    (foxy教程10.9运行nav2时报错)Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
    动手学ROS2
    ros2 nav2 ros2-foxy
    1.4k
      T.
      在跟着教程走到运行nav2,初始化设置的时候,rviz出现的不是error,而是warm,rviz界面如下:
      终端报错如下:
      [controller_server-4] [INFO] [1712253661.690443611] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1712253661.773769226] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1712253661.773940891] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [controller_server-4] [INFO] [1712253662.190515009] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [controller_server-4] [INFO] [1712253662.690512522] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [rviz2-10] [INFO] [1712253662.774192578] [rviz2]: Waiting for the lifecycle_manager_navigation/is_active service...
      [rviz2-10] [INFO] [1712253662.774363237] [rviz2]: Sending lifecycle_manager_navigation/is_active request
      [controller_server-4] [INFO] [1712253663.190443715] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      目前我自己的nav2功能包中,CMAKEList文件:
      project(sim_nav2)
      # Default to C99
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
      find_package(nav2_bringup REQUIRED)
      install(
        DIRECTORY launch param maps
        DESTINATION share/${PROJECT_NAME}
      if(BUILD_TESTING)
      endif()
      ament_package()
      package.xml文件:
      <?xml version="1.0"?>
      <package format="3">
        <name>sim_nav2</name>
        <version>0.0.0</version>
        <maintainer email="wjndem@163.com">jeni</maintainer>
        <depend>nav2_bringup</depend>
        <export>
        </export>
      </package>
      launch文件:
      作者: 小鱼
      公众号: 鱼香ROS
      QQ交流群: 2642868461
      描述: Nav2 launch启动文件
      import os
      from launch.actions import IncludeLaunchDescription
          #=============================1.定位到包的地址=============================================================
          fishbot_navigation2_dir = get_package_share_directory('sim_nav2')
          #=============================2.声明参数,获取配置文件路径===================================================
          # use_sim_time 这里要设置成true,因为gazebo是仿真环境,其时间是通过/clock话题获取,而不是系统时间
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          map_yaml_path = LaunchConfiguration('map',default=os.path.join(fishbot_navigation2_dir,'maps','sim_map.yaml'))
          nav2_param_path = LaunchConfiguration('params_file',default=os.path.join(fishbot_navigation2_dir,'param','whe_nav2.yaml'))
          rviz_config_dir = os.path.join(nav2_bringup_dir,'rviz','nav2_default_view.rviz')
          #=============================3.声明启动launch文件,传入:地图路径、是否使用仿真时间以及nav2参数文件==============
          nav2_bringup_launch = IncludeLaunchDescription(
                  PythonLaunchDescriptionSource([nav2_bringup_dir,'/launch','/bringup_launch.py']),
                  launch_arguments={
                      'map': map_yaml_path,
                      'use_sim_time': use_sim_time,
          rviz_node =  Node(
                  package='rviz2',
                  executable='rviz2',
                  name='rviz2',
                  output='screen')
          return LaunchDescription([nav2_bringup_launch,rviz_node])
      麻烦大佬帮忙看看什么问题,谢谢!
      • 29127732652
        2912773265
        请问解决了吗。我现在也遇到这个问题
        29127732652 1 条回复 最后回复 回复 引用 0
        • 29127732652
          2912773265 @2912773265
          @2912773265 而且我不能选择2d position estimate
