么解决呢?我是24版
                      29644875142 1 条回复 最后回复 回复 引用 0
                      • 爱 爱学习的小羽毛 在 中 引用了 这个主题
                      • 29644875142
                        雨鱼无瓜 @毛哥成山轮胎机油保养
                        @毛哥成山轮胎机油保养 19fd8b5f-19c2-406d-b258-66ddddd36beb-image.png rosdepc安装失败
                          小鱼 技术大佬 @2964487514
                          @2964487514 没有安装成功
                          • 29644875142
                            雨鱼无瓜 @小鱼
                            @小鱼 最后是在CS DN里面, 找了一个新方法https://blog.csdn.net/qq_30267617/article/details/115028689
                            • 29644875142
                              雨鱼无瓜 @1040831491
                              @1040831491 https://blog.csdn.net/qq_30267617/article/details/115028689看这个链接
