    一键安装 ros2
    51.1k
    • 阿来呀阿
      阿来呀 @小鱼
      @小鱼 ltl@ltl-pc:~$ wget http://fishros.com/install -O fishros && . fishros
      --2022-07-07 09:48:20--  http://fishros.com/install
      --2022-07-07 09:48:21--  http://fishros.com/install/
      Saving to: ‘fishros’
      fishros                                       100%[==============================================================================================>]     543  --.-KB/s    in 0s
      2022-07-07 09:48:21 (67.6 MB/s) - ‘fishros’ saved [543/543]
      Reading package lists... Done
      --2022-07-07 09:48:21--  http://fishros.com/install/install1s/tools/base.py
      /tmp/fishinstall/tools/base.py                100%[==============================================================================================>]  41.01K  --.-KB/s    in 0.1s
      2022-07-07 09:48:21 (392 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41998/41998]
      [-]Result:success
      基础检查通过...
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      请输入[]内的数字以选择:1
      --2022-07-07 09:48:45--  http://fishros.com/install/install1s/tools/tool_install_ros.py
      /tmp/fishinstall/to 100%[===================>]  17.35K  --.-KB/s    in 0.06s
      2022-07-07 09:48:45 (292 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [17766/17766]
      --2022-07-07 09:48:45--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      /tmp/fishinstall/to 100%[===================>]   2.40K  --.-KB/s    in 0s
      2022-07-07 09:48:45 (410 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2022-07-07 09:48:45--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
      /tmp/fishinstall/to 100%[===================>]   7.33K  --.-KB/s    in 0s
      2022-07-07 09:48:45 (183 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[amd64:jammy],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [/]Get:8 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 DEP-11 Metadata [42[\]Get:9 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 48x48 Icons [100.0[|]Get:10 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64 Icons [148 [-]Get:11 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64@2 Icons [15[/]Get:12 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 c-n-f Metadata [30[\]Get:13 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 Packages [12[|]Get:14 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted i386 Packages [30.[-]Get:15 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted Translation-en [18[/]Get:16 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 c-n-f Metada[\]Get:17 https://mirrors.ustc.edu.cn/ubuntu jammy/universe i386 Packages [7,474 kB]
      [|]Get:18 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 Packages [14.1 MB]
      [-]Result:success                            --upgradable' to see them.ckages [151 kB]adata [228 B]]]
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Get:1 https://mirrors.ustc.edu.cn/ubuntu jammy InRelease [270 kB]', 'Get:2 https://mirrors.ustc.edu.cn/ubuntu jammy-updates InRelease [114 kB]', 'Get:3 https://mirrors.ustc.edu.cn/ubuntu jammy-backports InRelease [99.8 kB]', 'Get:4 https://mirrors.ustc.edu.cn/ubuntu jammy-security InRelease [110 kB]', 'Get:5 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 Packages [1,395 kB]', 'Get:6 https://mirrors.ustc.edu.cn/ubuntu jammy/main i386 Packages [1,040 kB]', 'Get:7 https://mirrors.ustc.edu.cn/ubuntu jammy/main Translation-en [510 kB]', 'Get:8 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 DEP-11 Metadata [423 kB]', 'Get:9 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 48x48 Icons [100.0 kB]', 'Get:10 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64 Icons [148 kB]', 'Get:11 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64@2 Icons [15.8 kB]', 'Get:12 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 c-n-f Metadata [30.3 kB]', 'Get:13 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 Packages [129 kB]', 'Get:14 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted i386 Packages [30.4 kB]', 'Get:15 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted Translation-en [18.6 kB]', 'Get:16 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 c-n-f Metadata [488 B]', 'Get:17 https://mirrors.ustc.edu.cn/ubuntu jammy/universe i386 Packages [7,474 kB]', 'Get:18 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 Packages [14.1 MB]', 'Get:19 https://mirrors.ustc.edu.cn/ubuntu jammy/universe Translation-en [5,652 kB]', 'Get:20 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 DEP-11 Metadata [3,559 kB]', 'Get:21 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 48x48 Icons [3,447 kB]', 'Get:22 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 64x64 Icons [7,609 kB]', 'Get:23 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 64x64@2 Icons [69.3 kB]', 'Get:24 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 c-n-f Metadata [286 kB]', 'Get:25 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse i386 Packages [112 kB]', 'Get:26 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 Packages [217 kB]', 'Get:27 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse Translation-en [112 kB]', 'Get:28 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 DEP-11 Metadata [42.1 kB]', 'Get:29 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 48x48 Icons [42.7 kB]', 'Get:30 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 64x64 Icons [193 kB]', 'Get:31 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 64x64@2 Icons [214 B]', 'Get:32 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 c-n-f Metadata [8,372 B]', 'Get:33 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 Packages [340 kB]', 'Get:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages [151 kB]', 'Ign:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages', 'Get:35 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main Translation-en [85.7 kB]', 'Get:36 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 DEP-11 Metadata [90.9 kB]', 'Get:37 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 48x48 Icons [26.2 kB]', 'Get:38 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 64x64 Icons [38.2 kB]', 'Get:39 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 64x64@2 Icons [29 B]', 'Get:40 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 c-n-f Metadata [6,172 B]', 'Get:41 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted amd64 Packages [215 kB]', 'Get:42 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted i386 Packages [22.1 kB]', 'Get:43 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted Translation-en [32.8 kB]', 'Get:44 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted amd64 c-n-f Metadata [536 B]', 'Get:45 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe i386 Packages [70.1 kB]', 'Get:46 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 Packages [141 kB]', 'Get:47 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe Translation-en [50.8 kB]', 'Get:48 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 DEP-11 Metadata [95.0 kB]', 'Get:49 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 48x48 Icons [38.0 kB]', 'Get:50 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 64x64 Icons [50.5 kB]', 'Get:51 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 64x64@2 Icons [29 B]', 'Get:52 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 c-n-f Metadata [2,960 B]', 'Get:53 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 Packages [7,032 B]', 'Get:54 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse i386 Packages [1,460 B]', 'Get:55 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse Translation-en [2,112 B]', 'Get:56 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 DEP-11 Metadata [940 B]', 'Get:57 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 48x48 Icons [1,867 B]', 'Get:58 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 64x64 Icons [2,497 B]', 'Get:59 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 64x64@2 Icons [29 B]', 'Get:60 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 c-n-f Metadata [420 B]', 'Get:61 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/main amd64 c-n-f Metadata [112 B]', 'Get:62 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/restricted amd64 c-n-f Metadata [116 B]', 'Get:63 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 Packages [5,404 B]', 'Get:64 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe i386 Packages [3,840 B]', 'Get:65 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe Translation-en [8,160 B]', 'Get:66 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 DEP-11 Metadata [12.5 kB]', 'Get:67 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 48x48 Icons [2,686 B]', 'Get:68 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 64x64 Icons [7,651 B]', 'Get:69 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 64x64@2 Icons [29 B]', 'Get:70 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 c-n-f Metadata [236 B]', 'Get:71 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/multiverse amd64 c-n-f Metadata [116 B]', 'Get:72 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main i386 Packages [68.4 kB]', 'Get:73 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 Packages [197 kB]', 'Get:74 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main Translation-en [48.8 kB]', 'Get:75 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 DEP-11 Metadata [11.4 kB]', 'Get:76 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 48x48 Icons [5,952 B]', 'Get:77 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 64x64 Icons [8,219 B]', 'Get:78 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 64x64@2 Icons [29 B]', 'Get:79 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 c-n-f Metadata [3,336 B]', 'Get:80 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted amd64 Packages [177 kB]', 'Get:81 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted i386 Packages [21.8 kB]', 'Get:82 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted Translation-en [26.2 kB]', 'Get:83 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted amd64 c-n-f Metadata [512 B]', 'Get:84 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 Packages [79.6 kB]', 'Get:85 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe i386 Packages [36.2 kB]', 'Get:86 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe Translation-en [28.4 kB]', 'Get:87 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 DEP-11 Metadata [608 B]', 'Get:88 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 48x48 Icons [29 B]', 'Get:89 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 64x64 Icons [29 B]', 'Get:90 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 64x64@2 Icons [29 B]', 'Get:91 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 c-n-f Metadata [1,700 B]', 'Get:92 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse i386 Packages [1,032 B]', 'Get:93 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse amd64 Packages [4,192 B]', 'Get:94 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse Translation-en [900 B]', 'Get:95 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse amd64 c-n-f Metadata [228 B]', 'Get:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages [151 kB]', 'Fetched 49.5 MB in 7min 3s (117 kB/s)', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "3 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [-]Result:success                           s for HTTPer dock appIolsceic typesmentation)slyt source code3 moree-system-lib-on-osx"
      [-]Result:success                           e and 3 not upgraded.
      [-]Result:success                           eplacement (dummy transitional package)
      [-]Result:success                            ...2.1_all.deb ...stalled.) gnupg2 all 2.2.27-3ubuntu2.1 [5,548 B]
      [-]Result:success
      [-]Result:success
      [-]Result:success                            --upgradable' to see them.64 Packages [643 kB]
      [-]Result:success                           tends 'ros_core' and includes other basic functionalities like tf2 and urdf.
      [1]:humble(ROS2)
      [2]:rolling(ROS2)
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:humble(ROS2)桌面版
      [2]:humble(ROS2)基础版(小)
      请输入[]内的数字以选择:1
      [-]Result:success                           end for Debian/Ubuntu (development files)sion
             Depends: libsystemd0 but it is not installable
       dconf-gsettings-backend : Depends: dconf-service (< 0.40.0-3.1~)
                                 Depends: dconf-service (>= 0.40.0-3)
       init : PreDepends: systemd-sysv
       libcolord2 : Depends: libudev1 (>= 196) but it is not installable
       libdbus-1-3 : Depends: libsystemd0 but it is not installable
                     Recommends: dbus
       libhwloc15 : Depends: libudev1 (>= 183) but it is not installable
       libignition-cmake2-dev : Depends: cmake
       libopenmpi-dev : Depends: openmpi-bin (>= 3.0.0-1)
                        Recommends: libcoarrays-openmpi-dev but it is not going to be installed
       libopenni2-0 : Depends: libudev1 (>= 183) but it is not installable
       libpulse0 : Depends: libsystemd0 but it is not installable
       libqt5designer5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
       libqt5designercomponents5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
       libqt5help5 : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
                              libqt5gui5-gles (>= 5.0.2) but it is not installable
       libqt5printsupport5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
       libqt5quickshapes5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                            Depends: libqt5quick5 (>= 5.14.1) but it is not installable or
                                     libqt5quick5-gles (>= 5.14.1) but it is not installable
       libqt5quicktest5 : Depends: libqt5gui5 (>= 5.12.2) but it is not installable or
                                   libqt5gui5-gles (>= 5.12.2) but it is not installable
                          Depends: libqt5quick5 (>= 5.0.2) but it is not installable or
                                   libqt5quick5-gles (>= 5.0.2) but it is not installable
       libqt5quickwidgets5 : Depends: libqt5gui5 (>= 5.10.0) but it is not installable or
                                      libqt5gui5-gles (>= 5.10.0) but it is not installable
                             Depends: libqt5quick5 (>= 5.15.1) but it is not installable or
                                      libqt5quick5-gles (>= 5.15.1) but it is not installable
       libqt5svg5 : Depends: libqt5gui5 (>= 5.15.3+dfsg~) but it is not installable or
                             libqt5gui5-gles (>= 5.15.3+dfsg~) but it is not installable
       libqt5webkit5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                       Depends: libqt5quick5 (>= 5.15.3+dfsg~) but it is not installable or
                                libqt5quick5-gles (>= 5.15.3+dfsg~) but it is not installable
       libqt5widgets5 : Depends: libqt5gui5 (>= 5.15.1) but it is not installable or
                                 libqt5gui5-gles (>= 5.15.1) but it is not installable
       libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3) but it is not installable
       libusb-1.0-0 : Depends: libudev1 (>= 183) but it is not installable
       libvtk9-qt-dev : Depends: libqt5opengl5-dev but it is not installable
       libvtk9.1-qt : Depends: libqt5gui5 (>= 5.11.0~rc1) but it is not installable or
                               libqt5gui5-gles (>= 5.11.0~rc1) but it is not installable
       mpi-default-bin : Depends: openmpi-bin
       python3-pyqt5 : Depends: libqt5gui5 (>= 5.1.0) but it is not installable
       python3-pyqt5.qtsvg : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
       python3-pyside2.qtgui : Depends: libqt5gui5 (>= 5.15) but it is not installable
        小鱼 技术大佬 @阿来呀
        @阿来呀 在 一键安装ros2显示没有找到包:python3-argcomplete 中说:
        这个下面的东西嘞,按理说这后面应该会暂停检测错误的,你有看到 吗
        • 阿来呀阿
          阿来呀 @小鱼
          @小鱼 刚刚重新试一下,前面一直没报错,但是最后还是显示不成功,我还是重新装一下Ubuntu22.04,然后再试一下一键安装
            小鱼 技术大佬 @阿来呀
            @阿来呀 这个错误我遇到过很多次了,一键安装也是能自动解决的,你这个关键日志一直贴不上,我也没办法帮你看,那你重装下吧。
            阿来呀阿 2 条回复 最后回复 回复 引用 0
            • 阿来呀阿
              阿来呀 @小鱼
              @小鱼 嗯嗯,谢谢,我重装试试看一下
              • 阿来呀阿
                阿来呀 @小鱼
                @小鱼 小鱼,我刚刚重装Ubuntu再下还是有问题,我把日志给你看看
                阿来呀阿 1 条回复 最后回复 回复 引用 0
                • 阿来呀阿
                  阿来呀 @阿来呀
                  怎么命令行的日志复制不了了
                  小鱼小 阿来呀阿 2 条回复 最后回复 回复 引用 0
                    小鱼 技术大佬 @阿来呀
                    @阿来呀 你在虚拟机中打开我们的社区,然后复制粘贴都在虚拟机里进行应该就可以了,另外提供一下你的镜像名字,我看看你的镜像有没有毛病
                    • 阿来呀阿
                      阿来呀 @阿来呀
                      ubuntu-22.04-desktop-amd64
                        小鱼 技术大佬 @阿来呀
                        @阿来呀 给一下日志吧,我瞅瞅
                        • 阿来呀阿
                          阿来呀 @小鱼
                          @阿来呀 ok,谢谢你,装好了
                          • 阿来呀阿
                            阿来呀 @阿来呀
                            @阿来呀 真的十分感谢你
                              小鱼 技术大佬 @阿来呀
                              @阿来呀 可以给我说说咋回事吗,忙活半天我还是一脸蒙
                              • 阿来呀阿
                                阿来呀 @小鱼
                                @小鱼 好像就是有个地方说我十分依赖啥的,要我先输n后输y,这个地方我没注意,我记得我之前一直输y还是咋滴
                                  小鱼 技术大佬 @阿来呀
                                  @阿来呀 了解了
                                  • 小伊小 小伊 将这个主题转为问答主题,在
                                  • 小伊小 小伊 将这个主题标记为已解决,在
